Garbage pickup date (mijnafvalwijzer.nl) custom_component
I’m getting it finally to work with Limburg.Net !! Nice work !
Unfortunately, I’m having issues with following warning:
* Template warning: 'as_timestamp' got invalid input '03 Feb' when rendering template '{{as_timestamp(strptime(states('sensor.limburg_net_pmd'),'%d-%m-%Y'))}}' but no default was specified. Currently 'as_timestamp' will return 'None', however this template will fail to render in Home Assistant core 2022.1
Could you maybe have a look ?
Thanks in advance !
Kr,
Bart
Hey Bart , the warning speaks for itself. You need top set defaults on the as_timestamp.
check Updating Templates with the new default values in 2021.10.x on how to do that.
Hi, this question might have been asked ad nauseam here,
but can anyone point me to the location of the image files in this genre:
gft3
glas
kca
For glass an nothing i can only find the 6767 icons…
I’m looking for the 300
300 ones in the same style
Hi I’m new in the Homeassistant world.
In have Hacs installed and the afvalwijzer.
I got the sensors working
But how do i get the nice looks with pictures?
Fontend installed
  • Button-card
  • Auto-entities
  • Mini-grap-card
I’ve just started using this addon and use the following in my dashboard:
type: horizontal-stack
title: Afvalophaling
cards:
  - type: picture-entity
    entity: sensor.recycleapp_afvalophaling_vandaag
    state_image:
      gft: /local/gft.png
      papier: /local/papier.png
      restafval: /local/rest.png
      plastic verpakkingsafval: /local/pmd.png
      Geen: /local/geen2.png
      restafval, papier: /local/papier_rest.png
    entity: sensor.recycleapp_afvalophaling_morgen
    state_image:
      gft: /local/gft.png
which results in the following:
the refferences to /local go to the config/www folder
After a restart my Afvalwijzer doesn’t work anymore. I got an error message saying the ‘include_date_today’ parameter isn’t known. Strange, but disabling it in configuration.yaml made the error go away.
However, I don’t get any info anymore for the different pickup dates: it just says Unknown. Were there any changes I’m not aware of? Or is the service down?
Found the cause: include_date_today has been renamed to exclude_pickup_today. Changed it in configuration.yaml.
Can you post the yaml for that card ??
did you try and find it above? its posted a few times…
Today I tried to setup this integration but I ran into the following error which I can’t get my head around without any help of you:
Source: custom_components/afvalwijzer/collector/mijnafvalwijzer.py:76
Integration: Sensor (documentation, issues)
First occurred: 16:13:27 (1 occurrences)
Last logged: 16:13:27
Error while setting up afvalwijzer platform for sensor
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform
    await asyncio.shield(task)
  File "/config/custom_components/afvalwijzer/sensor.py", line 69, in async_setup_platform
    collector = await hass.async_add_executor_job(
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/config/custom_components/afvalwijzer/collector/mijnafvalwijzer.py", line 47, in __init__
    ) = self.get_waste_data_provider()
  File "/config/custom_components/afvalwijzer/collector/mijnafvalwijzer.py", line 76, in get_waste_data_provider
    json_response["ophaaldagen"]["data"]
KeyError: 'ophaaldagen'
I can’t find/see the sensors in my developer tools either.
What can be the case?
Could someone help me to set up afvalwijzer? I’ts pretty difficult…
show us what you did and what happened?
For those interested in using Node-RED instead of Home Assistant automations and Template Sensors, I shared and explained my setup here: Afvalwijzer automation with Node-RED
It is, I’ve given up as well and seeing the last meaningful post was months ago, I am not the only one.
This thread is riddled with questions that do not seem to get answered.
I’d love to have just a quick manual for the basic configuration, but the github page is messy, just snippets of code without context.
I suggest you move on and find a better solution. I am currently looking at GitHub - pippyn/Home-Assistant-Sensor-Afvalbeheer: Provides Home Assistant sensors for multiple Dutch and Belgium waste collectors
The place where I live is connected to afvalwijzer and not afvalbeheer. Thanks for the suggestion though.
I don’t know how to add (and where to find) the images to the lovelace dashboard. I do see pick-up dates at the moment.
the images are scattered around in this thread, did you search for them at all? try image in the search box…\
also, they are in the authors GitHub repo . and you can ofc add your own images if you like, there’s no such thing as The images.
if you save the images you like in a map in eg /config/www/images/afvalwijzer , you can reference then in the lovelace cards and use /local/images/afvalwijzer
Thank you for your fast reply. I downloaded the files from HACS, so as far as I can see it downloaded everything from GitHub, so also the full repo. But I don’t know how to add the images to the lovelace card.
For now it looks like this (without the brown bar ofc):
see eg: Garbage pickup date (mijnafvalwijzer.nl) custom_component - #633 by Mariusthvdb
Hi @xirixiz
somehow Garbage pickup date (mijnafvalwijzer.nl) custom_component - #516 by niekniek89 was marked as solution to this thread, causing this:
to popup every time someone posts here. Since this is a general topic, I dont think that solution mark is appropriate and in fact rather annoying…
can you un-solve this? or would the poster in that thread need to do that
