I have currently solved this with Elfin-EW11 within Node-RED…
I understand that this is probably not the most rational way, but it works…
Function node, for example, for generate power: return { payload: msg.payload.readInt16BE(11)/1000 }; // 11 is the buffer byte number offset
TCP in node:
Switch node for filtering messages:
Entity node:
