Frigate is using more than 90% CPU
you should be using hwaccel Hardware Acceleration | Frigate
Are you able to suggest the code change? I cant see how i can enable it with my current hardware i.e CPU
I’m not confident Hardware Accel is possible on the R2E (GCN3.0) iGPU you have. If it works, this is the section you’d follow and it gives you the code you’d need. It doesn’t seems to have much in the way of hardware codec decoding for typical security camera formats though so it may not work.
