Force HA to use custom pyHik version
cd /config/deps
git clone GitHub - mezz64/pyHik: Python wrapper for Hikvision camera event stream
pip install -e ./pyHik
error: externally-managed-environment
× This environment is externally managed
    The system-wide python installation should be maintained using the system
    package manager (apk) only.
    If the package in question is not packaged already (and hence installable via
    "apk add py3-somepackage"), please consider installing it inside a virtual
    environment, e.g.:
    python3 -m venv /path/to/venv
    . /path/to/venv/bin/activate
    pip install mypackage
    To exit the virtual environment, run:
    deactivate
    The virtual environment is not deleted, and can be re-entered by re-sourcing
    the activate file.
    To automatically manage virtual environments, consider using pipx (from the
    pipx package).
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
I’m not sure if I should use the ‘–break-system-packages’ option with pip now?
