Floorplan UI with Color synced lights
Odd, I’ve added that and it still doesn’t work.
Looking at the previous code I had which somewhat worked, there was also no tap_action. But again, this code didn’t seem to handle colours correct which is why I’m using your code.
  - type: "custom:config-template-card"
    entities:
      - light.desk
    element:
      action: none
      entity: light.desk
      tap_action:
        action: none
      hold_action:
        action: none
      image: /local/home_transparent.png
      state_image:
        "on": /local/ui/floorplan/lights/rez/home_afternoon_bedroomdesk_on.png
      type: image
    style:
      filter: >-
        ${ "hue-rotate(" + (states['light.desk'].attributes.hs_color ? states['light.desk'].attributes.hs_color[0] : 0) + "deg) saturate(100%)"}
      opacity: >-
        "${states['light.desk'].state === 'on' ? (states['light.desk'].attributes.brightness / 255) : '0'}"
      left: 50%
      top: 35.70%
      width: 100%
      mix-blend-mode: lighten
I quess now I am also confused :smiley:
The code for the light images is correct without tab_action. Its just the color of the light if its on.
For the icon switch you have to edit the other code, where you have the icon and the color wheel for hold_action. There you have to insert the tab_action.
I notice your icon does not change either, it should also reflect the fact the light is on.
I believe this has to do with the hue-rotate code. If my colored lights are not rendere as red, the colors in HA will not show correctly. Perhaps you’re not affected by this, have you tried the same code with a light rendered as white instead of red?
I got a white and a red rendered image.
This is the actual selected light color.
And its not only if i select a red light color (wich is obviously not red its white) even all other colors are slightly off. Just a white color shows correctly.
EDIT: With a light bulb it works great with all colors just on a lightstrip it doesn’t.
I’ve fixed that now! Dark grey when OFF and white when ON. But when I set it to a colour it will change to the selected colour.
I’ve got both white and red rendered images too.
Have also just tried this config on another hue colour light with all the images rendered for white and red & it still doesn’t work. So I must be doing something wrong/have broken config somewhere.
Annoying how it somewhat works on the old code but doesn’t work at all on this new code. But I need this new code haha
Can you share your code where you have the color wheel inside with the light_timer?
This code?
light_timer:
  variables:
    entity: "var_entity"
  custom_fields:
    minus:
      card:
        type: "custom:button-card"
        show_icon: true
        show_name: false
        icon: "mdi:minus"
        tap_action:
          action: call-service
          service: counter.decrement
          service_data:
            entity_id: counter.light_time
        styles:
          card:
            - border-radius: 100%
            - padding: 0
            - background: "rgba(255, 255, 255, 0.3)"
    time:
      card:
        show_icon: false
        show_name: true
        aspect_ratio: 3.5/1
        name: '[[[ return states["counter.light_time"].state + " min."; ]]]'
        tap_action:
          action: none
        styles:
          card:
            - border-radius: 1vw
            - padding: 0
          name:
            - font-size: 1vw
    plus:
      card:
        show_icon: true
        show_name: false
        icon: "mdi:plus"
        tap_action:
          service: counter.increment
          service_data:
        styles:
          card:
            - padding: 0
    OK:
      card:
        show_icon: true
        show_name: false
        icon: "mdi:play"
        tap_action:
          service: script.light_timer
          service_data:
            entity_id: "[[[ return variables.entity ]]]"
        styles:
          card:
            - padding: 0
  name: "Timer extinction"
  show_icon: false
  show_name: true
  action: none
  styles:
    grid:
      - grid-template-areas: '"n n n n n n n n n" ". minus . time . plus . OK ."'
      - grid-template-columns: 10% 10% 5% 35% 5% 10% 5% 10% 10%
      - grid-template-rows: 1fr 1fr
    card:
      - border: none
      - box-shadow: none
    name:
      - font-size: 1vw
That’s the intended behaviour.
This looks like a decluttering card or button card.
You have to have inside your visual.yaml also a code witch shows the light icon on your desk.
I can show you my code but I do not use icons. With my code you have to click on an area. (dont like icons on the light floormap :wink: ) This code is with the light wheel etc. if you hold.
If you need a icon you have to look at CDRX code. In my case there is no icon and you have to play around with the position of the area:
style:
  height: 27%
  left: 44.0%
  top: 78.5%
  width: 12.5%
This one second:
- type: custom:config-template-card
  entities:
    - light.desk
  element:
    type: image
    image: /local/transparent.png
    entity: light.desk
    tap_action:
      service: homeassistant.toggle
      service_data:
        entity_id: light.desk
    hold_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.popup
          content:
            type: custom:mod-card
            card_mod:
              style:
                layout-card$:
                  grid-layout$: |
                    :host {
                      padding: 0 !important;
                    #root {
                      margin: 0px !important;
                    #root > * {
            card:
              type: "custom:decluttering-card"
              template: light_popup_mid
              variables:
                - light: light.desk
                - name: Desk Light
          title: Desk Light
  style:
    height: 27%
    left: 44.0%
    top: 78.5%
    width: 12.5%
EDIT CORRECTED THE CODE IT WAS A WRONG ONE! So you have to have both this (above) and your code:
This one first:
    entities:
      - light.desk
    element:
      type: image
      image: /local/ui/floorplan/lights/rez/home_night_desklights_on_white.png
      entity: light.desk
      tap_action:
        action: none
      hold_action:
        action: none
    style:
      opacity: >-
        ${ ( states["light.desk"].attributes.brightness ?
        states["light.desk"].attributes.brightness / 255 : 0) -
        (states["light.desk"].attributes.hs_color ?
        states["light.desk"].attributes.hs_color[1]/255 : 0)}
      left: 50%
      top: 50%
      width: 100%
      transform: none
    entities:
      - light.desk
    element:
      type: image
      image: /local/ui/floorplan/lights/rez/home_night_desklights_on_red.png
      entity: light.desk
      tap_action:
        action: none
      hold_action:
        action: none
    style:
      filter: >-
        ${ "hue-rotate(" + (states["light.desk"].attributes.hs_color ?
        states["light.desk"].attributes.hs_color[0] : "0") + "deg)
        saturate(" + (states["light.desk"].attributes.hs_color ?
        states["light.desk"].attributes.hs_color[1] : 255)+ "%)" }
      opacity: >-
        ${ (states["light.desk"].attributes.brightness ?
        states["light.desk"].attributes.brightness / 100 : 0) *
        states["light.desk"].attributes.hs_color[1]/90 : 0) }
      left: 50%
      top: 50%
      width: 100%
      transform: none
Hmmm I’m just spitballing here, but where did you put the new code? The order of the code inside the yaml file is important, since the engine will render from the top down. That means your base image (floorplan at night) should be at the very top of your code, followed by the day image with the sun attributes. Since the engine renders from top down, your night image will be the image all the way at the back of your view, with all images coming after it rendering on top of it.
This is what I have in my light_rez.yaml (I have yet to rename)
Are you saying I need both of the codes snippets you sent in that file?
Code_4S0tM8AXPq
Inside my visual.yaml I have this for the floorplan view -
It’s pretty much at the top of my floor file. I’ve posted a quick view of my code below
Yes. Unless CDRX split it to different yaml files, I can’t tell you that.
I can try putting that code into one yaml file for now to see if it works.
What i’ve noticed is when I comment this code out
I get this result -
So it knows the image to use, just doesn’t overlay it correctly.
EDIT: putting your code into my lights_rez.yaml file in the order you mentioned doesn’t seem to do anything unfortunately
Looks like from “mix-blend-mode” you have to move everything forward by one tab. That still belongs to “style”. Should be also beneath opacity:
I’ve figured it out… I forgot to move the overlay image using the left,top adjustments…
Thank you for all your help guys! Now to get all the lights sorted!
