Just a quick respond: Energy to Battery looks rock solid and the values are nearly the same as reported by the Fronius Smartmeter.
Energy from Battery Look like the values are to high. Since there is not much Sun in Austria at the Moment, my Battery does not charge really much. I’ll have a closer Look over the next few days/weeks an keep you informed.
Today was a little bit more Sun here. If more Energy get pulled out from the Battery (or the last 5% a pulled out to a lower State of Charge) it looks very good. Today there is only a difference from 0.05 kwh energy from the battery.
Did anyone switch from the Fronius platform to the Fronius integration?
I don’t know what happened in my system, but from the moment I started using the integration the solar production measure skyrocketed (wrong values and as if Wh are being interpreted as kWh).
I’m using the energy_total_fronius_inverter_1 sensor. It used to work perfectly.
This is the state for the main sensor (the one I’m using for the solar panels):
state_class: total_increasing
unit_of_measurement: Wh
device_class: energy
friendly_name: Energy total
Nonetheless, it seems that everything is working ok right now. I did not do anything, so I guess it was some kind of glitch.
The only drawback is that now both Energy total and Energy Year are way off what should be their real value. I wonder which records would I need to update on the DB to make it right.
Did you use the core Fronius integration, or the custom component before? The core integration did always report Wh afaik.
No idea how to change these things in db, but I’ve seen some posts about such here (mostly removing single entries) - you’ll surely find that info somewhere in the forums.
Hi all, I wonder if you can help. I added Fronius integration via the gui here Fronius - Home Assistant
It’s all great, I got a Symo 10.0-3-M & SolarNet device. I’m not sure why I need both. SolarNet has sensor.solarnet_power_photovoltaics which I believe is the important thing. Which seems identical to sensor.symo_10_0_3_m_1_power_ac.
I don’t care about tariffs etc.
I have solaranalytics so not the 3rd device you all have.
Seems the power_ac is electricity production, and I don’t actually have grid in/out figures. Is that right?
I can put SolarNet Energy day under Configure solar panels. ← but is this right? I don’t fully understand it. I thought it would want solarnet_power_photovoltaics somewhere.
So I can’t use Grid consumption & Return to grid which isn’t provided?
Id use “Energy total” from the inverter device, HA will do the rest for you.
The energy panel always expects energy entities.
Have a look at the integration documentation, it is listed en detail what you should configure there.
The SolarNet device is used eg. to show values calculated from multiple devices (eg. 2 inverters or a Smartmeter). If you only have one inverter you can probably ignore it.
To have grid import and export you would need a meter (eg. Fronius Smartmeter) connected to your inverter.
HA starts to count when you set up the integration and updates hourly (I think). So this was probably your production since you set up the energy panel - until the last full hour.
I have pasted your code in my configuration.yaml and amended the IPs to match mine and also implemented the slight amendment by farmio.
When checking now the sensors, I can see they are created but the state is unknown. I believe that might also be the reason why they are not available to be selected under the energy dashboard.
It is the first time I am using anything else than the UI so I am really not familiar with yaml yet (but working on it).
I have a SymoGen24 with a BYD battery and Smart Meter (sitting right behind my official meter), so I assume I have the same config as you.
Is there anything you could think of what I could have done wrong? I can ping the inverter from the Pi.
thanks (again ) for pointing me in the right direction. I’ve managed with the guide to get the data. But they are somehow not matching with what the fronius app is telling me.
HA is telling me a consumption of 9kWh. Fronius shows me about 1kWh live consumption and 16kWh total for today. The meter location is set to 0. I have tried and change it to 1 but that makes it even worse.
