Ok. I managed to upload the configuration to my ESP32. Unfortunately, the ESP does not connect to HA. It can connect to WIFI but only after several attempts and then it goes into SafeMode. Below are the logs:
[17:35:22]h��)�II��i����Bn� rj)ja�F�[D][wifi:481]: Starting scan...
[17:35:28][D][wifi:496]: Found networks:
[17:35:28][I][wifi:540]: - 'UP' [redacted]▂▄▆█
[17:35:28][D][wifi:541]: Channel: 6
[17:35:28][D][wifi:542]: RSSI: -48 dB
[17:35:28][I][wifi:312]: WiFi Connecting to 'UP'...
[17:35:28][W][wifi_esp32:530][arduino_events]: Event: Disconnected ssid='UP' bssid=[redacted] reason='Association Leave'
[17:35:28][W][wifi:673]: WiFi Unknown connection status 0
[17:35:28][D][wifi:696]: Retrying with hidden networks...
[17:35:28][W][wifi_esp32:530][arduino_events]: Event: Disconnected ssid='UP' bssid=[redacted] reason='Authentication Failed'
[17:35:33][I][wifi:312]: WiFi Connecting to 'UP'...
[17:35:33][W][wifi_esp32:530][arduino_events]: Event: Disconnected ssid='UP' bssid=[redacted] reason='Association Leave'
[17:35:33][W][wifi:673]: WiFi Unknown connection status 0
[17:35:33][W][wifi:689]: Restarting WiFi adapter...
[17:35:35][I][wifi:616]: WiFi Connected!
[17:35:35][C][wifi:427]: Local MAC: CC:DB:A7:3E:48:24
[17:35:35][C][wifi:432]: SSID: [redacted]
[17:35:35][C][wifi:435]: IP Address: 192.168.31.202
[17:35:35][C][wifi:439]: BSSID: [redacted]
[17:35:35][C][wifi:440]: Hostname: 'fujitsu'
[17:35:35][C][wifi:442]: Signal strength: -50 dB ▂▄▆█
[17:35:35][C][wifi:446]: Channel: 6
[17:35:35][C][wifi:447]: Subnet: 255.255.255.0
[17:35:35][C][wifi:448]: Gateway: 192.168.31.1
[17:35:35][C][wifi:449]: DNS1: 192.168.31.1
[17:35:35][C][wifi:450]: DNS2: 0.0.0.0
[17:35:35][D][wifi:625]: Disabling AP...
[17:35:35][I][app:062]: setup() finished successfully!
[17:35:35][W][safe_mode:099]: SAFE MODE IS ACTIVE
[17:35:35][W][component:170]: Component wifi cleared Warning flag
[17:35:35][I][app:100]: ESPHome version 2024.6.1 compiled on Dec 9 2024, 16:32:44
[17:35:35][C][wifi:599]: WiFi:
[17:35:35][C][logger:185]: Logger:
[17:35:35][C][logger:186]: Level: DEBUG
[17:35:35][C][logger:188]: Log Baud Rate: 115200
[17:35:35][C][logger:189]: Hardware UART: UART0
[17:35:35][C][captive_portal:088]: Captive Portal:
[17:35:35][C][mdns:115]: mDNS:
[17:35:35][C][mdns:116]: Hostname: fujitsu
[17:35:35][C][esphome.ota:073]: Over-The-Air updates:
[17:35:35][C][esphome.ota:074]: Address: fujitsu.local:3232
[17:35:35][C][esphome.ota:075]: Version: 2
[17:35:35][C][esphome.ota:078]: Password configured
[17:35:35][C][safe_mode:018]: Safe Mode:
[17:35:35][C][safe_mode:020]: Boot considered successful after 60 seconds
[17:35:35][C][safe_mode:021]: Invoke after 10 boot attempts
[17:35:35][C][safe_mode:023]: Remain in safe mode for 300 seconds
[17:35:35][W][safe_mode:031]: SAFE MODE IS ACTIVE
[17:35:58][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[17:35:58][D][esp32.preferences:114]: Saving 1 preferences to flash...
[17:35:58][D][esp32.preferences:143]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
[17:39:58][W][safe_mode:091]: Safe mode enable time has elapsed -- restarting
[17:39:58][I][app:125]: Forcing a reboot...
[17:39:59][W][wifi_esp32:530][arduino_events]: Event: Disconnected ssid='UP' bssid=[redacted] reason='Association Leave'
[17:39:59]ets Jul 29 2019 12:21:46
[17:39:59]
[17:39:59]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[17:39:59]configsip: 0, SPIWP:0xee
[17:39:59]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[17:39:59]mode:DIO, clock div:2
[17:39:59]load:0x3fff0030,len:1184
[17:39:59]load:0x40078000,len:13132
[17:39:59]load:0x40080400,len:3036
[17:39:59]entry 0x400805e4
[17:39:59][I][logger:156]: Log initialized
[17:39:59][C][safe_mode:079]: There have been 0 suspected unsuccessful boot attempts
[17:39:59][D][esp32.preferences:114]: Saving 1 preferences to flash...
[17:39:59][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[17:39:59][I][app:029]: Running through setup()...
[17:39:59][D][fuji:027]: Fuji initialized
[17:39:59][D][fuji:037]: starting task
[17:39:59][D][fuji:009][FujiTask]: reached task
[17:39:59][D][fuji:010][FujiTask]: serialTask started on core 1
[17:39:59]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[17:39:59]
[17:39:59]Core 1 register dump:
[17:39:59]PC : 0x400d300d PS : 0x00060c30 A0 : 0x800d3340 A1 : 0x3ffb5900
[17:39:59]A2 : 0x3ffb2a98 A3 : 0x3f40013a A4 : 0x0000000a A5 : 0x3f4001d8
[17:39:59]A6 : 0x00000001 A7 : 0x80000001 A8 : 0x800e217d A9 : 0x3ffb5910
[17:39:59]A10 : 0x00000000 A11 : 0x3f40013a A12 : 0x0000000a A13 : 0x3f4001d8
[17:39:59]A14 : 0x007bf0b8 A15 : 0x003fffff SAR : 0x00000004 EXCCAUSE: 0x0000001c
[17:39:59]EXCVADDR: 0x00000000 LBEG : 0x40089965 LEND : 0x40089975 LCOUNT : 0xffffffec
[17:39:59]
[17:39:59]
[17:39:59]Backtrace:0x400d300a:0x3ffb59000x400d333d:0x3ffb59a0
[17:39:59]
[17:39:59]
[17:39:59]
[17:39:59]
[17:39:59]ELF file SHA256: 0000000000000000
[17:39:59]
[17:39:59]Rebooting...
[17:39:59]
[17:40:00][I][logger:156]: Log initialized
[17:40:00][C][safe_mode:079]: There have been 1 suspected unsuccessful boot attempts
[17:40:00][D][esp32.preferences:114]: Saving 1 preferences to flash...
[17:40:00][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[17:40:00][I][app:029]: Running through setup()...
[17:40:00][D][fuji:027]: Fuji initialized
[17:40:00][D][fuji:037]: starting task
[17:40:00][D][fuji:009][FujiTask]: reached task
[17:40:00][D][fuji:010][FujiTask]: serialTask started on core 1
[17:40:00]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[17:40:00]
[17:40:00]Core 1 register dump:
[17:40:00]PC : 0x400d300d PS : 0x00060c30 A0 : 0x800d3340 A1 : 0x3ffb5900
[17:40:00]A2 : 0x3ffb2a98 A3 : 0x3f40013a A4 : 0x0000000a A5 : 0x3f4001d8
[17:40:00]A6 : 0x00000001 A7 : 0x80000001 A8 : 0x800e217d A9 : 0x3ffb5910
[17:40:00]A10 : 0x00000000 A11 : 0x3f40013a A12 : 0x0000000a A13 : 0x3f4001d8
[17:40:00]A14 : 0x007bf0b8 A15 : 0x003fffff SAR : 0x00000004 EXCCAUSE: 0x0000001c
[17:40:00]EXCVADDR: 0x00000000 LBEG : 0x40089965 LEND : 0x40089975 LCOUNT : 0xffffffec
[17:40:00]
[17:40:00]
[17:40:00]Backtrace:0x400d300a:0x3ffb59000x400d333d:0x3ffb59a0
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:00]ELF file SHA256: 0000000000000000
[17:40:00]
[17:40:00]Rebooting...
[17:40:00]ets Jul 29 2019 12:21:46
[17:40:00]
[17:40:00]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[17:40:00]configsip: 0, SPIWP:0xee
[17:40:00]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[17:40:00]mode:DIO, clock div:2
[17:40:00]load:0x3fff0030,len:1184
[17:40:00]load:0x40078000,len:13132
[17:40:00]load:0x40080400,len:3036
[17:40:00]entry 0x400805e4
[17:40:00][C][safe_mode:079]: There have been 2 suspected unsuccessful boot attempts
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:00]
[17:40:01][I][logger:156]: Log initialized
[17:40:01][C][safe_mode:079]: There have been 3 suspected unsuccessful boot attempts
[17:40:01][D][esp32.preferences:114]: Saving 1 preferences to flash...
[17:40:01][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[17:40:01][I][app:029]: Running through setup()...
[17:40:01][D][fuji:027]: Fuji initialized
[17:40:01][D][fuji:037]: starting task
[17:40:01][D][fuji:009][FujiTask]: reached task
[17:40:01][D][fuji:010][FujiTask]: serialTask started on core 1
[17:40:01]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[17:40:01]
[17:40:01]Core 1 register dump:
[17:40:01]PC : 0x400d300d PS : 0x00060c30 A0 : 0x800d3340 A1 : 0x3ffb5900
[17:40:01]A2 : 0x3ffb2a98 A3 : 0x3f40013a A4 : 0x0000000a A5 : 0x3f4001d8
[17:40:01]A6 : 0x00000001 A7 : 0x80000001 A8 : 0x800e217d A9 : 0x3ffb5910
[17:40:01]A10 : 0x00000000 A11 : 0x3f40013a A12 : 0x0000000a A13 : 0x3f4001d8
[17:40:01]A14 : 0x007bf0b8 A15 : 0x003fffff SAR : 0x00000004 EXCCAUSE: 0x0000001c
[17:40:01]EXCVADDR: 0x00000000 LBEG : 0x40089965 LEND : 0x40089975 LCOUNT : 0xffffffec
[17:40:01]
[17:40:01]
[17:40:01]Backtrace:0x400d300a:0x3ffb59000x400d333d:0x3ffb59a0
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:01]ELF file SHA256: 0000000000000000
[17:40:01]
[17:40:01]Rebooting...
[17:40:01]ets Jul 29 2019 12:21:46
[17:40:01]
[17:40:01]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[17:40:01]configsip: 0, SPIWP:0xee
[17:40:01]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[17:40:01]mode:DIO, clock div:2
[17:40:01]load:0x3fff0030,len:1184
[17:40:01]load:0x40078000,len:13132
[17:40:01]load:0x40080400,len:3036
[17:40:01]entry 0x400805e4
[17:40:01][C][safe_mode:079]: There have been 4 suspected unsuccessful boot attempts
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:01]
[17:40:02][I][logger:156]: Log initialized
[17:40:02][C][safe_mode:079]: There have been 5 suspected unsuccessful boot attempts
[17:40:02][D][esp32.preferences:114]: Saving 1 preferences to flash...
[17:40:02][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[17:40:02][I][app:029]: Running through setup()...
[17:40:02][D][fuji:027]: Fuji initialized
[17:40:02][D][fuji:037]: starting task
[17:40:02][D][fuji:009][FujiTask]: reached task
[17:40:02][D][fuji:010][FujiTask]: serialTask started on core 1
[17:40:02]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[17:40:02]
[17:40:02]Core 1 register dump:
[17:40:02]PC : 0x400d300d PS : 0x00060c30 A0 : 0x800d3340 A1 : 0x3ffb5900
[17:40:02]A2 : 0x3ffb2a98 A3 : 0x3f40013a A4 : 0x0000000a A5 : 0x3f4001d8
[17:40:02]A6 : 0x00000001 A7 : 0x80000001 A8 : 0x800e217d A9 : 0x3ffb5910
[17:40:02]A10 : 0x00000000 A11 : 0x3f40013a A12 : 0x0000000a A13 : 0x3f4001d8
[17:40:02]A14 : 0x007bf0b8 A15 : 0x003fffff SAR : 0x00000004 EXCCAUSE: 0x0000001c
[17:40:02]EXCVADDR: 0x00000000 LBEG : 0x40089965 LEND : 0x40089975 LCOUNT : 0xffffffec
[17:40:02]
[17:40:02]
[17:40:02]Backtrace:0x400d300a:0x3ffb59000x400d333d:0x3ffb59a0
[17:40:02]
[17:40:02]
[17:40:02]
[17:40:02]
[17:40:02]ELF file SHA256: 0000000000000000
[17:40:02]
[17:40:02]Rebooting...
[17:40:02]ets Jul 29 2019 12:21:46
[17:40:02]
[17:40:02]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[17:40:02]configsip: 0, SPIWP:0xee
[17:40:02]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[17:40:02]mode:DIO, clock div:2
[17:40:02]load:0x3fff0030,len:1184
[17:40:02]load:0x40078000,len:13132
[17:40:02]load:0x40080400,len:3036
[17:40:02]entry 0x400805e4
[17:40:02][C][safe_mode:079]: There have been 6 suspected unsuccessful boot attempts
[17:40:02]
[17:40:02]PC : 0x400d300d PS : 0x00060c30 A0 : 0x800d3340 A1 : 0x3ffb5990
[17:40:02]A2 : 0x3ffb2b28 A3 : 0x3f40013a A4 : 0x0000000a A5 : 0x3f4001d8
[17:40:02]A6 : 0x00000001 A7 : 0x80000001 A8 : 0x800e217d A9 : 0x3ffb59a0
[17:40:02]
[17:40:02]
[17:40:02]Backtrace:0x400d300a:0x3ffb59900x400d333d:0x3ffb5a30
[17:40:02]
[17:40:02]
[17:40:02]
[17:40:02]
[17:40:02]
[17:40:02]
[17:40:03][I][logger:156]: Log initialized
[17:40:03][C][safe_mode:079]: There have been 7 suspected unsuccessful boot attempts
[17:40:03][D][esp32.preferences:114]: Saving 1 preferences to flash...
[17:40:03][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[17:40:03][I][app:029]: Running through setup()...
[17:40:03][D][fuji:027]: Fuji initialized
[17:40:03][D][fuji:037]: starting task
[17:40:03][D][fuji:009][FujiTask]: reached task
[17:40:03][D][fuji:010][FujiTask]: serialTask started on core 1
[17:40:03]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[17:40:03]
[17:40:03]Core 1 register dump:
[17:40:03]PC : 0x400d300d PS : 0x00060e30 A0 : 0x800d3340 A1 : 0x3ffb5900
[17:40:03]A2 : 0x3ffb2a98 A3 : 0x3f40013a A4 : 0x0000000a A5 : 0x3f4001d8
[17:40:03]A6 : 0x00000001 A7 : 0x80000001 A8 : 0x800e217d A9 : 0x3ffb5910
[17:40:03]A10 : 0x00000000 A11 : 0x3f40013a A12 : 0x0000000a A13 : 0x3f4001d8
[17:40:03]A14 : 0x007bf0b8 A15 : 0x003fffff SAR : 0x00000004 EXCCAUSE: 0x0000001c
[17:40:03]EXCVADDR: 0x00000000 LBEG : 0x40089965 LEND : 0x40089975 LCOUNT : 0xffffffec
[17:40:03]
[17:40:03]
[17:40:03]Backtrace:0x400d300a:0x3ffb59000x400d333d:0x3ffb59a0
[17:40:03]
[17:40:03]
[17:40:03]
[17:40:03]
[17:40:03]ELF file SHA256: 0000000000000000
[17:40:03]
[17:40:03]Rebooting...
[17:40:03]ets Jul 29 2019 12:21:46
[17:40:03]
[17:40:03]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[17:40:03]configsip: 0, SPIWP:0xee
[17:40:03]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[17:40:03]mode:DIO, clock div:2
[17:40:03]load:0x3fff0030,len:1184
[17:40:03]load:0x40078000,len:13132
[17:40:03]load:0x40080400,len:3036
[17:40:03]entry 0x400805e4
[17:40:03][C][safe_mode:079]: There have been 8 suspected unsuccessful boot attempts
[17:40:03]
[17:40:03]PC : 0x400d300d PS : 0x00060c30 A0 : 0x800d3340 A1 : 0x3ffb5900
[17:40:03]
[17:40:03]
[17:40:03]
[17:40:03]
[17:40:03]
[17:40:03]
[17:40:03]
[17:40:03]
[17:40:04]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[17:40:04]mode:DIO, clock div:2
[17:40:04]load:0x3fff0030,len:1184
[17:40:04]load:0x40078000,len:13132
[17:40:04]load:0x40080400,len:3036
[17:40:04]entry 0x400805e4
[17:40:04][I][logger:156]: Log initialized
[17:40:04][C][safe_mode:079]: There have been 9 suspected unsuccessful boot attempts
[17:40:04][D][esp32.preferences:114]: Saving 1 preferences to flash...
[17:40:04][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[17:40:04][I][app:029]: Running through setup()...
[17:40:04][D][fuji:027]: Fuji initialized
[17:40:04][D][fuji:037]: starting task
[17:40:04][D][fuji:009][FujiTask]: reached task
[17:40:04][D][fuji:010][FujiTask]: serialTask started on core 1
[17:40:04]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[17:40:04]
[17:40:04]Core 1 register dump:
[17:40:04]PC : 0x400d300d PS : 0x00060c30 A0 : 0x800d3340 A1 : 0x3ffb5900
[17:40:04]A2 : 0x3ffb2a98 A3 : 0x3f40013a A4 : 0x0000000a A5 : 0x3f4001d8
[17:40:04]A6 : 0x00000001 A7 : 0x80000001 A8 : 0x800e217d A9 : 0x3ffb5910
[17:40:04]A10 : 0x00000000 A11 : 0x3f40013a A12 : 0x0000000a A13 : 0x3f4001d8
[17:40:04]A14 : 0x007bf0b8 A15 : 0x003fffff SAR : 0x00000004 EXCCAUSE: 0x0000001c
[17:40:04]EXCVADDR: 0x00000000 LBEG : 0x40089965 LEND : 0x40089975 LCOUNT : 0xffffffec
[17:40:04]
[17:40:04]
[17:40:04]Backtrace:0x400d300a:0x3ffb59000x400d333d:0x3ffb59a0
[17:40:04]
[17:40:04]
[17:40:04]
[17:40:04]
[17:40:04]ELF file SHA256: 0000000000000000
[17:40:04]
[17:40:04]Rebooting...
[17:40:04]ets Jul 29 2019 12:21:46
[17:40:04]
[17:40:04]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[17:40:04]configsip: 0, SPIWP:0xee
EDIT: I uploaded the single-core version and it worked. Fujitsu showed up in my devices in HA! But another problem is that I can’t turn on the air conditioning. It shows 16 degrees all the time.
Here is the ESP log:
INFO ESPHome 2024.6.1
INFO Reading configuration /config/esphome/fujitsu.yaml...
INFO Starting log output from 192.168.31.202 using esphome API
INFO Successfully connected to fujitsu @ 192.168.31.202 in 0.052s
INFO Successful handshake with fujitsu @ 192.168.31.202 in 0.098s
[18:29:49][I][app:100]: ESPHome version 2024.6.1 compiled on Dec 9 2024, 17:58:03
[18:29:49][C][wifi:599]: WiFi:
[18:29:49][C][wifi:427]: Local MAC: CC:DB:A7:3E:48:24
[18:29:49][C][wifi:432]: SSID: [redacted]
[18:29:49][C][wifi:435]: IP Address: 192.168.31.202
[18:29:50][C][wifi:439]: BSSID: [redacted]
[18:29:50][C][wifi:440]: Hostname: 'fujitsu'
[18:29:50][C][wifi:442]: Signal strength: -57 dB ▂▄▆█
[18:29:50][C][wifi:446]: Channel: 6
[18:29:50][C][wifi:447]: Subnet: 255.255.255.0
[18:29:50][C][wifi:448]: Gateway: 192.168.31.1
[18:29:50][C][wifi:449]: DNS1: 192.168.31.1
[18:29:50][C][wifi:450]: DNS2: 0.0.0.0
[18:29:50][C][logger:185]: Logger:
[18:29:50][C][logger:186]: Level: DEBUG
[18:29:50][C][logger:188]: Log Baud Rate: 115200
[18:29:50][C][logger:189]: Hardware UART: UART0
[18:29:50][C][captive_portal:088]: Captive Portal:
[18:29:50][C][mdns:115]: mDNS:
[18:29:50][C][mdns:116]: Hostname: fujitsu
[18:29:50][C][esphome.ota:073]: Over-The-Air updates:
[18:29:50][C][esphome.ota:074]: Address: fujitsu.local:3232
[18:29:50][C][esphome.ota:075]: Version: 2
[18:29:50][C][esphome.ota:078]: Password configured
[18:29:50][C][safe_mode:018]: Safe Mode:
[18:29:50][C][safe_mode:020]: Boot considered successful after 60 seconds
[18:29:50][C][safe_mode:021]: Invoke after 10 boot attempts
[18:29:50][C][safe_mode:023]: Remain in safe mode for 300 seconds
[18:29:50][W][safe_mode:029]: Last reset occurred too quickly; safe mode will be invoked in 7 restarts
[18:29:50][C][api:139]: API Server:
[18:29:50][C][api:140]: Address: fujitsu.local:6053
[18:29:50][C][api:142]: Using noise encryption: YES
[18:30:10][W][api.connection:104]: ESPHome Logs 2024.6.1 (192.168.31.3): Connection closed
[18:30:32][D][climate:011]: 'Fujitsu' - Setting
[18:30:32][D][climate:015]: Mode: HEAT
[18:30:32][D][fuji:171]: Fuji setting mode 3
[18:30:32][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[18:30:32][D][esp32.preferences:114]: Saving 1 preferences to flash...
[18:30:33][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[18:30:41][D][climate:011]: 'Fujitsu' - Setting
[18:30:41][D][climate:024]: Fan: LOW
[18:30:41][D][fuji:208]: Fuji setting fan mode 513
[18:30:43][D][climate:011]: 'Fujitsu' - Setting
[18:30:43][D][climate:040]: Target Temperature: 17.00
[18:30:43][D][fuji:191]: Fuji setting temperature 17.000000
[18:30:51][D][climate:011]: 'Fujitsu' - Setting
[18:30:51][D][climate:040]: Target Temperature: 17.00
[18:30:51][D][fuji:191]: Fuji setting temperature 17.000000
[18:30:55][D][climate:011]: 'Fujitsu' - Setting
[18:30:55][D][climate:015]: Mode: COOL
[18:30:55][D][fuji:171]: Fuji setting mode 2
[18:31:24][D][climate:011]: 'Fujitsu' - Setting
[18:31:24][D][climate:033]: Preset: ECO
[18:31:24][D][fuji:198]: Fuji setting preset 5
[18:31:26][D][climate:011]: 'Fujitsu' - Setting
[18:31:26][D][climate:033]: Preset: ECO
[18:31:26][D][fuji:198]: Fuji setting preset 5
[18:31:28][D][climate:011]: 'Fujitsu' - Setting
[18:31:28][D][climate:015]: Mode: COOL
[18:31:28][D][fuji:171]: Fuji setting mode 2
[18:31:30][D][climate:011]: 'Fujitsu' - Setting
[18:31:30][D][climate:015]: Mode: HEAT
[18:31:30][D][fuji:171]: Fuji setting mode 3
[18:31:33][D][climate:011]: 'Fujitsu' - Setting
[18:31:33][D][climate:024]: Fan: LOW
[18:31:33][D][fuji:208]: Fuji setting fan mode 513
[18:31:35][D][climate:011]: 'Fujitsu' - Setting
[18:31:35][D][climate:015]: Mode: FAN_ONLY
[18:31:35][D][fuji:171]: Fuji setting mode 4
