Frigate question- CPU usage
I mean frigate config file. I don’t use add on so not sure if camera config has UI for that in add on.
Some camera have 2 stream. HD and SD. In frigate you may add both. The detect in config is set to the detect width/height
cameras:
  driveway_cam:
    ffmpeg:
      inputs:
        #SD 1280x720
        - path: rtsp://lowres:[email protected]:554/cam/realmonitor?channel=0
          roles:
            - detect
        #HD 2840x1920
        - path: rtsp://HD:[email protected]:554/cam/realmonitor?channel=1
          roles:
            - record
    detect:
      width: 1280
      height: 720
      fps: 10
Mask tree
Will mask a tree tomorrow during the day.
Just cheeking my webui config for intercom. It support two resolutions 1280 * 780 and 1920 * 1080 and six settings for video quality.
From what you send me I should be able to switch between those two streams that are supported by the camera.
But from your file I don’t understand how to do it. My input is like this
- path: rtsp://username:password@192xxxx
Oh I think I got it. My camera does support two streams main and substream. Both stream are accessible by ffplay. To change between streams I have to use “/Streaming/Channels/101/ or 102”.
But for now I can’t set it up in frigate. I put two rtsp lines like you showed me in frigate config file but addon won’t start.
Edit:
I started addon :smiley: with two streams. Thank you for your help.
