Frigate Mobile App Notifications 2.0
No idea mate…, have you got any other blueprints?
Yes, I have. But only one or two. They were imported just like a breeze. Mythical problems…
But now I was able to import it. Dont know what I did but it is there.
Just one thing. I dont know why it does not send me notifications with this blueprint. Not anything. No messages, no pictures, nothing. I have inserted required information (I think) to those fields. Is there a FAQ or something? Tutorial maybe?
I’m having issues with sending notifications and can’t seem to find the issue. The automation is being run correctly on frigate object detection but no notification is being sent to any of the three devices in a device group (2x iPhones and 1x Android TV). Testing the notification group in developer tools shows that the group is working. I’ve enabled logs for the automation but can’t decipher what I’m looking at to find the issue.
For what it’s worth, notifications were working for a while and then inexplicably stopped about 2 days ago.
Any help is appreciated!
Fixed it! Found what I was looking for in the logs, my automation was failing a zone check, just went ahead and disabled zone filters, and now it’s working. Seems like the automation wasn’t picking up the zones I typed in despite them matching what’s configured in Frigate.
Any support for Integration 5.0 ?
Just started trying the 0.13 Frigate beta and the 5.0 Integration, but already missing my automations that we’re blueprint based!
Thx!!
it works fine.
Yeah my bad, all my automations were disabled and I swear I saw something version related, but you are right, it still works fine!
Thx for your good work!
Not checked this thread in a while. Still using 0.12. Will need to go through the notes for upgrading to the latest version.
In the mean time, upgraded HA today and found that any frigate blueprint instances that use a defined group for notifications, stopped working.
Are you saying that, simply selecting any single notifications Device from the list, will still only allow to notify the specified group?
Yes, it always did, it’s just that device is now mandatory.
So am I, haven’t had time. But people seem to be using 0.13
0.13 is still in beta. Beta 7 is the latest. The most valuable feature is to register sound levels. This makes it usable for a babymonitor. Would be very cool if this could be something to trigger on in the future, no rush though.
The group notification works at stable version?
If yes, can we have an example of configuration.yaml?
Yes it works. There should be several in this thread
Notifications works at iwatch.
Picture appears, snooze works, but when i select to view snapshot or clip the home assistant app opens and nothing happens. There options are available at iwatch?
hi i know we went over a while back setting up this notification and having it only go off to my iphones and my sonos speakers when motion was detected in the zone i specified.
for whatever reason it has been a hit or miss, sometime it works…sometimes i get the notification on my phone but not the announcement. i missed important detection and would like to get this resolved asap. for the time being i turned the zone toggle to off and have been getting notifications on my the cams i used the bluepritn wiith (both to my phones and the annoucements). is there anyway you can tell me what settings specifically have to be toggled or the actions added to…what is the best way for me troubleshoot where the issue occurs after i do what you suggest.
thank you so much and happy and healthy new year!
Can you browse frigate on your watch?
Make the number of traces you keep larger.
Turn on debug.
Analyse the debug outputs of a trace that you think should have worked but didn’t.
That’s all anyone can do to find out why something ain’t working.
not sure how to do that, but i downloaded the trace can i send it to you?
i disabled the zone option prior and i was getting constant alerts and the acitons were working as they should have been. now i switched to zone and i only got a notification on my phone but the other action did not run
Here is a bit of a guide i threw together on getting the debug information
okay just enabled and added stored traces to the three automations i am using blueprint for.
