This is how I do it. Two automations (could be one with a wait but two is fine).
Triggers can be at your discretion. One extra I use is any chances to the timer I make restart the timer. So if I turn it on, then realise I want it off longer and adjust the timer, the correct end time is used.
I also have a time remaining displayed on my dashboard.
How do I fix this? Whenever I open a notification, this shows up. The video clips shows up after waiting for a few seconds then refreshing the browser.
I created the input_boolean and timer with the same name as you. That only leaves the last entity_id for me to fill in and when I was typing it out it kinda letās me auto complete.
I was wondering , after I get the single version working, how do I turn off multiple automations with one dashboard button.
For instance I have a camera named ipc11 and one named ipc20. Some of the automations are:
ipc11_all_firetvs
ipc11_k_iphone
ipc20_all_firetvs
Can you think of what I might be doing wrong? I couldnāt find anything on google that helped. Sorry for going a little off topic.
Thanks.
Yeah, youāre right. I havenāt done the update yet. Iāll be able to apply it tonight and give the automation another go. If triggers doesnāt work, Iāll try your other suggested method. Thanks again.
I keep getting this error and its mostly for false positive detections. What can I do to filter this out in this blueprint? Frigate does not even save the snapshot or the clip since it has decided that its a āmistakeā but the blueprint still notifies me. Is this something that you can filter out with the blueprint or is it all tweaking frigate config?
Cooldown is only for new events, not updates to the existing one.
I recommend using alert once which stops audio spam. Iām surprised you would get updates to the extent youād call them spammy given update image is off by default and is the primary cause for updates. Whatās happening in the event broadly speaking?
No media could be an issue with your base url.
Depending on what your notifications setup is like you need to expand the notification to see the action buttons.
Hi! Thanks for the response. I have change the mqtt topic to frigate/review on one camera to test it out but unfortunately it did not give me notification even though frigate recognized the detection and also recorded the clip.
@SgtBatten Is there a way to get the Blueprint and subsequent automations to use the authenticated API? My instance of home assistant is public for various webhooks and what not and I donāt really want to expose the public API endpoints to the internet. Have you or anyone come up with a clever solution for that?
Is the TV notification only work for Android and FireTV? Does it work on Roku/AppleTV? What if my TVās OS is Android and I am currently watching a show with Roku Ultra, does the TV input change automatically to the android when it gets a notification from the blueprint or does it use pip? I have been checking youtube to see some examples but it looks like nobody has done it. I just want to get a notification/clip on my tv on doorbell press.
