How is this still not implemented after 7 years? Why I can’t use for at numeric_state condition? It works with normal state check and even with the numeric state check in the trigger! Why it does not in conditions?
I would really need this and unable to find a workaround without creating unnecessary entities just for this simple specific check.
That’s about triggers. I want to check if a state has been at least x in x minutes in conditions.
I tried it with templates but that also does not work because it does not know if it was below a specific state. Probably I need to add for each check an extra binary sensor like the answer of this thread is.
Not a good solution but at least it should work.
Edit: Sorry, my fault. This is about the for check in triggers. I misread that an thought it is about that it works in trigger but not in conditions because he compared the two.
All good, so what’s your actual problem? Think about opening a new thread, this is very outdated. And feel free to tag me, I’ll be happy to jump in, if I can give a quality answer.
Sorry for necroposting, but do we have a more elegant solution for the problem in the meantime?
The previous answer is an answer - but only a workaround in my eyes.
It’s neither pretty nor intuitive and the use friendliness is pretty limited as well.
You can do for on numeric_state triggers. That’s what this feature request is about. If you want this on a condition, it’s not possible at this time.
It’s actually unlikely to ever get implemented for a condition due to the limitations of the system. It would need to traverse the database and look at all values over the specified duration. The limiting factor is that it would require users to use history and recorder, which are optional integrations.
I do understand that it’s not trivial to do that like you explained.
What I do not get: why can’t it do what is explained above in the background? Create hidden sensor or the like that.
