That works returns - but errors
“Body” : {
“Data” : {}
“Head” : {
“RequestArguments” : {
“DataCollection” : “”,
“DeviceClass” : “Inverter”,
“DeviceId” : “”,
“Scope” : “Device”
“Status” : {
“Code” : 6,
“Reason” : “CGI-Args: Invalid parameter ‘’ for attribute ‘DataCollection’ (use ‘3PInverterData’, ‘CommonInverterData’, ‘CumulationInverterData’, ‘MinMaxInverterData’)”,
“UserMessage” : “”
“Timestamp” : “2019-07-07T17:38:25+12:00”
Was able to get info using
/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=CommonInverterData
ie removed spaces
so mine ended up being id 1 to get info
what is the syntax for setting the id device: “1” - ?
Get the below error now so getting closer
Error while setting up platform fronius
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT)
File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 416, in wait_for
return fut.result()
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/config/custom_components/fronius/sensor.py”, line 73, in setup_platform
fronius_data.update()
File “/usr/src/homeassistant/homeassistant/util/init.py”, line 224, in wrapper
result = method(*args, **kwargs)
File “/config/custom_components/fronius/sensor.py”, line 176, in update
self._data = result[‘Data’]
KeyError: ‘Data’
Make sure you use the latest code as device has changed to device_id.
In configuration.yaml
under the ip_address line with the same indent put
device_id: 1
sensor
- platform: fronius
ip_address: 192.168.0.XXX
device_id: 1
In your URL replace the URL encoded bit with an ampersand “&”
Thanks Kelvin,
Could you post the output from the URL in your browser please?
Sorry. What you’re mean with ampersand “&” ?
I added " around the IP
error
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/config/custom_components/fronius/sensor.py", line 73, in setup_platform
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 224, in wrapper
File "/config/custom_components/fronius/sensor.py", line 176, in update
self._data = result['Data']
KeyError: 'Data
output of /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=Device&DeviceId%20=1&%20DataCollection=CommonInverterData
"Body" : {
"Data" : {
"Inverters" : {
"1" : {
"DT" : 76,
"E_Day" : 20372,
"E_Total" : 9561240,
"E_Year" : 5230560.5,
"P" : 0
"Site" : {
"E_Day" : 20372,
"Meter_Location" : "unknown",
"Mode" : "produce-only",
"P_Akku" : null,
"P_Grid" : null,
"P_Load" : null,
"P_PV" : 0,
"rel_Autonomy" : null,
"rel_SelfConsumption" : null
"Version" : "11"
"Head" : {
"RequestArguments" : {},
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Timestamp" : "2019-07-07T17:03:59+10:00"
Remove the "%20"s from your URL. They are breaking it.
http://IP_ADDRESS/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=CommonInverterData
This is different to the GetPowerFlowRealtimeData.
Is that what you would prefer in the component?
That is not the sensor.
I can’t really tell from that post what your config looks like without formatting.
To test try:
sensor
- platform: fronius
device_id: 1
or again, try the correct test URL:
Here you go info from the URL, but still error in home assistant
"Body" : {
"Data" : {
"DAY_ENERGY" : {
"Unit" : "Wh",
"Value" : 1183.0999999999999
"DeviceStatus" : {
"ErrorCode" : 0,
"LEDColor" : 2,
"LEDState" : 0,
"MgmtTimerRemainingTime" : -1,
"StateToReset" : false,
"StatusCode" : 7
"FAC" : {
"Unit" : "Hz",
"Value" : 49.979999999999997
"IAC" : {
"Unit" : "A",
"Value" : 5.6799999999999997
"IDC" : {
"Unit" : "A",
"Value" : 6.9199999999999999
"PAC" : {
"Unit" : "W",
"Value" : 1304
"TOTAL_ENERGY" : {
"Unit" : "Wh",
"Value" : 12549250
"UAC" : {
"Unit" : "V",
"Value" : 229.80000000000001
"UDC" : {
"Unit" : "V",
"Value" : 227.59999999999999
"YEAR_ENERGY" : {
"Unit" : "Wh",
"Value" : 2289530.75
"Head" : {
"DataCollection" : "CommonInverterData",
"DeviceClass" : "Inverter",
"DeviceId" : "1",
"Scope" : "Device"
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Timestamp" : "2019-07-08T11:02:46+12:00"
Thanks.
Please use the latest code.
It now also defaults to deviceID 1
Note that if you want to change device id the config is now:
device_id: 1
Will try now thanks
Tried but new error now
just using basic setting in sensor
- platform: fronius
ip_address: 192.168.0.##
Log Details (ERROR)
Mon Jul 08 2019 11:18:04 GMT+1200 (NZST)
fronius: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 377, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/config/custom_components/fronius/sensor.py", line 141, in update
self._state = round(self._data.latest_data[self._json_key].get("Value"), 3)
TypeError: 'NoneType' object is not subscriptable
That’s a bit confusing.
I have removed the rounding for the values, so please try again when you are ready.
Sorry still no luck
Log Details (ERROR)
Mon Jul 08 2019 11:38:04 GMT+1200 (NZST)
File "/config/custom_components/fronius/sensor.py", line 139, in update
self._state = self._data.latest_data[self._json_key].get("Value") / 1000
this what I getting after updating it too.
Mon Jul 08 2019 09:56:40 GMT+1000 (Australian Eastern Standard Time) Invalid config for [sensor.fronius]: [device] is an invalid option for [sensor.fronius]. Check: sensor.fronius->device. (See /config/sensors.yaml, line 22). Please check the docs at https://home-assistant.io/components/sensor.fronius/ Connection lost. Reconnecting…
URL works
“Body” : {
“Data” : {
“DAY_ENERGY” : {
“Unit” : “Wh”,
“Value” : 2220.5999999999999
“DeviceStatus” : {
“ErrorCode” : 0,
“LEDColor” : 2,
“LEDState” : 0,
“MgmtTimerRemainingTime” : -1,
“StateToReset” : false,
“StatusCode” : 7
“FAC” : {
“Unit” : “Hz”,
“Value” : 50
“IAC” : {
“Unit” : “A”,
“Value” : 5.3799999999999999
“IDC” : {
“Unit” : “A”,
“Value” : 3.9199999999999999
“PAC” : {
“Unit” : “W”,
“Value” : 1312
“TOTAL_ENERGY” : {
“Unit” : “Wh”,
“Value” : 9563460
“UAC” : {
“Unit” : “V”,
“Value” : 243.80000000000001
“UDC” : {
“Unit” : “V”,
“Value” : 346.80000000000001
“YEAR_ENERGY” : {
“Unit” : “Wh”,
“Value” : 5232781.5
“Head” : {
“DataCollection” : “CommonInverterData”,
“DeviceId” : “1”,
“Scope” : “Device”
“Status” : {
“Code” : 0,
“Reason” : “”,
“UserMessage” : “”
“Timestamp” : “2019-07-08T09:48:57+10:00”
Aaron, change device to device_id in your config (or just delete that line as it defaults to 1 now).
yep don’t trhanks but Stii the same as @Kelvin_Sudlow
Mon Jul 08 2019 10:02:57 GMT+1000 (Australian Eastern Standard Time) fronius: Error on device update! Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity await entity.async_device_update(warning=False) File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 377, in async_device_update await self.hass.async_add_executor_job(self.update) File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/config/custom_components/fronius/sensor.py", line 141, in update self._state = self._data.latest_data[self._json_key].get("Value") TypeError: 'NoneType' object is not subscriptable
I don’t now much about code but was look at the rest sensors its it has .fcgi at the end.
