trying to use event data to get file name then file sensor to pull data i want from that file but no luck
event_type: folder_watcher
event_type: modified
path: /config/BlueLog/2023-01-20 112500.csv
file: 2023-01-20 112500.csv
folder: /config/BlueLog
origin: LOCAL
time_fired: "2023-01-20T16:26:00.134125+00:00"
context:
parent_id: null
user_id: null
input_text:
last_added_file:
name: Last added file
initial: None
i receive file name using input text method being called by automations using
alias: fwa
description: ""
- platform: event
event_data:
event_type: created
- platform: event
event_data:
condition: []
- choose:
- conditions:
- condition: trigger
- service: input_text.set_value
value: " {{ trigger.event.data.path }} "
entity_id: input_text.last_added_file
my idea was to then use that input_text for file path but it doesnt want to work
- platform: file
file_path: 'input_text.last_added_file'
value_template: '{{ value.split(",")[5] }}'
unit_of_measurement: F
