Works like a charm, thank you very much!
Hey, @ktownsend-personal.
Thanks for the input, but in the end, because those buttons were actually running scripts, their states were precisely the problem… After all a script will change its state to ‘on’ when you run it, but turn back to ‘off’ the next second.
The solution I came with, even do it was quite a roundabout way, was to create two binary sensors: one for the angle the fan was and the other for the mode. Then I had to create input booleans for all the angles and modes, using those for automations that would turn on/off the input booleans according to ‘numeric state’, for the angles, and ‘state’ changes, for the modes.
Ex:
On - change to ‘30º’
Off - change from ‘30º’
…and so on.
alias: 30º angle - fan
description: ""
- platform: state
entity_id:
- sensor.fan_angle #sensor that I created to read the attribute 'angle'
to: "30" #if value change to '30'
id: "on" #automation with id trigger
enabled: true
- platform: state
entity_id:
- sensor.fan_angle
enabled: true
condition:
- condition: state
entity_id: fan.fan
state: "on" #condition - fan is on
- choose:
- conditions:
- condition: trigger
sequence:
data: {}
entity_id: input_boolean.fan_30 #input boolean for 30º
- conditions:
sequence:
- service: input_boolean.turn_off
data: {}
mode: single
Then I changed the card, adding a template relating it with the state of the input booleans.
type: vertical-stack
cards:
- type: entity
entity: fan.fan
state_color: true
attribute: percentage
unit: '%'
- type: horizontal-stack
cards:
- show_name: true
show_icon: true
type: custom:button-card
tap_action:
action: call-service
service: script.fan_30
show_state: false
color_type: card
icon: ''
state:
- operator: template
value: |
[[[ return states['input_boolean.fan_30'].state === 'on' ]]]
color: rgb(66, 134, 244)
- operator: default
color: rgb(44, 44, 44)
- show_name: true
show_icon: false
color_type: card
tap_action:
service: script.fan_60
show_state: false
icon: ''
state:
value: |
[[[ return states['input_boolean.fan_60'].state === 'on' ]]]
- operator: default
- show_name: true
show_icon: false
tap_action:
service: script.fan_90
show_state: false
color_type: card
icon: ''
state:
value: |
[[[ return states['input_boolean.fan_90'].state === 'on' ]]]
- operator: default
- show_name: true
show_icon: false
tap_action:
service: script.fan_120
show_state: false
color_type: card
icon: ''
state:
value: |
[[[ return states['input_boolean.fan_120'].state === 'on' ]]]
- operator: default
cards:
- show_name: true
show_icon: true
color_type: card
tap_action:
service: script.fan_normal
show_state: false
icon: ''
state:
value: >
[[[ return states['input_boolean.fan_normal_mode'].state === 'on'
- operator: default
color: rgb(28, 28, 28)
- show_name: true
show_icon: true
color_type: card
tap_action:
service: script.fan_breeze
show_state: false
icon: ''
state:
value: >
[[[ return states['input_boolean.fan_breeze_mode'].state === 'on'
- operator: default
Exemple - cards:
Formatting seems to be wrong after 2022.11 and the new rounded “icons”
I am putting over a white box which is just blank when the timer/machine is not running and it just looks weird now:
entity: sensor.washer_power
state_display: '[[[ return Math.round(entity.state) + " W" ]]]'
margin: none
show_name: false
show_icon: false
show_state: true
styles:
card:
- box-shadow: none
- font-size: 12px
state:
- color: |
if (states['sensor.washer_power'].state > 2)
return "red";
else
return "white";
Any idea if it can be hidden again and how?
same problem here, all cards are messed up and get a thin frame
I set ha-card-border-width: "0px"
in my theme to fix it.
How did you do that? I just have the default theme on
You can add the following to your card to hide the border.
styles:
card:
- border: none
Sweet, it works thanks.
Can also use card-mod for cards that don’t have style
- type: weather-forecast
card_mod:
style: |
ha-card {
border:none
Does anyone know whether this integration takes into account regex when templating? I have the card code below in my dashboard and it returns original entity value instead of the regex_replace string. Testing this in the template tester returns the regex_replace values correctly.
entity: binary_sensor.kippy_sade
show_state: true
show_name: false
show_icon: false
icon: mdi:paw
color: rgb(0, 150, 0)
show_entity_picture: true
entity_picture: /local/img/sade_avatar_1.png
state:
value: >
{{ states('binary_sensor.kippy_sade') | regex_replace(find="on", replace="En casa", ignorecase=False) | regex_replace(find="off", replace="Fuera", ignorecase=False) }}
styles:
state:
- font-size: 10px
card:
- height: 68px
Would someone give me a hand?
I am trying to create a reeeeally simple button-card with just the icon.
But I would like the icon to be aligned horizontally left/start and vertically middle/center.
How do I do this? I get all kinds of strange icon sizes and placement during my trial & errorrrrrr
- type: custom:button-card
entity: input_boolean.start_datetime_24h
show_label: false
show_name: false
state:
- value: 'on'
styles:
icon:
- color: white
- value: 'off'
styles:
icon:
- color: grey
Thank you
Tried playing with grid, but also to no success.
The card’s content is just not vertically centered.
Maybe I misunderstand, but wouldn’t adding this move the icon to the left and still be vertically center?
layout: icon_name_state
It is then not vertically centered, no.
I think this problem might only be visible when the card is scaled, e.g. in a grid.
Here is the full code of the vertical stack card containing a grid at the top.
Summary
cards:
- type: custom:layout-card
layout_type: grid
layout:
grid-template-columns: 3fr 1fr
grid-template-rows: auto
grid-template-areas: |
"main1 side1"
"main2 side2"
cards:
- type: custom:config-template-card
entities:
- input_boolean.start_datetime_24h
- input_datetime.start_datetime
card:
type: entities
card_mod:
style: |
:host {
--card-mod-icon-color: white;
.card-content {
padding: 0px;
entities:
- entity: input_datetime.start_datetime
icon: |-
if (states['input_boolean.start_datetime_24h'].state == 'on')
{ 'mdi:autorenew' }
else
{ 'mdi:numeric-1-box-multiple-outline' }
card_mod:
style: |
ha-date-input {
--mdc-text-field-fill-color: rgba(0, 0, 0, 0);
ha-time-input {
--mdc-select-fill-color: rgba(0, 0, 0, 0);
tap_action:
service: script.start_datetime_1h
hold_action:
service: script.start_datetime_24h
double_tap_action:
view_layout:
grid-area: main1
entities:
- input_boolean.end_datetime_now
- input_datetime.end_datetime
card:
type: entities
card_mod:
style: |
:host {
.card-content {
padding: 0px;
entities:
- entity: input_datetime.end_datetime
icon: |-
if (states['input_boolean.end_datetime_now'].state == 'on')
{ 'mdi:autorenew' }
else
{ 'mdi:update' }
card_mod:
style: |
ha-date-input {
ha-time-input {
tap_action:
service: input_boolean.toggle
entity_id: input_boolean.end_datetime_now
hold_action:
service: script.end_datetime_reset
view_layout:
grid-area: main2
show_label: false
show_name: false
show_state: true
styles:
grid:
- grid-template-areas: '"i s" "i s" "i s"'
- grid-template-rows: 1fr 1fr 1fr
- grid-template-columns: auto
icon: |
if (entity.state == 'on')
return "mdi:autorenew";
else
return "mdi:autorenew-off";
state:
- value: 'on'
styles:
icon:
- color: white
- value: 'off'
styles:
icon:
- color: grey
view_layout:
grid-area: side1
entity: input_boolean.end_datetime_now
show_label: false
show_name: false
show_state: true
styles:
grid:
icon: |
else
state:
- value: 'on'
styles:
icon:
- color: white
- value: 'off'
styles:
icon:
- color: grey
view_layout:
grid-area: side2
- type: entities
card_mod:
style: |
:host {
entities:
- entity: input_select.dropdown_wildcards
card_mod:
style:
hui-generic-entity-row $: |
state-badge {
display: none;
:host {
- entity: input_select.dropdown_entities
card_mod:
style:
state-badge {
display: none;
:host {
- entity: input_select.dropdown_areas
card_mod:
style:
state-badge {
display: none;
:host {
Looks like your code didn’t populate in your message.
How weird. Re-added the code
Thanks for the inspiration on this custom button card, I finally change the icon and layout of the button as per specific requirement. the documentation is really helpful, thanks a lot!
@Edwin_D, thanks. That’s definitely the easiest and most universal fix. It took me a while to remember to call the frontend.reload_themes
service to see the change.
I set
@williamZ that’s a nice clean and consistent look.
@williamZ Looks fantastic. How did you achieve the toggle slider in the upper right-hand corner of each box? I have searched for the answer more than I’d like to admit…
