Floorplan UI with Color synced lights
i think i have the found the issue, apperantly i hadden’t put the - /hacsfiles/lovelace-card-mod/card-mod.js in the config.yaml.
no error anymore about the config template card, only the big slider card and the entity row, for the lights.
first trying to figure out the overlay part…
is quiet complicated how everything is connected, but loving the challange :slight_smile:
thank you for the quick response and assistance
Hi, i’m trying to learn and do a floor plan in home assistant. I started with a simple image of my apartment with all the lights off and another of a room with the light on, both same size. but I have encountered two problems
I have managed to make the brightness change in the image when I change it in the light but with each click the screen does like a quick flash.
The other problem is with the color, the code works well but the color of the image change with the right color only for some room objects and others show other different colors, very strange…
This is the code:
type: custom:config-template-card
entities:
  - light.tira_de_luz
card:
  type: picture-elements
  image: /local/home3d/casadenoche.png
  elements:
    - action: none
      type: image
      entity: light.tira_de_luz
      hold_action:
        action: none
      tap_action:
        action: none
      image: /local/home3d/casadormitorioencendido.png
      style:
        filter: >-
          ${ "hue-rotate(" + (states['light.tira_de_luz'].attributes.hs_color ?
          states['light.tira_de_luz'].attributes.hs_color[0] : 0) + "deg)"}
        opacity: >-
          ${states['light.tira_de_luz'].state === 'on' ?
          (states['light.tira_de_luz'].attributes.brightness / 255) : '0'}
        mix-blend-mode: lighten
        left: 50%
        top: 50%
        width: 100%
    - entity: light.tira_de_luz
      type: custom:button-card
      tap_action:
        action: more-info
      style:
        left: 72.5%
        top: 54.5%
Maybe I should start with something simpler but I like everything I see and I try to do it, lol
I had problems with the colors until I rendered the colored lights images as red lights and adapted the code a bit. Check my HA repo for image examples and the code.
i’ll do that, thank you. Any clue for the screen flash problem? thanks in advance
Not really, to be honest. Does it happen on every device/browser combination you use?
yes, i tried on a laptop and a tablet. The 95% of the times al the screem flash for a second when i made a change in the brightness
That’s new to me, to be honest… You might want to check the code inspector in your browser, perhaps there’s some errors there or clues as to why those flashes are happening.
I just discover that the flash is because reloads the full dashboard every time I change the brightness setting. Do not know why…
Fixed with card_mod instead of Config Template Card Card
image: /local/CasaHA/casadenoche.png
elements:
  - type: image
    image: /local/CasaHA/casadormitorioencendido.png
    tap_action:
      action: none
    hold_action:
      action: none
    style:
      transform: none
      width: 100%
      height: 100%
      top: 0
      left: 0
    card_mod:
      style: |
        :host {
          opacity: {{ (state_attr(config.entity, 'brightness') / 255) if is_state(config.entity, 'on') else 0.0 }};
          filter: {{ 'hue-rotate(' + ((state_attr(config.entity, 'hs_color')[0] - 45)|string if state_attr(config.entity, 'hs_color') else '0') + 'deg)' }};
    tap_action:
      action: more-info
    style:
      left: 72.5%
      top: 54.5%
Interesting approach! I’ll be interested in a feedback regarding performance once you’ve done all your lights!
Thnx you for the tip with the posters.
Would you share your code for emby and the sonarr and radarr part, cant get it right with the two collums :slight_smile:
Sorry don’t have the code for it any more - have ended up going through about 3 dashboards since then :rofl:
:rofl:i understand i stept in it a bit to late, i’am also keep changing my dashboard :laughing:
Got a question regarding cleaning or more regarding arrays.
So in Lukes code the cleaning is based on this input_text helper.
What do annoys me is that if I select one or more rooms in the app, it does not recognizes it.
e.g.:
state_image:
  kitchen: /local/robot/kitchen_cleaning.png
So I decided to create a sensor based on the cleaning segments of the vacuum. So I get the rooms itself. Everything works so far but!
The cleaning segments are an array. e.g.:
state_image:
  '[10]': /local/robot/kitchen_cleaning.png
So one room its pretty fine like this no 10. But if I select more than one room it look like this
[10, 5, 9, etc…]
So how can I show the image of a selected room if the no e.g. 10 is just a part of the whole array?
After a few mistakes on my side i had to restore a back up and started almost again at the beginning.
I have it almost sorted but i have no idea where to look.
For the color to represent the correct color light i need to render those lights with a red hue and white? do i do this in gimp for example or in sweet home where i made the png files?
in my weather pael it gives me a error on the apexcharts but i have those in place and working for example in the sidebar, what could this be?
view_layout:
  grid-area: main
elements:
- current: true
  details: true
  entity: weather.forecast_thuis
  forecast: true
  number_of_forecasts: 5
  card_mod:
    style: |
      :host {
        left: 50%;
        top: 30%;
        width: 90%;
        overflow: hidden;
        height: 60%;
        background: none !important;
        box-shadow: none !important;
      .current {
        margin-bottom: 7vw;
      .variations {
        margin-bottom: 4vw;
      ha-card {
        height: 100%;
        border-radius: 1vw;
        font-size: 1.2vw !important;
      .forecast{
        padding: 0 2.5%;
        width: 95%;
      .forecast .day:first-child{
        border-left: 0.1em solid #d9d9d9;
      .forecast .day:last-child{
        border-right: 0.1em solid #d9d9d9;
  type: 'custom:weather-card'
- type: 'custom:weather-chart-card'
  entity: weather.buienradar
  show_main: false
  show_current_condition: true
  show_attributes: false
  show_time: false
  show_day: false
  show_date: false
  show_humidity: true
  show_pressure: true
  show_wind_direction: true
  show_wind_speed: true
  show_sun: true
  forecast:
    precipitation_type: rainfall
    labels_font_size: '11'
    style: style2
    show_wind_forecast: true
    condition_icons: true
    round_temp: false
    type: daily
  units:
    pressure: ''
    speed: ''
  card_mod:
    style: |
      :host {
        left: 50%;
        top: 75%;
        width: 90%;
        height: 40%;
      ha-card {
        /*background: none !important;
        height: 100%;
        left: 50%;
        top: 75%;
        width: 90%;
        height: 40%;*/
- type: 'custom:apexcharts-card'
  experimental:
    color_threshold: true
  graph_span: 14d
  span:
    start: day
    offset: -7d
  now:
    show: true
    label: 'Huidig'
    color: '#ff1a1a'
  yaxis:
  - id: temp
    show: true
    apex_config:
      forceNiceScale: true
      tickAmount: 5
      decimalsInFloat: 0
  - id: rain
    show: true
    opposite: true
    apex_config:
      tickAmount: 5
      decimalsInFloat: 0
  apex_config:
    dataLabels:
      enabled: false
    chart:
      width: '100%'
      height: '100%'
    legend:
      position: top
      show: false
    grid:
      show: false
      padding:
        left: 5
        right: 20
    plotOptions:
      bar:
        columnWidth: '50%'
    xaxis:
      axisBorder:
        show: false
      axisTicks:
        show: false
      tooltip:
        enabled: false
  series:
  - entity: weather.buienradar
    type: area
    color_threshold:
    - value: -80
      color: '#03a8f4'
      opacity: 0.65
    - value: 0
      color: '#ffa31a'
      opacity: 0.65
    color: '#ffa31a'
    opacity: 0.65
    unit: °C
    attribute: temperature
    stroke_width: 0
    yaxis_id: temp
    fill_raw: last
    show:
      legend_value: false
    group_by:
      func: avg
      duration: 1h
      start_with_last: false
    extend_to: false
    type: area
    # color: '#ffa31a'
    opacity: 0.65
    color_threshold:
    - value: -80
      color: '#03a8f4'
      opacity: 0.65
    - value: 0
      color: '#ffa31a'
      opacity: 0.65
    stroke_width: 0
    yaxis_id: temp
    unit: °C
    extend_to: now
    group_by:
      func: raw
    fill_raw: last
    show:
      legend_value: false
    data_generator: |
      return entity.attributes.forecast.flatMap((entry) => {
        let noon = new Date(entry.datetime).setHours(16, 0, 0, 0);
        let midnight = new Date(entry.datetime).setHours(4, 0, 0, 0);
        return [[new Date(midnight).getTime(), entry.templow], [new Date(noon).getTime(), entry.temperature]];
  - entity: sensor.openweathermap_rain
    type: column
    yaxis_id: rain
    unit: mm
    color: '#0b0385'
    # fill_raw: last
    opacity: 0.65
    show:
      legend_value: false
    group_by:
      func: sum
      duration: 1d
  # - entity: sensor.openweathermap_snow
  #   type: column
  #   yaxis_id: rain
  #   name: 'Neige'
  #   unit: mm
  #   color: '#0cffdb'
  #   fill_raw: last
  #   show:
  #     legend_value: false
  #   group_by:
  #     func: sum
  #     duration: 1d
    type: column
    yaxis_id: rain
    color: '#0b0385'
    unit: mm
    # fill_raw: last
    opacity: 0.65
    show:
      legend_value: false
    data_generator: |
      return entity.attributes.forecast.map((entry) => {
        return [new Date(entry.datetime).setHours(24, 0, 0, 0), entry.precipitation];
  card_mod:
    style: |
      :host {
        left: 50%;
        top: 75%;
        width: 90%;
        height: 40%;
      ha-card {
        height: 100%;
      .wrapper.with-header {
        height: 100%;
      .apexcharts-tooltip {
        border: none !important;
        border-radius: 0.2vw !important;
      .apexcharts-tooltip-title {
        padding-bottom: none;
        margin-bottom: none;
      .apexcharts-xaxis-annotations > rect {
        display: none;
image: /local/Huis/Klaar/plattegrond.png
card_mod:
  style: |
    ha-card {
      background: rgba(42, 46, 48, 1);
within my media tab i have a lot of free space at the bottom , anybody an idea how i can fix it? is it correct when there is no media playing there is a empty space?
Ok, so in order of appearance:
  • I rendered my color lights as red lights in sweethome3d. I actually put red lights in my 3d model.
  • I think your apexcharts card is not installed properly or does not load for some reason. The graph in the sidebar is a mini-graph-card if you’re going based on my code (looks like it)
  • Regarding the free space: is your background picture the same size as your floorplan pictures? That may explai what you’re seeing.
thnx for the quick reply.
  • iam now precessing an image with one red light to see how it works out(last one).
    maybe not the right place to ask but i also have two led strips with color, but havent found a way yet to simulate that, do you use led strips?
  • apexcharts is finnaly working, didn’t put the map name in the url :man_facepalming: only to figure out the layout a bit,seems i"am missing data
  • within sweethome i have 2.732 with pixels and 2048 height pixel, changed the resolution of the back image to these numbers but no luck, using it for now on a ipad pro 12.9 inch ( until i have this running so i can look for cheapers ones for wall mounting).
  • and one other small question i cannot lower the battery state icon at the sidebar (person)
So does anyone have a good starting template? As in commented alot of the things that gives the errors so at least it can run without crashing?
If I understand you correctly, you are looking for a template that works right away, but you won’t find it.
Every template (Lukes or that of CDRX2) has addons, integrations (HACS) that must be installed in advance in order to be able to display it smoothly. Furthermore, you have to exchange all listed entities for your own entities and create listed scripts, automations, template_sensors etc. If an entity, script, automation or even a template_sensor is listed that you don’t have, you will also get an error message.
In short:
  • LED strips I do have. For instance the kitchen deco light in my repo is a white LED strip. I basically added a bunch of light sources to my 3d model, grouped them for easy showing/hiding and tested the renders until I was satisfied with the result.
  • Apexcharts: I’m not entirely satisfied with this myself, to be honest. The columns are ridiculously thin and there’s always an overlap for the temperature (you’d need past and future data to see both these effects). I just haven’t got around to figuring it out and since I don’t really use this part of the dashboard I don’t know if I’ll try to tackle it again.
  • Background: so if I understand correctly, your background image is now the same size as your home images but you’re still seeing that weird alignment? Two questions: have you tried it on a non-apple device/browser and what does your browser’s code inspector tell you?
  • Lowering the icon: its vertical position is defined in the decluttering template. You’ll have to look for the stateicon template in the decluttering_templates\sidebar_decluttering file.
