Not sure I followed everything in those flows. If you give a description of exactly what you’re trying to do and when to reset when what changes. For the Door/windows sensors, do you want those to reset the timer if one or all go to an off state? Same with the Gruppo Finestre?
[{"id":"3ef3b4de.d3155c","type":"trigger","z":"5780fdbe.51efb4","op1":"","op2":"off","op1type":"nul","op2type":"str","duration":"2","extend":false,"units":"min","reset":"on","bytopic":"all","name":"Deleyed Off","x":390,"y":160,"wires":[["b5a6fc3a.0dd98"]]},{"id":"b5a6fc3a.0dd98","type":"api-current-state","z":"5780fdbe.51efb4","name":"Stagione Invernale","version":1,"outputs":2,"halt_if":"winter,autumn","halt_if_type":"str","halt_if_compare":"includes","override_topic":true,"entity_id":"sensor.season","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":true,"x":586,"y":160,"wires":[["ea89418b.253f2"],[]]},{"id":"ea89418b.253f2","type":"api-call-service","z":"5780fdbe.51efb4","name":"Riscaldamento away","version":1,"debugenabled":false,"service_domain":"climate","service":"set_preset_mode","entityId":"climate.netatmo_cucina","data":"{\"preset_mode\":\"away\"}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":820,"y":160,"wires":[[]]},{"id":"e9d55746.cd9ad8","type":"server-state-changed","z":"5780fdbe.51efb4","name":"Finestra_Cameretta_Thermo_off","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.door_window_sensor_158d0000ed2dd2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":146,"y":64,"wires":[["3ef3b4de.d3155c","74acaa1b.517d64"],["1588e29b.5b3b8d"]]},{"id":"7326ea6f.92a014","type":"server-state-changed","z":"5780fdbe.51efb4","name":"Door/Window Sensors","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.door_window_sensor_158d0000e8bc0e,binary_sensor.door_window_sensor_158d0000f42bda,binary_sensor.door_window_sensor_158d0000e91709,binary_sensor.door_window_sensor_158d0000e8bc0e","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":116,"y":160,"wires":[["3ef3b4de.d3155c"],[]]},{"id":"73907b93.e2eb14","type":"server-state-changed","z":"5780fdbe.51efb4","name":"Gruppo Finestre","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"group.windows_view","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":96,"y":224,"wires":[["e0aa3dcb.cdcc8"],[]]},{"id":"e0aa3dcb.cdcc8","type":"trigger","z":"5780fdbe.51efb4","op1":"","op2":"off","op1type":"nul","op2type":"str","duration":"2","extend":false,"units":"min","reset":"on","bytopic":"all","name":"Deleyed Off","x":390,"y":224,"wires":[["feb6e4d1.e52448"]]},{"id":"feb6e4d1.e52448","type":"api-current-state","z":"5780fdbe.51efb4","name":"Stagione Invernale","version":1,"outputs":2,"halt_if":"winter,autumn","halt_if_type":"str","halt_if_compare":"includes","override_topic":true,"entity_id":"sensor.season","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":true,"x":586,"y":224,"wires":[["268ccd25.f33dc2"],[]]},{"id":"268ccd25.f33dc2","type":"api-call-service","z":"5780fdbe.51efb4","name":"Riscaldamento Auto","version":1,"debugenabled":false,"service_domain":"climate","service":"set_hvac_mode","entityId":"climate.netatmo_cucina","data":"{\"hvac_mode\":\"auto\"}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":820,"y":224,"wires":[[]]},{"id":"d25da0f6.763f7","type":"api-current-state","z":"5780fdbe.51efb4","name":"Stagione Invernale","version":1,"outputs":2,"halt_if":"winter,autumn","halt_if_type":"str","halt_if_compare":"includes","override_topic":false,"entity_id":"sensor.season","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":true,"x":586,"y":64,"wires":[["8005a5c.cf8a058"],[]]},{"id":"8005a5c.cf8a058","type":"api-call-service","z":"5780fdbe.51efb4","name":"Scaldino on/off","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"switch.plug_158d0001041082","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":800,"y":64,"wires":[[]]},{"id":"74acaa1b.517d64","type":"ha-wait-until","z":"5780fdbe.51efb4","name":"","outputs":2,"entityId":"binary_sensor.door_window_sensor_158d0000ed2dd2","property":"state","comparator":"is_not","value":"on","valueType":"str","timeout":"4","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":380,"y":64,"wires":[[],["d25da0f6.763f7"]]},{"id":"1588e29b.5b3b8d","type":"ha-wait-until","z":"5780fdbe.51efb4","name":"","outputs":2,"entityId":"binary_sensor.door_window_sensor_158d0000ed2dd2","property":"state","comparator":"is_not","value":"off","valueType":"str","timeout":"4","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":380,"y":112,"wires":[[],["4bfadc32.9b15a4"]]},{"id":"4bfadc32.9b15a4","type":"change","z":"5780fdbe.51efb4","name":"turn on","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"service\": \"turn_on\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":556,"y":112,"wires":[["d25da0f6.763f7"]]}]
