Frigate Mobile App Notifications 2.0
Okay, i understand . I disabled the cooldown. But no success
Sorry for the many questions…
i works without zones. Is this relevant for the automation?
i activate debug, but no entry.
again, identify or show me what condition fails every time
Edit, This one
Ausgeführt: 10. November 2024 um 10:13:27
Ergebnis:
result: false
conditions/0
Ergebnis:
result: true
conditions/1
Ergebnis:
result: true entities: - automation.frigate_notifications_0_12_0_5_iphone_sebastian
conditions/2
Ergebnis:
conditions/3
Ergebnis:
conditions/4
Ergebnis:
conditions/5
Ergebnis:
result: false entities:
step configuration:
https://nopaste.net/opQLYhtWFa
This says the camera that triggered this did not match the camera you selected.
Perfect Thank so much. I add a old disconnected camera.
I just started using this blueprint, although im having issues that im getting pinged every 10th minute because of my car being a stationary object. Has anyone encountered this issue and maybe its my setup of frigate im not sure?
I am currently running Frigate 15 Beta 1 and I have been using the Frigate Notification App (0.12.0.4d). Everything works great, at least I thought it was.
I created a new automation using the 0.14.0.1g version and it alerts me when there is an alert.
However, I noticed that neither version will play the clip if I click the View Clip button. I have the base url applied correctly. The video opens chrome on my iphone and the player shows and then just shows the play button with a line through it.
What is weird is that if I copy the url that is generated for the clip, it plays perfectly on my PC. But the clip will not play in Chrome or Safari on the iphone.
The cameras are h.264.
Any ideas what to do to fix the issue? I don’t even know where to start. Like I said on the stable version, the play clips used to work.
Thinking about rolling back to Frigate 14 to test it.
I have not seen anyone else with this issue, so who knows.
Scott
Multiple people have mentioned something about frigate 0.15 and clips. Until I update to test, someone just needs to work out what’s changed.
does anyone have a script or automation setup, that automatically exports the event that triggered the notification?
My scenario is that someone breaks in and steals the server thus rendering locally stored recordings worthless.
I would love to automatically export clips from events that triggered the notification (which only happens when i’m not home)
Before I go off on a wild adventure trying to build this myself, I thought I’d ask if something like this already exists?
Would you know how to do it? Is it possible through mqtt events to automate sending photos/videos if the door opens? Or will I have to, through mqtt events, download the photos/videos, and only then can I send them a notification?
You can achieve such behavior with telegram integration. It’s implemented in the Beta config
I believe the playing of clips is broken due to ha 2024.11. There is a fix coming to try.
Fix media browser by ivanjx · Pull Request #22875 · home-assistant/frontend · GitHub
So I upgraded to frigate 14 and notifications still seem to be working on the 0.12.0.3a blueprint Im using now, where can I find the frigate 14 specific blueprint though to get the new features? thanks
I have just upgraded to Frigate 0.15.0 beta 2 to try out GenAI. I managed to get it working with Gemini, but how do I send the description in a notification? I am using the Frigate notification blueprint. It might be a simple issue, but I can’t get it to work despite hours of trying. I’ve read the documentation and understand that the information comes in a different MQTT topic. But how do I send it as a notification, including the image? I also couldn’t find anything through searching.
So next day I started getting notifications but than it stopped and it works on and off and not sure how to fix this.
Read the traces. it will tell you what it is doing
I am testing the beta version with Telegram and I do not have the action buttons.
With Home Assistant notifications the buttons are there.
EDIT: I just saw that sometimes the buttons appear in Telegram but not always, it is random
Thanks, might test it out just on my own phone separately since the frigate 12 blueprint still working on frigate 14 with no issues.
Hi All, as ever what a great blueprint!
Im testing 0.15 frigate with gen AI using a local LLM from ollama, i’d love to print the AI response for a detection directly in the blueprint message section. is this coming in a future beta?
