Floorplan now available as a Lovelace card
Look here for a similar issue I'm stuck at the beginning of home_simple. ERROR /local/floor plan/home simple/home simple.css?_= - #12 by leandroog
Type the path to you SVG into the address bar and see if you can see it. If so check the path in your yaml
Thanks! I had replaced /local/ with /config/www/ yesterday, and saw the improvement in that the error message changed to missing entities instead of missing file. However, now that i moved back to /local/, the floorplan showed up! I think it has to do with my NAS where I am running HA was restarted during the night. … and that solved the problem with my “/local/” not working.
I’m trying to change the opacity based on brightness of a light. Can’t get it to work. What am I doing wrong?
    - entities:
        - element: Livingroom_Spots_On
          entity: light.living_room_spots_2
      state_action:
        action: call-service
        service: floorplan.style_set
        service_data: |
            var opacity = '${(entity.state === "on") ? (entity.attributes.brightness / 255) : '0'}';
          return `opacity: ${opacity};`;
Firstly I would wrap the attribute in parseInt() before dividing by 255 and then you should probably round that result so you have an integer for the opacity
Im getting a error: 4/6/2024, 4:12:13 PM ERROR Unexpected token (1:117) (See console for more info)
Ok but if you don’t supply the yaml then we can’t help
The code in the first code-box is the function I try to use for setting opacity based on brightness of a light. Without this section, no error-message. Below the full yaml and css-code.
    - entities:
      state_action:
        service_data: |
Full YAML:
type: custom:floorplan-card
full_height: false
config:
  console_log_level: info
  log_level: info
  image: /local/floorplan/40.svg
  cache: true
  stylesheet: /local/floorplan/40.css
  startup_action:
    - service: floorplan.class_set
      service_data:
        elements:
          - ButtonAtticShow
          - ButtonSensorsShow
        class: layer-visible
      service_data:
        elements:
          - Parking
          - Attic
          - Attic_Sensors
          - Downstairs_Sensors
          - ButtonAtticHide
          - ButtonSensorsHide
        class: layer-hidden
  rules:
    - element: ButtonAtticShow
      tap_action:
          service_data:
            elements:
              - ButtonAtticHide
              - Attic
          service_data:
            elements:
              - ButtonAtticShow
            class: layer-hidden
    - element: ButtonAtticHide
      tap_action:
          service_data:
            elements:
              - ButtonAtticShow
          service_data:
            elements:
              - ButtonAtticHide
              - Attic
            class: layer-hidden
    - element: ButtonSensorsShow
      tap_action:
          service_data:
            elements:
              - ButtonSensorsHide
              - Attic_Sensors
          service_data:
            elements:
              - ButtonSensorsShow
            class: layer-hidden
    - element: ButtonSensorsHide
      tap_action:
          service_data:
            elements:
              - ButtonSensorsShow
          service_data:
            elements:
              - ButtonSensorsHide
              - Attic_Sensors
            class: layer-hidden
    - element: Attic_Bedroom_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#bedroom'
    - element: Attic_GuestBedroom_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#guestbedroom'
    - element: Attic_Office_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#office'
    - element: Attic_WC_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#wc'
    - element: Attic_HallAttic_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#hallattic'
    - element: LivingroomTemp_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#heating'
    - element: LivingroomSpots_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#lights'
    - element: LivingroomVarious_Toucharea
      tap_action:
        action: navigate
    - element: Dining_Toucharea
      tap_action:
        action: navigate
    - element: KitchenIsland_Toucharea
      tap_action:
        action: navigate
    - element: KitchenSink_Toucharea
      tap_action:
        action: navigate
    - element: Bathroom_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#bathroom'
    - element: Hall_Toucharea
      tap_action:
        action: navigate
        navigation_path: '#hall'
    - entity: sensor.air_quality_temperature_measurement
      state_action:
        - service: floorplan.text_set
          service_data: '${entity.state ? entity.state + "°C" : "unknown"}'
    - entity: sensor.bathroom_temp_hum_temperature_measurement
      state_action:
    - entity: sensor.bathroom_temp_hum_relative_humidity_measurement
      state_action:
          service_data: '${entity.state ? entity.state + " %" : "unknown"}'
    - entity: sensor.temp_and_humidity_temperature_measurement
      state_action:
    - entity: sensor.motion_sensor_guest_bedroom_temperature
      state_action:
    - entity: sensor.motion_sensor_hall_attic_temperature
      state_action:
    - entity: sensor.motion_sensor_bathroom_attic_temperature
      state_action:
    - entity: sensor.motion_sensor_office_temperature
      state_action:
    - entities:
        - entity: light.bathroom_spots
          element: Bathroom_On
        - entity: light.hallway
          element: Hall_On
        - entity: light.kitchen_spots_2
          element: Kitchen_Spots_On
        - entity: light.kitchen_zink_2
          element: Kitchen_Sink_On
        - entity: light.kitchen_island_2
          element: Kitchen_Island_On
          element: Kitchen_On
        - entity: light.dining
          element: Dining_On
        - entity: light.living_room_spots_2
          element: Livingroom_Any_On
        - entity: switch.bathroom_attic_lights
          element: WC_On
        - entity: light.office
          element: Office_On
        - entity: light.guest_bedroom_2
          element: GuestBedroom_On
      state_action:
        service_data: '${(entity.state === "on") ? "layer-visible" : "layer-hidden"}'
    - entities:
        - entity: binary_sensor.bedroom_contact
          element: Hall_Attic_Off_Door_Open
        - entity: light.bedroom
          element: Hall_Attic_DoorOpen_Off_Bedroom_On
        - entity: light.hall_attic_2
          element: Hall_Attic_On
          element: Bedroom_DoorOpen
          element: Bedroom_DoorOpen_On_Hall_On
          element: Bedroom_DoorClosed_On
          element: Bedroom_DoorOpen_LightOn
          element: Bedroom_DoorOpen_Off_Hall_On
      state_action:
    - entities:
          element: Bedroom_DoorOpen_LightOff
          element: Bedroom_DoorOpen_Off_Hall_Off
      state_action:
        service_data: '${(entity.state === "off") ? "layer-visible" : "layer-hidden"}'
    - entities:
        - entity: sensor.smoke_detector_livingroom_smoke_detector
          element: Sensor_Livingroom_Frame_Detected
          element: Sensor_Livingroom_Fire_Detected
        - entity: sensor.smoke_detector_hallway_smoke_detector
          element: Sensor_Hall_Frame_Detected
          element: Sensor_Hall_Fire_Detected
        - entity: sensor.smoke_detector_bedroom_smoke_detector
          element: Sensor_Bedroom_Frame_Detected
          element: Sensor_Bedroom_Fire_Detected
        - entity: sensor.smoke_detector_guest_bedroom_smoke_detector
          element: Sensor_GuestBedroom_Frame_Detected
          element: Sensor_GuestBedroom_Fire_Detected
        - entity: sensor.smoke_detector_hall_attic_smoke_detector
          element: Sensor_HallAttic_Fire_Detected
          element: Sensor_HallAttic_Frame_Detected
      state_action:
        service_data: '${(entity.state === "detected") ? "layer-visible" : "layer-hidden"}'
    - entities:
          element: Sensor_Livingroom_Frame_Clear
          element: Sensor_Livingroom_Fire_Clear
          element: Sensor_Hall_Frame_Clear
          element: Sensor_Hall_Fire_Clear
          element: Sensor_Bedroom_Frame_Clear
          element: Sensor_Bedroom_Fire_Clear
          element: Sensor_GuestBedroom_Frame_Clear
          element: Sensor_GuestBedroom_Fire_Clear
          element: Sensor_HallAttic_Fire_Clear
          element: Sensor_HallAttic_Frame_Clear
      state_action:
        service_data: '${(entity.state === "clear") ? "layer-visible" : "layer-hidden"}'
    - entities:
          element: Sensor_Livingroom_Fire_Error
          element: Sensor_Hall_Fire_Error
          element: Sensor_Bedroom_Fire_Error
          element: Sensor_GuestBedroom_Fire_Error
          element: Sensor_HallAttic_Fire_Error
      state_action:
        service_data: '${(entity.state === "undefined") ? "layer-visible" : "layer-hidden"}'
    - entities:
        - entity: lock.main_door
          element: Sensor_Hall_Main_Door_Lock_Unlocked
      state_action:
        service_data: '${(entity.state === "unlocked") ? "layer-visible" : "layer-hidden"}'
    - entities:
          element: Sensor_Hall_Main_Door_Lock_Locked
      state_action:
        service_data: '${(entity.state === "locked") ? "layer-visible" : "layer-hidden"}'
    - entities:
          element: Sensor_Hall_Main_Door_Lock_Error
      state_action:
    - entities:
        - entity: binary_sensor.balcony_door_contact
          element: Sensor_Livingroom_Balconydoor_Closed
        - entity: binary_sensor.main_door_contact
          element: Sensor_Hall_Main_Door_Closed
        - entity: binary_sensor.escape_shaft_contact
          element: GuestBedroomEscapeClosed
      state_action:
    - entities:
          element: Sensor_Livingroom_Balconydoor_Open
          element: Sensor_Hall_Main_Door_Open
          element: GuestBedroomEscapeOpen
      state_action:
    - entities:
        - entity: binary_sensor.motion_sensor_bathroom_motion_2
          element: Sensor_Bathroom_Motion_Detected
        - entity: binary_sensor.camera1_cell_motion_detection
          element: Sensor_Livingroom_Camera_Detected
        - entity: binary_sensor.motion_sensor_bedroom_motion_2
          element: Sensor_Bedroom_Motion_Detected
        - entity: binary_sensor.motion_sensor_guest_bedroom_motion_3
          element: Sensor_GuestBedroom_Motion_Detected
        - entity: binary_sensor.motion_sensor_hall_attic_motion_2
          element: Sensor_HallAttic_Motion_Detected
        - entity: binary_sensor.motion_sensor_office_motion_2
          element: Sensor_Office_Motion_Detected
        - entity: binary_sensor.motion_sensor_bathroom_attic_motion_2
          element: Sensor_WC_Motion_Detected
      state_action:
    - entities:
          element: Sensor_Bathroom_Motion_Error
          element: Sensor_Livingroom_Camera_Error
          element: Sensor_Bedroom_Motion_Error
          element: Sensor_GuestBedroom_Motion_Error
          element: Sensor_HallAttic_Motion_Error
          element: Sensor_Office_Motion_Error
          element: Sensor_WC_Motion_Error
      state_action:
    - entities:
        - entity: switch.motion_sensor_bathroom_motion
          element: Sensor_Bathroom_Motion_On
        - entity: switch.camera1_privacy
          element: Sensor_Livingroom_Camera_Off
        - entity: switch.motion_sensor_bedroom_motion
          element: Sensor_Bedroom_Motion_On
        - entity: switch.motion_sensor_guest_bedroom_motion
          element: Sensor_GuestBedroom_Motion_On
        - entity: switch.motion_sensor_hall_attic_motion
          element: Sensor_HallAttic_Motion_On
        - entity: switch.motion_sensor_office_motion
          element: Sensor_Office_Motion_On
        - entity: switch.motion_sensor_bathroom_attic_motion
          element: Sensor_WC_Motion_On
      state_action:
    - entities:
          element: Sensor_Bathroom_Motion_Off
          element: Sensor_Livingroom_Camera_On
          element: Sensor_Bedroom_Motion_Off
          element: Sensor_GuestBedroom_Motion_Off
          element: Sensor_HallAttic_Motion_Off
          element: Sensor_Office_Motion_Off
          element: Sensor_WC_Motion_Off
      state_action:
    - entities:
        - entity: binary_sensor.water_leak_sensor_water
          element: Sensor_Kitchen_Waterleak_Detected
        - entity: binary_sensor.water_leak_sensor_water_2
          element: Sensor_Bathroom_Waterleak_Detected
        - entity: binary_sensor.waterleak_hw_tank_water
          element: Sensor_WC_Waterleak_Detected
      state_action:
    - entities:
          element: Sensor_Kitchen_Waterleak_Clear
          element: Sensor_Bathroom_Waterleak_Clear
          element: Sensor_WC_Waterleak_Clear
      state_action:
    - entities:
          element: Sensor_Kitchen_Waterleak_Error
          element: Sensor_Bathroom_Waterleak_Error
          element: Sensor_WC_Waterleak_Error
      state_action:
        service_data: '${(entity.state === "unavailable") ? "layer-visible" : "layer-hidden"}'
    - entities:
        - entity: sun.sun
          element: Outside_Night
        - entity: sun.sun
          element: Livingroom_Night
        - entity: sun.sun
          element: Attic_Night
      state_action:
        service_data: >-
          ${(entity.state === "below_horizon") ? "layer-visible" :
          "layer-hidden"}
    - entities:
        - entity: sun.sun
          element: Outside_Day
        - entity: sun.sun
          element: Livingroom_Day
        - entity: sun.sun
          element: Attic_Day
      state_action:
        service_data: >-
          ${(entity.state === "above_horizon") ? "layer-visible" :
          "layer-hidden"}
    - entities:
        - entity: switch.bathroom_fan
          element: BathroomFan
      state_action:
        service_data: '${(entity.state === "on") ? "spinning" : "layer-hidden"}'
    - entities:
        - light.hallway
        - light.living_room_spots_2
      state_action:
        - action: call-service
          service_data: |
              var elements = [
                `${entity.entity_id}`,
                `${entity.entity_id}.gradient_color_0`,
              var color = 'rgb(0, 0, 0)';
              var opacity = 0;
              if (entity.state === 'on') {
                if (entity.attributes.color_temp) {
                  var rgb = util.color.miredToRGB(entity.attributes.color_temp);
                  color = `rgb(${rgb[0]}, ${rgb[1]}, ${rgb[2]})`;
                  opacity = '(entity.attributes.brightness / 255)';
                else if (entity.attributes.rgb_color) {
                  var rgb = entity.attributes.rgb_color;
              var style = `fill: ${color}; stop-color: ${color}; stop-opacity: ${opacity};`;
              return {
                elements: elements,
                style: style,
    - entities:
      state_action:
        service_data: |
CSS:
/* Layers */
.layer-visible {
  display: inline !important;
.layer-hidden {
  display: none !important;
/* Spinning fan */
.spinning {
  animation-name: spin;
  animation-duration: 2s;
  animation-iteration-count: infinite;
  animation-timing-function: linear;
  transform-origin: center;
  transform-box: fill-box;
@keyframes spin {
  from {
    transform: rotate(0deg);
  to {
    transform: rotate(360deg);
You haven’t made any changes based on the first response I gave you. Also the 0 is wrapped in single quotes when it needs to be in double “
I have tried your suggestion. The double quote fixed the error-message, but it is still not changing the opacity based on brightness of lamp.
    - entities:
      state_action:
        service_data: |
            var opacity = '${(entity.state === "on") ?  (parseInt(entity.attributes.brightness) / 255) : "0"}';
I doesn’t look like the “var opacity” is sent to “return opacity”.
Trying to hardcode a number in return line, i.e. “return opacity: 0.5;;” works.
Trying to hardcode 0.5 in the if does not work, i.e. " var opacity = ‘${(entity.state === “on”) ? “0.5” : “0”}’;"
Try it like this
          state_action:
            service_data:
              style: |
                opacity: ${(entity.state === "on") ? Math.round(parseInt(entity.attributes.brightness)/255): "0"}
Edit: if you keep it the way you currently have it then use something like this to show what the values of everything are as it executes.
 console.log('brightness', entity.attributes.brightness);
I’ve tried to “install” the example files, but they do not work. Can somebody please help me to find the error in one of my steps?
  1. I’ve installed the Lovelace Card via HACS and after that it is listed in my resources.
  2. Then I’ve created a new view in my dashboard. Since a floorplan card wasn’t listed I did choose the manual way and added the following code:
title: test
  - title: Floorplan
    path: floorplan
    badges: []
    cards:
      - type: vertical-stack
        cards:
          - type: horizontal-stack
            cards:
              - type: custom:floorplan-card
                full_height: true
                config:
                  image: /local/floorplan/examples/home/home.svg
                  stylesheet: /local/floorplan/examples/home/home.css
                  log_level: info
                  defaults:
                    hover_action: hover-info
                    tap_action: more-info
                  rules:
                    - entity: light.garage
                      element: light.garage
                      state_action:
                        service: floorplan.image_set
                        service_data: >-
                          /local/floorplan/examples/home/light_${entity.state}.svg
                      tap_action: toggle
                      element: light.garage.button
                      state_action:
                        service_data: button-${entity.state}
                      tap_action:
                        service: homeassistant.toggle
                      element: light.garage.text
                      state_action:
                        service_data: ${entity.state}
                      tap_action: false
                    - entity: switch.living_area_fan
                      tap_action: false
                      state_action:
                        service_data:
                          class: '${(entity.state === "on") ? "spinning" : ""}'
                      element: switch.living_area_fan.button
                      state_action:
                      hold_action:
                        service_data:
                          entity_id: switch.living_area_fan
                      element: switch.living_area_fan.text
                      state_action:
                      tap_action: false
                    - entity: camera.zagreb_ban_jelacic_square
                      state_action:
                        service_data:
                          image: ${entity.attributes.entity_picture}
                          image_refresh_interval: 10
                    - entities:
                        - binary_sensor.main_bedroom
                        - binary_sensor.living_area
                      state_action:
                        service_data:
                          style: >
                            fill: ${ entity.state === "on" ? "#F9D27C" :
                            "#7CB1F9" };
                            transition: ${ entity.state === "off" ? "fill 5s
                            ease" : "" };
  1. Then I did create the following folders via file editor and uploaded the two home files:
But the dashboard is still empty:
What can I do?
Regards,
Jogi
Please take a look at my YouTube videos:
Also, try and check the JS console, and if you see any issues. You can also set our debug option in ha-floorplan itself.
If you still facing any issues, create a Discussion topic on GitHub :blush:.
Here’s another example:
Also, follow OzGav’s suggestion: Simplify to the bare minimum.
Start by simplifying. Remove the vertical and horizontal stack.
Try and access the image by putting the image address in your browser address bar after YOUR_HA_IP:8223
Do you mean like this?https://.ui.nabu.casa:8223/local/floorplan/examples/home/home.svg
That didn’t work…
Remove all the things you don’t need in the YAML code.
Also, it’s not a good ideá to share the link to your Home Assistant instance.
Also, OzGaz asks you to check if files below “local” or “www” are actually resolveable. You can upload whatever to that folder in your Home Assistant solution, to confirm if it’s possible to access the files. If you cannot open the svg path, it’s not related to ha-floorplan: It’s related to your Home Assistant setup.
You need to play around with the “www” and “local” subpath of your home assistant instance, and see what works for you. The www folder in the root of your Home Assistant solution are normally solved as “/local” in the http web-address. But it depends on what kind of solution you’re using.
Here where it’s using “hacsfiles” for the weather-card I’m using, you’ll normally use “local” or “www” for files stored in the “www” folder.
Here’s the content of my home assistant root (output stripped down)
➜  homeassistant ls -alht
total 828M
drwxr-xr-x 62 <myusername> <myusername>  12K Aug 15 14:41 ..
-rw-r--r--  1 root root 1.8M Aug 15 14:40 home-assistant.log
-rw-r--r--  1 root root  21K Aug 14 14:32 automations.yaml
drwxr-xr-x 12 <myusername> <myusername> 4.0K Aug 14 14:27 www
➜  homeassistant pwd
/home/<myusername>/homeassistant
Notice that I have a folder called “www”, but should be resolved as “local”, like: http://10.0.0.x/local/<whatever_file>
cant get it to work…
i copy and pasted example and there is always: Your configuration is not valid: r: At path: views – Expected an array value, but received: undefined
what is the solution to this
nothing from examples works…
Did you watch @exetico video that he linked a few posts up?
Hi, just another input:
If you copy pasted all, and you’re facing issues. Kindly explain what you copied, and where and how you pasted it.
Please link to the source too. If the guide does have a bug, I’ll correct it.
i found out if you just copy raw from github it is in wrong format and you get the message (Your configuration is not valid: r: At path: views – Expected an array value, but received: undefined,…)… i needed some time to figure this out :smiley: sorry.
now im writing all by my self and it is slowly getting shapes.
im now trying to get temperatures on picture…
this thing is not the easiest for total begginers.
Where did you copy from, from Github? And where did you try and paste it?
I’d like to add a comment to the guide, if I could prevent this kind of misunderstanding :slight_smile:
Happy floorplanning! And no, it’s not the easiest, for sure. With that said, it also a good way trying to touch both CSS and Javascript on a basis level. But for sure, not that easy to taggle :slight_smile: .
