Tips on tablet model and apps, can you share your solution, thanks
I’m in the same boat working on an android kiosk. Actually, you can stream IP cam in Floorplan live, not just snapshot, through background-image. Quite simple really, comment out the background-color and just add some background lines to floorplan.css:
svg, svg * {
vector-effect: non-scaling-stroke !important;
pointer-events: all !important;
/* background-color: #e3e2db; */
background-image:
url(http://<ipcam1_stream_url>),
url(http://<ipcam2_stream_url>),
url(http://<ipcam3_stream_url>),
url(http://<ipcam4_stream_url>),
url(http://<ipcam5_stream_url>),
url(http://<ipcam6_stream_url>),
url(http://<ipcam7_stream_url>),
linear-gradient(to right, rgba(30, 75, 115, 1), rgba(255, 255, 255, 0));
background-size: 25% 33.4%, 25% 33.4%, 25% 33.4%, 25% 33.4%, 25% 33.4%, 25% 33.4%, 25% 33.4%, 100% 100%;
background-repeat: no-repeat, no-repeat, no-repeat, no-repeat, no-repeat, no-repeat, no-repeat, no-repeat;
background-position: top left, center left, bottom left, top center, top right, center right, bottom right, top center;
background-attachment: fixed;
linear-gradient just add the background color back with effects and you can customize the position and size of each stream ipcam.
The streaming works on my Android IP Webcam but not Amcrest cam though so YMMV.
So about Tablet Models I don’t have a unique model I work with, depends on what can I reuse from famly in the kitchen I have a Samsung Galaxy Tab3 on the wall. In my office I have a Woxter 7’’ Tablet and in my room I have a kindle.
About Apps, I mainly work with 3 apps.
- IP Cam - To stream the tablet’s cam to HASS
- Yatse - To manage kodi devices
- Squeezer - To manage the Squeezebox speakers.
solutions like this will really help me to unify the tablet requirements and secure them to avoid curiosity to break things
let me know if you want more details.
Nice think I have a play on my days off
How did you enable kiosk mode in the kindle fire? I tried and it keeps telling me to make it the default home app but not seeing anywhere to change that
can you share how
in HASSIO, anyone knows how to send curl post commands?
I use this below, but have 2 problems. 1. the switch is not working, and 2 the state I don’t know how to input the command with all the ’ " (it recognizes up to the password not the rest)
rest_command:
mi5splus_screen_on:
url: !secret mi5splus_screen_on
method: POST
mi5splus_screen_off:
url: !secret mi5splus_screen_off
method: POST
mi5splus_screen_state:
url: !secret mi5splus_screen_state
method: GET
switch:
- platform: command_line
switches:
mi5splus_screen:
command_on: switch.mi5splus_screen_on
command_off: switch.mi5splus_screen_off
command_state: switch.mi5splus_screen_state
value_template: '{{ value == "on" }}'
friendly_name: Mi5splus Screen
in secret
############## FULLY KIOSK
mi5splus_rest: http://192.168.1.50:2323/?cmd=deviceInfo&type=json&password=xxx # FULLY KIOSK
mi5splus_screen_on: 'http://192.168.1.50:2323/?cmd=screenOn&type=json&password=xxx'
mi5splus_screen_off: 'http://192.168.1.50:2323/?cmd=screenOff&type=json&password=xxx'
mi5splus_screen_state: 'http://192.168.1.50:2323/?password=xxx |grep "Screen status" |grep "on\|off" |sed "s/<[^>]*>//g" |sed "s/Screen status//g" |sed "s/Turn on//g" |sed "s/Turn off//g"'
http://192.168.1.50:2323/?password=xxx |grep “Screen status” |grep “on|off” |sed “s/<[^>]*>//g” |sed “s/Screen status//g” |sed “s/Turn on//g” |sed “s/Turn off//g”
basically this command shows in browser the fully kiosk server, and it asks for a passsword (although the password is correct)
can you explain what this is? And if possible how to put it in a rest_command
Also I am not sure how the grep command work, and how to put it in rest_command
This command in a browser works well, so it works (pretty cool!!!)
I like the idea of a nightly restart of the Kiosk. I have to look into how to do this…
Its quite simple, but I have basically created a page within HADashboard that takes the live camera feed and shows it on a page, after 30 secs reverts back to the main page of my dashboards.
An automation is kicked off then the doorbell is pressed to then kick off a script shown below.
Example of the Switch Config -
switches:
doorbelldashbedroom:
command_on: /usr/bin/curl -k "http://KisokIP:2323/?cmd=loadURL&url=http://HADashboardIP:5050/Doorbell&password=KisokPassword"
command_off: /usr/bin/curl -k "http://KioskIP:2323/?cmd=loadURL&url=http://HADashboardIP:5050/Home&password=KisokPassword"
friendly_name: Doobell Display Bedroom
Example of the Script
doorbelldashchangebedroom:
alias: Show Bedroom Camera When Doorbell Rings Bedroom
sequence:
- service: homeassistant.turn_on
entity_id:
- switch.bedroomdashwakeup
- switch.doorbelldashbedroom
- delay:
#### Show for 30 then go back to Main menu
seconds: 30
- service: homeassistant.turn_off
entity_id: switch.doorbelldashbedroom
I have an automation that turns on this switch at 5:30 each day, and then 30 secs later turns it off, I could use a toggle thinking about it.
switches:
dashrestartlanding:
command_on: /usr/bin/curl -k "http://KisokIP:2323/?cmd=restartApp&password=KisokPassword"
friendly_name: Restart Landing Dashboard App
anyone knows why I receive this error?
2018-02-07 17:32:56 ERROR (SyncWorker_8) [homeassistant.components.switch.command_line] Command failed: rest_command.mi5splus_screen_on
rest_command:
mi5splus_screen_on:
url: 'http://192.168.1.50:2323/?cmd=screenOn&type=json&password=xxx'
method: post
url: 'http://192.168.1.50:2323/?cmd=screenOff&type=json&password=xxx'
method: post
switch:
switches:
mi5splus_screen:
command_on: rest_command.mi5splus_screen_on
command_off: rest_command.mi5splus_screen_off
If I put this in a browser it works perfectly
I do it this way and it works -
switches:
diningdashwakeup:
command_on: /usr/bin/curl -k "http://KioskIP:2323/?cmd=screenOn&password=KioskPassword"
command_off: /usr/bin/curl -k "http://KioskIP:2323/?cmd=screenOff&password=KisokPassword"
friendly_name: Front Door Dashboard On
I am with HASSIO, I don’t think I can use /usr/bin/curl
I am running HASSIO and it works for me
well HASSIO in a Docker within Ubuntu Server
Try running this:
curl http://192.168.1.50:2323/?password=xxx |grep “Screen status” |grep “on|off” |sed “s/<[^>]*>//g” |sed “s/Screen status//g” |sed “s/Turn on//g” |sed “s/Turn off//g”
On the command line… If you can, post any output.
