Floorplan UI with Color synced lights
Great work! It’s amazing!
Following your example I am very happy with my result and I attach it here to share with everyone:
I am still trying to change the color of the temperature icon based on the sensor value, but I am failing at every attempt.
If any of you guys was able to do it, I would appreciate sharing the snippet :slight_smile:
same here… :frowning:
Mark
I got your config more or less working, but got some strange issues, maybe you can give me an idea what I’m doing wrong here?
  • I have the same error as reported here: #5 Fixed with the help of @brux88
  • When I click on a light bulb the light goes on, but when I click again nothing happens?
  • When I click on the light then this is not visible in the plan, when I refresh it works
I’m not at developer so probably my stupid mistake but any help is very appreciated to get it working, thanks!
Short video to make the above a little more clear I hope :wink:
https://dmertens.stackstorage.com/s/ujdeR00KjDgArMt
Supervisor: Version | 220
HassOS: Version: | HassOS 3.13
HA: Version | 0.109.3
Thanks!
Kind regards,
Danny
Hi very strange problem, if I want to use a state icon and/or state label then nothing happens, in my previous floorplan, entity card you can see the updates but not on the version I build from your example, so probable something related to this?
Any idea what I do wrong here?
Using everywhere the same code
          - entity: binary_sensor.window_door_sensor
            style:
              left: 60%
              top: 35%
              '--iron-icon-height': 50px
              '--iron-icon-width': 50px
              '--paper-item-icon-active-color': red
            tap_action:
              action: none
            type: state-icon
A short video that makes things more clear I hope?
https://dmertens.stackstorage.com/s/YT9cPfv5axFm1sa
Thanks!
Update: State updates work fine, just forgot to add the other entities to the template card :flushed:
Hey so this sounds like it has something to do with groups or the way you are controlling the lights?
I had this issue with light groups - theres a delay for all the lights to update. So when you tap a group off, its fine, but when you tap it back on it doesnt work nicely. Are the lights single lights or a group of lights?
Hey all! Sorry have been a bit busy lately and not on the community. I havent updated to 0.109.3 yet, let me do that and get back to you and all the issues seen here, perhaps some of them are related to 109.
Thanks for your reply, to be honest the lights seem to work fine, is the window, motion, door, media… state icons, and state labels that don’t update.
The strange thing is even as I turn on the lights (light icon on the dashboard, or transparent image) then they sometimes update so looks like a background update, refresh issue or something like that?
Thanks for looking in to it, and yes I try to keep updated so now on version 0.109.6
Thanks!
I’m trying to use browser_mode.popup with ‘custom:thermostat-popup-card’ from @DBuit but I’m stuck with configuration. The Popup window is to small and I need to scroll to see the whole thermostat popup-card:
Code for this thermostate state icon in my floorplan is:
            - entity: sensor.heating_icon
              hold_action:
              #   action: more-info
                action: call-service
                service: browser_mod.popup
                service_data:
                  card:
                    cards:
                      - entities:
                          - entity: climate.heating
                            secondary_info: last-changed
                        style:
                          z-index: 5
                        type: entities
                      - cards:
                          - cards: null
                            column_height: 1
                            layout: vertical
                            type: 'custom:layout-card'
                          - entities:
                              - color_temp: false
                                header: false
                                persist_features: false
                                type: 'custom:thermostat-popup-card'
                            show_header_toggle: false
                            style:
                              height: 100%
                              z-index: 0;
                            type: entities
                        column_num: 1
                        layout: horizontal
                        max_width:
                          - 100%
                    type: 'custom:vertical-stack-in-card'
                  deviceID:
                    - this
                  style:
                    '--ha-card-border-radius': 0vw 0vw 0.8vw 0.8vw
                    border-radius: 0.8vw
                    opacity: 0.9
                  title: Tado heating
            #   icon: 'mdi:spotlight-beam'
              style:
                '--iron-icon-height': 2vw
                '--iron-icon-width': 2vw
                '--paper-item-icon-active-color': '#fae12f'
                '--paper-item-icon-color': '#525252'
                align-items: center
                background-color: 'rgba(255, 255, 255, 0.4)'
                border-radius: 100%
                box-shadow: '0px 0px 28px 0px rgba(0, 0, 0, 0.39)'
                display: flex
                height: 3vw
                justify-content: center
                left: 56.3%
                margin-left: '-1.5vw'
                margin-top: '-1.5vw'
                top: 30.5%
                transform: scale(0.7)
                width: 3vw
              tap_action:
                action: none
              type: state-icon
more or less this is the same configuration that @lukevink is using for his lightbulbs and setting the brightness and color.
Hey Luke, thanks for this great card(s). right now I’m building my own based on yours, but when I click on a light in the floorplan, the whole interface refreshes, If i watch your video, it’s not the case. Can you help me out where to search/configure?
thanks!
I think the problem might be in the styles part here:
3vw means make the height 3% of the width of the screen, which is probably pretty short! removing that style and see if that helps - or change 3vw to something like 500px.
Unfortunately not, this part is under styling of the state-icon, not the custom-thermostat-popup-card. If I increase this height to 500px or for example 30vw only this label-icon height gets bigger and ugly :smiley:
One more thing, how can I change style for homekit-panel-card. I have tried like is stated in documentation:
- type: "custom:homekit-card"
  style: |
    :host {
      --tile-background: rgba(255, 255, 255, 0.8);
      --tile-border-radius: 12px;
      --tile-width: 100px; -> this part
      --tile-height: 100px; -> this part
      --tile-on-background: rgba(255, 255, 255, 1);
      --tile-name-text-color: rgba(0, 0, 0, 0.4);
      --tile-on-name-text-color: rgba(0, 0, 0, 1);
      --tile-state-text-color: rgba(0, 0, 0, 0.4);
      --tile-on-state-text-color: rgba(0, 0, 0, 1);
      --tile-state-changed-text-color: rgb(134, 134, 134);
      --tile-unavailable-state-text-color: rgba(255, 0, 0, 1);
      --tile-value-text-color: rgba(255, 0, 0, 1);
      --tile-icon-color: rgba(0, 0, 0, 0.3);
      --tile-on-icon-color: #f7d959;
      --tile-width-mobile: 90px;
      --tile-height-mobile: 90px;
to change tile height but without any success. The problem is that on my Tablet in Fully Kiosk browser and in Kiosk mode when I enter all lights section I can’t see all the cards and I can’t scroll down…Maybe smaller homekit tile will do the trick but I can’t resize them - please see pictures:
Lovelace on my laptop:
Lovelace on my tablet:
Hi tested now also with groups and yes have the same issues, going to wait to you update the version to the latest hass version, probably best to look to 0.110.0 because there is already a beta (https://rc.home-assistant.io/blog/2020/05/20/release-110/) for more then a week and that means the roll-out is probably not so far away, and as I understand it changes again a lot of things again?
Thanks!
OK 0.110.0 is out and breaks the complete dashboard :frowning: any idea what’s the issue here?
Just updated mine…
It didn’t break the floorplan view, but the browser_mod popup is not working on the hold action. On an interesting side note, it’s working if I use the service call in the developer screen…
are you using custom header? seems that there are also some problems with, not home now but going to remove this later and test again
I am not. Just the main customization with the floorplan view.
The only thing not working is the hold action.
Ok updated to new custom header version but does not seem to fix it :weary:
I have the same problem after upgrading to 0.110.0 no lovelace card is showing. For now the only way is to debug ui-lovelace,yaml file piece by piece and find what’s causing this.
One thing that is changed for sure is style for individual lights icon. Before it was:
and now is replaced with:
'--mdc-icon-size': 2vw
Here you can see I have changed one icon like this and icon size is OK again:
This finding is from original release post on the forum…
Thanks, I already removed all my customizations, state-icons, labels and things like that but no luck for now, did you already got it working again?
@sergio_pt as you still have it working, are you willing to share your code so I can review what’s different with mine?
