I managed to do it for my roller shutters but it is an ‘active’ element I don’t know if it can work with just the state information. I try to explain
in the svg make for example a square and give it a name, for example solarium.heatlevel
in the configuration :
element: your svg name ex solarium.heatlevel
entity: the entity with your data ex climate.solarium
image_template: >-
var heatlevelstate = entity.attributes.name of the attribute; if (heatlevelstate
< xx) return '/local/heat-1.png’; # you must specify the exact address of the directory
else if (heatlevelstate < xx) return '/local/yourpng';
else return '/local/yourpng'; # for the last case
heatlevelstate is a exemple, you can choose another name.
I hope this will help you and my apologies for my bad english
Added the resource as a JavaScript Module.
tried a lovelace card config which works partly. The card keeps on loading. How can i try replicate the “simple” example so i can continue building on and edit to my plans. Thanks
Hi there.
Went thru your tutorial step by step but I do not get anything displaying.
I can see the entities and their changing states but no floorplan image…
I find a code for navigating between pages, link below.
Also CCOSTAN is using similar type of code in his setup (not a floorplan-card).
However, when I try it comes with an error … maybe some smarter people can figure it out how to use it the right way.
where “toggle_button” is the id of the object you use as a button and “page1” is the layer id (saved in inkscape xml), also your css file must include .layer-hidden and .layer-visible.
Maybe make a binary_sensor that changes to true when either of the sensor or lamp conditions are met. Then set the SVG element to the status of the binary_sensor?
Hey OzGav, thanks for your comment! I forgot to answer that I have solved the templte sensor, I am more and more studying templats there you can do fun things to me!
Very simply, with Floorplan you have total control and can use any shapes, in any way. This makes it significantly more flexible, and requires more effort.
For instance, on my floorplan those doors and windows are part of the SVG. No matter how the view scales, they remain perfectly aligned. Same with every other entity.
Trying to duplicate that with the Picture Elements card was frustrating, and I abandoned those efforts.
Of course, that’s partly my fault for wanting my floorplan to closely resemble reality… If I wanted something more conceptual it’d be easier to use Picture Elements.
I saw that people have cases where they define multiple CSS classes (e.g. for different light or temperature levels) and handle the switching with a class_template, but I haven’t been able to find cases where a CSS variable can be used (in the YAML or CSS). I don’t know which variables are defined or whether there are other tricks.
I was also wondering whether there is extensive documentation somewhere. The simple example does great at explaining some of the basics and the structure, but it’s not clear what all the options and limitations are (regarding the YAML config).
And if I may ask one more thing: I see there is both lovelace-floorplan (which I’m using) and ha-floorplan. I can’t quite figure out whether the one supersedes the other or whether both are supported and what the pros and cons of the two options are.
I installed files and got the simple sample working in a custom panel and changed some of the elements in the svg to match my light switches.
I click them and THEY WORKED! But only once or maybe twice. After that, no response. I still get the hover arrow as if they SHOULD do something, but nope. Even refreshing the page does nothing. I’m on HA 0.110.4
One detail I noticed re: my previous post - if I manually turn off the switches for the lights (Tuya switches) then clicking the Floorplan button will turn them on. So even though I have it calling a Toggle on the switch, it is only sending an ‘Turn On’ command. Based on the default install code, is there a way to have it check the state of a switch and then send the correct code to switch it to the opposite state (Off/On)?
Thanks all!
Hi all,
I am converting my 2D image to 3D. All is going well but I have just run into a problem. Currently I can click pretty much anywhere in a room and turn the main room light on. I would like to still do that. When I cut out the mask for a room light it includes all the streaming light out of the doors and windows (looks great!). However this means I have a huge touch target now and they all overlap. This is because I am using a JPG as the base image and then putting the PNG “lights on” image over the top which is then hidden via CSS until the light is on.It is this image that is the touch target.
So how have people solved this? I am thinking I can make a transparent area which is the touch target and then have booleans for each room with an automation that keeps that in sync with the light status and then link the PNG with the boolean. Does that make sense? Is there an easier way to do this?
I have used image templates elsewhere which change an image based on an attribute but they are all the same size and shape so I don’t think that will work?
Following on from my idea above. I have set up a input boolean and I am using the following to try and keep the input boolean state synchronised to the light state but it is currently doing the opposite and I am seeing an error in the log. Here is my code:
I finally figured out how to get the ‘simple’ example working properly in 0.113. Since the process I think was more painful than it should be, I’ll highlight some things for other newbs just trying to get started with this great lovelace floorplan card. I think these items should be updated on the github docs (I may submit a PR myself, but wanted to pass across more advanced folks first).
Step #3 in the primary readme refers to adding the resource url to your lovelace config.
Of course the natural progression (and suggested below on the page) is to open up the lovelace raw yaml editor and paste that in. Fortunately when you do this, a warning pop up tells you not to add resources: to the yaml, instead use the lovelace config ui. So then I have to delete those lines and resave the yaml, then open up configuration/lovelace and enter the module url there. The docs should be updated to point newbs straight to the lovelace config ui.
This gripe probably has more to do with my lack of understanding how lovelace yaml works… the tutorial for the simple example says to simply ‘add the following to your Lovelace configuration:’. So, a newb clicks ‘configure ui’ from the hamburger, clicks the orange + circle in the bottom, scrolls down and clicks the ‘manual’ card entry, pastes in the entirety of code from the example, and gets a big red box with ‘card type errors’. I believe this is going to be the usual way a newb will attempt to go about setting up the simple example. So instead the example lovelace card should be purely just a card config like this:
This code works when you just paste it into a ‘manual card’ using the gui. I know the example includes more yaml for the header/tabs and stuff, but since this is a ‘card’ by definition, folks are going to expect it to work like a card, not a card+headers+extraJunk.
Please don’t take this post as a negative. I truly appreciate all the efforts that have gone in to making this what it is. I just wanted to give a fresh perspective on things in case the docs could be polished up so newbs get a smoother introduction to this awesome project.
hello everyone, I have a problem with lovelace, in the iphone open the floorplan but in browser give me error ‘’ You need to define an entity ‘’ what can I be doing wrong ??
Hello, I’m a novice. I’ve been working on multi floor display for a long time, but I can’t. You can say what this means, or share an example. Thank you
