hi there, (this is my first post, excuse me if i am not using correct terminology)
to everyone struggling with getting the color of the lights synced correctly. i just figured out a way that works in my setup : I changed the color values of the ‘light-on image’ using a photo editor (photoshop in my case). Proceed as follows:
change ‘hue/saturation’ values of the ‘light-on’ image
Hey long time lurker, first time poster of this thread. I’m happy to say I"m almost done with a completely new UI based on this project, but have one simple but important question: what font did you use for menu buttons? Instead of the room/group and media pages, I’m doing something different, and want to make matching buttons accordingly with the same font! I suppose I could redo all buttons in my own font but I like the one you picked. Thank you!
Hi all!!
I dont know if it’s only me, but the update to 0.113.2 seems to have broken my Floorplan card.
It seems to trace back to config-template-card.
Does anyone else have this issue?
config-template-card.js:3227 Uncaught (in promise) TypeError: Cannot read property 'state' of undefined
at eval (eval at _evaluateTemplate (config-template-card.js:3227), <anonymous>:1:36)
at HTMLElement._evaluateTemplate (config-template-card.js:3227)
at config-template-card.js:3191
at Array.forEach (<anonymous>)
at HTMLElement._evaluateConfig (config-template-card.js:3180)
at config-template-card.js:3188
at HTMLElement._evaluateArray (config-template-card.js:3205)
at config-template-card.js:3185
I have started to setup a new version based on the new config of Luke but for what I have now everything seems to work fine, lights work, media works weather works, state images, icons, badges work, … so no issues here I think
Still a very rough draft but thought I’d share mine. I wanted to create way more different tabs/views than I thought I had space for, until I came up with a simple solution: insert a down arrow so I can scroll down to reveal additional menus! I think it looks sleeker being animated. It’s easy to miss but I also had to create a 5th roborock button for the mop setting.
Are the animated rainy weather overlays working for anyone? As far as I can tell I have them in the correct order in my lovelace yaml, but didn’t see the rain animation overlay despite raining all weekend. I changed the state filter from ‘pouring’ to ‘rainy’ and confirmed it was ‘rainy’ as a current state from openweather.
The result is a white page showing nothing (also no errors) and it seems to be related to the config-template-card.
I’m using HA 0.113.3 and running lovelace in yaml mode.
all custom addons have been installed (through HACS or manually) all resources are mentioned in configuration.yaml etc…
Ugh obviously have an account but I’ve never uploaded a single thing to github before; i’ll take a look at it tonight. Please pardon my github noobness.
I did dynamic floorplan for my home assistant, but these config is on other level.
There is a guide to approch lovelace and css to create a safe environment to check config wihtout screw-up all my system?
I’m little scared to copy and paste something really I don’t understand.
Create a new dashboard in yaml mode and use that for experimenting. I have two dashboards specifically for testing out cards/elements before I add them to my ‘official’ dashboard.
Once you have everything setup and are satisfied, just use the new dashboard as the default.
