2t0m
(Thomas)
March 25, 2019, 3:18pm
21
Hi @stilllman and thanks for your work.
I’m running 0.90.1 and I get an error each time the freebox platform is setted up.
Error setting up platform freebox
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/__init__.py", line 174, in async_setup_platform
hass, {DOMAIN: p_config})
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/freebox/device_tracker.py", line 15, in async_get_scanner
scanner = FreeboxDeviceScanner(hass.data[DATA_FREEBOX])
KeyError: 'freebox'
Let me know if I can help.
stilllman
(Luc Touraille)
March 25, 2019, 3:53pm
22
Hey, thanks for the thanks ^^
It looks like Home Assistant is trying to initialize the device tracker before initializing the Freebox component. The great @SNoof85 has made some changes a few releases ago to start implementing new features (upload/download sensors, wifi switch, etc.), maybe you haven’t updated your configuration after the breaking change? The configuration used to be
device_tracker:
- platform: freebox
host: foobar.fbox.fr
port: 1234
but now it should be
freebox:
host: foobar.fbxos.fr
port: 1234
Let me know if this was the issue!
2t0m
(Thomas)
March 25, 2019, 4:12pm
23
I didn’t even check for news in the component configuration page. Sorry…
Of course, it’s working now !
stilllman
(Luc Touraille)
March 25, 2019, 4:24pm
24
No worries, glad I could help!
SNoof85
(Sébastien)
March 26, 2019, 8:46am
25
Hi !
If you are running hassio, i would suggest you to use the check configuration addon before any upgrade That would avoid these kind of issues if you have no time to explore all breaking changes
raomin
(Raomin)
June 18, 2020, 11:19am
26
Hello @stilllman ,
we have an issue with the mini 4k freebox.
Since my last update to 0.111.3 I’ve lost the device tracker.
2020-06-18 12:08:01 ERROR (MainThread) [homeassistant.components.upnp] Unexpected error fetching Freebox Server data: Error during async_call(), status: 500, body: <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>401</errorCode><errorDescription>Invalid Action</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
The configuration is in the right form:
freebox:
host: mafreebox.freebox.fr
port: 443
Any idea?
raomin
(Raomin)
June 18, 2020, 11:26am
27
Hmm I replaced the configuration with the external url, added all permissions to the application and now it’s working…!
Thanks for the good work btw!
SNoof85
(Sébastien)
June 18, 2020, 6:50pm
28
If you read the docs it’s clearly stated that you have to use the API domain Wich is an external address. And FYI the integration can be configured without any yaml input. You can add freebox from the frontend.
stilllman
(Luc Touraille)
June 19, 2020, 7:01am
29
@raomin Glad to hear you managed to fix your setup, and thanks @SNoof85 for following up
mgim
November 5, 2020, 8:57pm
30
Hi everyone, @stilllman ,
Does anyone know how to setup consider_home
for freebox device_tracker?
SNoof85
(Sébastien)
April 13, 2021, 8:27am
32
Hi !
I don’t have anymore any freebox at home. But normally as it’s now configured via UI the consider_home should be on the options of the freebox integration. (i’m using unifi and it’s in the integration options)
But i’m not sure it is implemented on freebox device tracker platform.
mgim
April 27, 2021, 11:32am
33
Sadly no, it’s not. No options on the Freebox integration.
flowby
September 6, 2023, 3:42pm
34
Does anyone know how to setup consider_home for freebox device_tracker?
I have exactly the same question; there are no integration options at all unfortunately
I’m contemplating editing the file .storage/core.config_entries
but i’m not very confident… Should it go into options
or data
"entry_id": "e4c70d0a632af7df51e79e2fef941cc3",
"version": 1,
"domain": "freebox",
"title": "xxxx.fbxos.fr",
"data": {
"host": "xxxx.fbxos.fr",
"port": "40244"
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "zeroconf",
"unique_id": "xxxx.fbxos.fr",
"disabled_by": null
