EddieFAF
(Mathias)
January 4, 2022, 7:41am
269
I have created a template_sensor for that:
sensors:
geschirrspuler_programm:
friendly_name: Geschirrspüler Programm
value_template: >
{% if is_state('switch.geschirrspuler_program_auto1', 'on') %}
Auto1
{% elif is_state('switch.geschirrspuler_program_auto2', 'on') %}
Auto2
{% elif is_state('switch.geschirrspuler_program_auto3', 'on') %}
Auto3
{% else %}
Kein Programm
{% endif %}
icon_template: mdi:dishwasher
and one template_sensor for remaining_time:
geschirrspuler_remaining:
friendly_name: "Geschirrspüler verbleibend"
value_template: >
{% if states('sensor.geschirrspuler_operation_state') == 'Inactive' %} -
{% elif states('sensor.geschirrspuler_operation_state') == 'Finished' %} -
{% elif states('sensor.geschirrspuler_remaining_program_time') == 'unavailable' %} -
{% elif (as_timestamp(states('sensor.geschirrspuler_remaining_program_time')) - as_timestamp(now())) < 61 %} < 1 min
{% else %}
{{ (((as_timestamp(states('sensor.geschirrspuler_remaining_program_time')) - as_timestamp(now())) / 60) | round(0)) | string + " min" }}
{% endif %}
In your card you could use those sensors to display what you want.
I hope that helps.
Bojkas
January 4, 2022, 8:33am
270
This is great idea! That help. Thank you very much.
pedolsky
(Pedolsky)
January 4, 2022, 8:59am
271
Ad 1.: The only thing I see is that you mixed colon styles. But as I can see in your posted image the program is displayed with „Auto“. So what do you want to achieve?
Ad 2.: You can try a little bit slicing by using
time: |
var t = states['sensor.mycka_nadobi_remaining_program_time'].state;
var r = t.slice(11, -6);
return r
11 = cut 11 characters at the beginning = 2022-01-03T
-6 = cut 6 characters at the end = +00:00
A template sensor as suggested above is also a nice solution.
Bojkas
January 4, 2022, 9:37am
272
ad.: I wanted to get him to display the active program. It showed Auto, but it didn’t change. I used your code and it seems ok now.
ad.: I also used your original code and this new one, now I have two values.
Gaston
January 4, 2022, 1:00pm
273
Thank you for your help. I got it as I wanted.
Thank you for the hint how to insert code.
I still have to figure out how to display time in military state example 23:00 instead of 11:00 PM and how to use Sunrise and Sunset in input_datetime helper.
bolle
(Martin)
January 5, 2022, 6:49pm
274
I am using this custom buttom card - Apple homekit-lookalike card too view my light on a tablet. Is there possible to change this on/off view to brightness percent?
type: custom:button-card
entity: light.ute
hold_action:
action: more-info
icon: mdi:coach-lamp
color_type: card
show_state: true
styles:
card:
- width: 100px
- height: 100px
grid:
- grid-template-areas: '"i" "n" "s"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr min-content min-content
img_cell:
- align-self: start
- text-align: start
name:
- justify-self: start
- padding-left: 10px
- font-weight: bold
state:
state:
- value: 'off'
styles:
card:
- filter: opacity(50%)
icon:
- filter: grayscale(100%)
pedolsky
(Pedolsky)
January 5, 2022, 9:46pm
275
Yes, that’s possible:
show_label: true
label: |
if (entity.state == 'on' && entity.attributes.brightness)
return (Math.round(entity.attributes.brightness / 2.55)) + ' %';
sumur1au
(Sam M)
January 6, 2022, 8:14am
276
Is it possible to template the tap action based on state
action_button:
tap_action:
if (entity.state == ‘on’ )
return action: toggle
else
return action: none
pedolsky
(Pedolsky)
January 6, 2022, 1:55pm
277
This should do the trick:
entity: light.YOUR_LIGHT
show_name: true
name: only allow toggling if entity is on
show_state: true
tap_action:
action: |
[[[ return entity.state == 'on' ? 'toggle' : 'none' ]]]
This works for me:
tap_action:
action: |
if (states['binary_sensor.tecnoalarm_in1'].state =='off')
return 'null'
else
return 'toggle'
Note that this binary sensor is not main entitiy of my button card.
seldom
(Seldom Lee)
January 7, 2022, 11:12pm
279
To the original poster. Thank You. After much banging around I was able to take your examples and use them.
Gaston
January 7, 2022, 11:20pm
280
Here is my Lovelace custom:button-card
It is a type grid card. First is title Lebel, then the overview for 3 motion sensors.
Each sensor has 5 elements: State, a Flag (indicate if active or not), the battery level, the temperature and finally the LUX level (if available)
Here is my code in Lovelace
type: grid
cards:
- type: custom:button-card
color_type: label-card
color: rgb(44, 109, 214)
template: motion_all_attributes
variables:
var_status: binary_sensor.motion_cuisine_motion
var_battery: sensor.motion_cuisine_battery
var_actif_flag: input_boolean.cuisine_motion_flag
var_temp: sensor.motion_cuisine_temperature_measurement
var_lux: N/A
variables:
var_status: binary_sensor.philips_sml001_fef50302_occupancy
var_battery: sensor.philips_sml001_fef50302_power
var_actif_flag: input_boolean.salon_motion_flag
var_temp: sensor.philips_sml001_fef50302_temperature
var_lux: sensor.philips_sml001_fef50302_illuminance
variables:
var_status: binary_sensor.motion_mezzanine_ias_zone
var_battery: sensor.motion_mezzanine_power
var_actif_flag: input_boolean.mezzanine_motion_flag
var_temp: sensor.motion_mezzanine_temperature
var_lux: N/A
columns: 1
square: false
As you can see I am using a template with variables for each motion detector.
Here is the code in my template
motion_all_attributes:
template: container
custom_fields:
buttons:
card:
type: horizontal-stack
cards:
entity: '[[[ return variables.var_status ]]]'
show_name: false
show_state: true
entity: >-
[[[ return variables.var_actif_flag != "N/A" ?
variables.var_actif_flag : " " ]]]
tap_action:
action: toggle
label: >-
[[[ return variables.var_actif_flag == "N/A" ? "NO FLAG" :
"Actif "+ states[variables.var_actif_flag].state ]]]
show_name: false
show_label: true
show_state: true
entity: '[[[ return variables.var_battery]]]'
template: battery
entity: ' [[[ return variables.var_temp ]]]'
show_name: false
show_state: true
entity: >-
[[[ return variables.var_lux != "N/A" ? variables.var_lux : " "
label: >-
[[[ return variables.var_lux == "N/A" ? "No LUX" :
variables.var_message ]]]
show_name: false
show_state: true
show_label: true
Here is my problem;
In the section of the template where entity is set to variables_var_actif_flag. I set the LABEL as follow
label: >-
[[[ return variables.var_actif_flag == “N/A” ? “NO FLAG” :
If my variable is N/A the it return NO FLAG. If not then it return Actif with the state of the entity.
SO far so Good. First time I open Lovelace the state is correct, when I toggle the card the icon change and reflect the status but the label does not change.
Any suggestion to change the label when the entity does toggle?
pedolsky
(Pedolsky)
January 8, 2022, 10:50am
281
Add triggers_update: all to the main button card, refresh your dashboard and try again.
template: container
custom_fields:
Gaston
January 8, 2022, 1:55pm
282
Great, it works. Thank you.
should I insert this statement in all my templates or only when I set name/entity/label/state depending on variables ?
pedolsky
(Pedolsky)
January 8, 2022, 2:03pm
283
According to the documentation it’s recommended to all JS templates:
triggers_update
Bojkas
January 9, 2022, 3:15pm
284
Hello again,
I connected Hassio with the Google calendar, where I have entered waste collection. Is it possible to use a button card to sort these cards by date, give it the correct date format “dd.mm” not “mm-dd”, and add today / tomorrow or date?
Here is my code:
type: grid
cards:
entity: calendar.komunal
icon: mdi:trash-can-outline
aspect_ratio: 1/1
show_name: true
styles:
icon:
- color: black
grid:
- grid-template-areas: '"i" "date" "n"'
- grid-template-rows: 50% 1fr
name:
- font-size: 13px
custom_fields:
date:
- justify-self: null
custom_fields:
date: |
var d = states['calendar.komunal'].attributes.start_time;
var r = d.slice(-14,10);
return r
entity: calendar.bio
aspect_ratio: 1/1
color: green
styles:
icon:
- color: rgb(153, 76, 0)
grid:
name:
- font-size: 13px
custom_fields:
date:
custom_fields:
date: |
var d = states['calendar.bio'].attributes.start_time;
return r
entity: calendar.plast
aspect_ratio: 1/1
styles:
icon:
- color: rgb(240, 240, 0)
grid:
name:
- font-size: 13px
custom_fields:
date:
custom_fields:
date: |
var d = states['calendar.plast'].attributes.start_time;
return r
entity: calendar.papir
aspect_ratio: 1/1
styles:
icon:
- color: rgb(0, 128, 255)
grid:
name:
- font-size: 13px
custom_fields:
date:
custom_fields:
date: |
return r
columns: 5
square: true
@seldom , I’m glad it was helpful for you
@Bojkas , I don’t think you can sort your grid directly, but it might be possible to make a button card template that is aware of all 4 entities and sorts them by date in javascript and displays the one at an index variable, then your grid can simply define 4 instances of the template and specify the right index for each one.
There’s a custom integration for this HERE. . Check it out, maybe you’ll find it usefull. I have it installed and it works perfectly.
sumur1au
(Sam M)
January 10, 2022, 11:10pm
288
Hi All,
Can anyone help me in nesting this as a tap action based on a state condition. @pedolsky and @Protoncek many thanks, I was able to get your code to work with toggle and none but when I nest the below action I can’t get it to trigger. I think it may have to do with my indentation of the code.
tap_action:
action: fire-dom-event
browser_mod:
command: popup
title: Popup example
hide_header: true
card:
type: glance
show_state: false
entities:
- entity: button.rumpus_tab_a7_restart_browser
tap_action:
action: call-service
service: button.press
entity_id: button.rumpus_tab_a7_restart_browser
- entity: button.dining_tab_a7_restart_browser
tap_action:
entity_id: button.dining_tab_a7_restart_browser
- entity: zone.home
icon: mdi:restart
name: Home Assistant
tap_action:
service: homeassistant.restart
