Fronius Solar Component
Okay, I can confirm this myself now, got it working.
It seems you added the fronius_inverter custom component, but tried to configure the fronius core integration - which doesn’t support yaml anymore.
Okay, Yes I have issues with the current setup as the data read is not always matching what it actually is.
Do you have any link to any updated components?
I only know the core integration. A link to this is here: https://www.home-assistant.io/integrations/fronius/
The custom component is querying mostly the same APIs afaik, but it’s error handling and data parsing should work differently.
Ah okay yes then I have also tested the core integration but I’m not getting (finding) enough measurements from there to be able to get a good result in the data. Most probably I have messed something up and is not able to sort it out.
What measurement are you looking for?
Can some one give me a hint or help me.
Tried to use the Fronius Integration in HA, but everytime i type in the IP Adress it says “Connection Failed”…
For newer models you’d have to enable “SolarAPI” in the inverters web interface first.
