Many thanks @Mariusthvdb!
Much to learn I guess… ;o))
Cheers Herman.
Hi @Mariusthvdb,
I did try to implement the packages as you advised. Unfortunately, I’m getting the following error.
Of course, first I excluded the other imported scripts like sensor, templates, customize, etc.
Any suggestions?
Regards, Herman
please post your configuration.yaml, and show a screenshot of the /config showing the map for the packages?
it should be something like
/config/packages/afvalwijzer_backend.yaml
and inside that package just list all integrations a top, so you would need
script:
template:
automation:
inside that
Here you go.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Example configuration.yaml entry
frontend:
themes: !include_dir_merge_named themes
sensor: !include sensors.yaml
template: !include templates.yaml
homeassistant:
# customize: !include customize.yaml
packages: !include_dir_named packages
And the package ?
And the Config/packages config.
The scripts.yaml, template.yaml, and automation.yaml contain no code for ‘Afvalwijzer’ anymore.
The package provide by you
## AfvalWijzer Custom Component
## created by @xirixiz, more info on https://github.com/xirixiz/home-assistant-config
## https://community.home-assistant.io/t/garbage-pickup-date-mijnafvalwijzer-nl-custom-component/34631
# @mariusthvdb
# Customize
homeassistant:
customize:
sensor.afvalwijzer_vandaag: &afval
hide_attributes: templates
templates:
entity_picture: >
var path = '/local/afvalwijzer/';
var ext = '.png';
var type = ['papier','gft','plastic','restafval'];
return type.includes(state) ? path + state + ext : path + 'kliko_geen' + ext;
sensor.afvalwijzer_morgen: *afval
sensor.afvalwijzer_overmorgen: *afval
# niet in frontend
# sensor.afvalwijzer_next_in_days:
# hide_attributes: templates
# templates:
# icon: >
# if (state === 'Geen') return 'mdi:calendar-question';
# var items = ['1','2','3','4','5','6','7','8','9'];
# if (items.includes(state))
# return 'mdi:numeric-' + state + '-box-multiple-outline';
# return 'mdi:help';
# Sensors
- platform: afvalwijzer
provider: rd4
postal_code: 9999ab
street_number: 99
# Templates
template:
- trigger:
- platform: homeassistant
event: start
- platform: time_pattern
hours: '/1'
- unique_id: trash_alert
state: >-
{% if has_value('sensor.afvalwijzer_morgen') or
has_value('sensor.afvalwijzer_vandaag') %}
{%- if states('sensor.afvalwijzer_morgen') != 'geen' and
states('input_boolean.afval_morgen_notificatie') == 'on'%}
Afval: {{states('sensor.afvalwijzer_morgen')|title}} wordt morgen opgehaald
{%- elif states('sensor.afvalwijzer_vandaag') != 'geen'%}
Afval: {{states('sensor.afvalwijzer_vandaag')|title}} wordt vandaag opgehaald
{%- else -%} Geen afval alert
{%- endif -%}
{% else %} Geen sensors gemaakt
{% endif %}
- unique_id: trash_next_icon
state: >
{% set days = states('sensor.afvalwijzer_next_in_days') %}
{% if days != 'geen' %}
{% if days|int <= 9 %} mdi:numeric-{{days}}-box-multiple-outline
{% else %} mdi:numeric-9-plus-box-multiple-outline
{% endif%}
{% else %} mdi:checkbox-blank-outline
{% endif %}
- unique_id: trash_next_color
state: >
{% set next = states('sensor.afvalwijzer_next_type') %}
{% set colors = {'papier':'deepskyblue','gft':'darkgreen',
'plastic':'orange','restafval':'black'} %}
{{colors.get(next,'grey')}}
- unique_id: trash_color
state: >
{% set vandaag = states('sensor.afvalwijzer_vandaag') %}
{{colors.get(vandaag,'grey')}}
- unique_id: volgende_afval_ophaal_dag
state: >
{%- set next = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),
'%d-%m-%Y',none),none) %}
{% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli',
'Augustus','September','Oktober','November','December'] %}
{%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag',
'Vrijdag','Zaterdag'] %}
{%- set wday = next|timestamp_custom('%w',default=none)|int(default=0) %}
{%- set month = next|timestamp_custom('%m',default=none)|int(default=0) %}
{{next|timestamp_custom(wdays[wday] ~ ' %-d ' ~ months[month-1],default=none)}}
- binary_sensor:
- unique_id: afval_notificatie
state: >
{{is_state('input_boolean.afval_vandaag_notificatie','on') or
is_state('input_boolean.afval_morgen_notificatie','on')}}
- unique_id: saver_offline
state: >
{{states.sensor.afvalwijzer_vandaag is none}}
device_class: problem
# Scripts
script:
notify_trash_today:
mode: restart
sequence:
- condition: state
entity_id: input_boolean.notify_utility
state: 'on'
- service: notify.notify
title: >
{{states('sensor.vandaag').split('dag ')[1]}}: Afval vandaag
message: >
{{states('sensor.afvalwijzer_vandaag')|title}} wordt vandaag opgehaald!
persistent_trash_today:
mode: restart
sequence:
- condition: state
entity_id: input_boolean.persistent_notification_create
state: 'on'
- service: persistent_notification.create
notification_id: afval_vandaag_notificatie
title: >
message: >
entity_id: input_boolean.afval_vandaag_notificatie
notify_trash_tomorrow:
mode: restart
sequence:
- condition: state
state: 'on'
title: >
{{states('sensor.vandaag').split('dag ')[1]}}: Afval morgen
message: >
{{states('sensor.afvalwijzer_morgen')|title}} wordt morgen opgehaald!
persistent_trash_tomorrow:
mode: restart
sequence:
- condition: state
state: 'on'
notification_id: afval_morgen_notificatie
title: >
message: >
entity_id: input_boolean.afval_morgen_notificatie
trash_outside_tomorrow:
mode: restart
sequence:
- condition: state
entity_id: input_boolean.afval_staat_voor
state: 'off'
- condition: state
entity_id: input_boolean.afval_reminder
state: 'on'
- service: notify.mobile_app_marijn
title: iOS notification
message: >
{% set title = states('sensor.afvalwijzer_morgen')|title %}
{{title}} wordt morgen opgehaald, zet het afval aan de straat
actions:
- action: MARK_TRASH_MOVED
title: Afval verwerkt
destructive: true
push:
badge: 5
sound: US-EN-Morgan-Freeman-Cleaning-Supplies-Closet-Opened.wav
trash_outside_today:
mode: restart
sequence:
- condition: state
state: 'off'
- condition: state
state: 'on'
message: >
{% set title = states('sensor.afvalwijzer_vandaag')|title %}
{{title}} wordt vandaag opgehaald, zet het afval aan de straat
actions:
destructive: true
push:
badge: 5
action_data:
# Automations
automation:
- id: saver_offline
platform: state
entity_id: binary_sensor.saver_offline
to: 'on'
notification_id: saver_notificatie
title: Saver melding
message: >
{{now().strftime('%d %B')}}: Saver is Offline
- service: script.intercom_message
message_nl: >
Het is {{states('sensor.vandaag').split('dag ')[1]}}:
Saver is Offline, geen data voor Home Assistant
message_en: >
Today is {{now().strftime('%A %-d %B')}}:
Saver is Offline and experiencing issues, no data provided to Home Assistant
# Vandaag moet het afval worden voorgezet
- id: afval_vandaag
platform: time
at: '07:00'
condition:
{{has_value('sensor.afvalwijzer_vandaag')}}
- not:
condition: state
entity_id: sensor.afvalwijzer_vandaag
state: geen
message_nl: >
{{states('sensor.vandaag').split('dag ')[1]}}: vandaag wordt {{vandaag}} opgehaald!
message_en: >
{% set today = states('sensor.afvalwijzer_vandaag') %}
{{now().strftime('%A %-d %B')}}: today {{today}} will be collected!
- service: script.persistent_trash_today
- service: script.trash_outside_today
# Morgen moet het afval worden voorgezet
- id: afval_morgen
platform: time
at: '21:00'
condition:
{{has_value('sensor.afvalwijzer_morgen')}}
- not:
condition: state
entity_id: sensor.afvalwijzer_morgen
state: geen
message_nl: >
Het is {{states('sensor.vandaag').split('dag ')[1]}}: Morgen wordt
{{states('sensor.afvalwijzer_morgen')|title}} opgehaald!
message_en: >
Today is {{now().strftime('%d %B')}}: Tomorrow
{{states('sensor.afvalwijzer_morgen')|title}} will be picked up!
- service: script.persistent_trash_tomorrow
- service: script.trash_outside_tomorrow
- id: reset_trash_notification
platform: state
to: 'on'
for:
hours: 5
service: input_boolean.turn_off
- id: reset_trash_notification_today
platform: state
to: geen
condition:
condition: state
state: 'on'
- service: persistent_notification.dismiss
- service: input_boolean.turn_off
- id: reset_trash_notification_tomorrow
platform: state
to: geen
condition:
condition: state
state: 'on'
- id: dismiss_afval_notificatie
- platform: persistent_notification
update_type: removed
condition:
or:
- condition: state
state: 'on'
- condition: state
state: 'on'
entity_id: >
input_boolean.{{trigger.notification.notification_id}}
message: Afval staat aan de straat
push:
badge: 0
sound: >
US-EN-Morgan-Freeman-Good-{{(states('sensor.part_of_day')
in ['Morning','Afternoon'])|iif('Morning','Night')}}.wav
- id: mark_trash_as_moved_outside_from_notification
platform: event
event_type: mobile_app_notification_action
event_data:
notification_id: >
afval_{{is_state('input_boolean.afval_vandaag_notificatie','on')
|iif('vandaag','morgen')}}_notificatie
entity_id: >
input_boolean.afval_{{is_state('input_boolean.afval_vandaag_notificatie','on')
push:
badge: 0
sound: >
How odd, looks good
If you take out the package from the config, and do config check, does it still error?
Btw please edit your postcode
"If you take out the package from the config, and do config check, does it still error?"
Not exactly know hoe to do that with one separate file
Postcode should be lowercase like 9999ab?
From the point I can judge, only the automations and scripts are not working. See previous screenshot.
What could have happened is that your automations have different object_id s and because of that don’t list as in the card.
Check dev tools /state for automation.automation_xxx where xxx will be a number.
If that is the case, you can simply change that object_id to the id of the automation and you should be good
I believe the card also shows the sensor.vandaag not to be created . Might be the same issue, as template integration auto adds ‘template’ in that object_id.
Again, simply edit that away.
As for your postcode: I meant you posted your actual postcode and you should not ….
Scripts: those should really be ok, so I am not sure what happened there .
The error you posted seems to indicate some top level hierarchy being incorrect .
Please check your indenting carefully, because if the yaml is off at some point, the checker will error with these types of warnings .
The beauty of packages is just that you can take out the file completely and then check the remaining config.
Just open the config directory in your file browser and take it out and store it somewhere you can drag it back from
Starting to be a bit frustrated! Now the whole card doesn’t function anymore :o( just suddenly after checking 1 hour later or so…
this is going to go far beyond the topic of this thread, so I suggest you open a new and dedicated topic, on how to install a package.
The package I have should be a drop in, and all in it should just work. I cant imagine what could be wrong now, but we need to take it a step back and go from there to build it up again.
also, you need to make sure you can easily edit files (preferably outside of HA, so you are not depending on a working frontend for that), and you can manipulate files over your network (preferably with something like SMB add-on, again so your are not depending on the frontend )
lets go there and Ill be glad to assist you further
You are right. Start a new topic next week.
For now I did start over by taking out the package and cleanup all the sensors. After putting the package back again it looks like the card is working partially.
See you on the other side.
Thank for al the help so far!
The majority of the ‘Automaten’ seem to be working. However, I can’t seem to get the two ‘input booleans’ to work. I’ve looked for incorrect ‘IDs.’ I’ve looked for incorrect naming. Unfortunately, I can’t pinpoint the error. I’m using a ‘Package’ where all the code resides. Thanks to @Mariusthvdb for all the support in this!
Any ideas?
The backend code of the 'Package"
# @mariusthvdb
# Customize
homeassistant:
customize:
sensor.afvalwijzer_gft:
friendly_name: GFT
sensor.afvalwijzer_papier:
friendly_name: Papier
sensor.afvalwijzer_restafval:
friendly_name: Restafval
sensor.afvalwijzer_pmd:
friendly_name: PMD
sensor.afvalwijzer_best_tas:
friendly_name: Best-tas
sensor.afvalwijzer_snoeiafval:
friendly_name: Snoeiafval
templates:
entity_picture: >
var ext = '.png';
var type = ['restafval','gft','papier','pmd','best_tas','snoeiafval'];
return type.includes(state) ? path + state + ext : path + 'geen' + ext;
# niet in frontend
# templates:
# icon: >
# Sensors
provider: rd4
postal_code: 6369hj
street_number: 33
# Templates
template:
- trigger:
event: start
hours: '/1'
state: >-
{%- endif -%}
{% endif %}
state: >
{% endif%}
{% endif %}
state: >
'pmd':'orange','restafval':'black'} %}
state: >
- unique_id: today_date
state: >
{%- set now = as_timestamp(now()) %}
{%- set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli',
{%- set weekdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag',
{%- set weekday = now|timestamp_custom('%w',default=none)|int(default=0) -%}
{%- set month = now|timestamp_custom('%m',default=none)|int(default=0) -%}
{%- set date = now|timestamp_custom(weekdays[weekday] ~ ' %-d ' ~ months[month-1]) -%}
{{- date -}}
state: >
- binary_sensor:
state: >
state: >
# Scripts
script:
notify_trash_today:
mode: restart
sequence:
- condition: state
state: 'on'
title: >
message: >
mode: restart
sequence:
- condition: state
state: 'on'
title: >
message: >
mode: restart
sequence:
- condition: state
state: 'on'
title: >
message: >
mode: restart
sequence:
- condition: state
state: 'on'
title: >
message: >
mode: restart
sequence:
- condition: state
state: 'off'
- condition: state
state: 'on'
message: >
actions:
destructive: true
push:
badge: 5
mode: restart
sequence:
- condition: state
state: 'off'
- condition: state
state: 'on'
message: >
actions:
destructive: true
push:
badge: 5
action_data:
# Automations
automation:
- id: saver_offline
platform: state
to: 'on'
message: >
message_nl: >
message_en: >
- id: afval_vandaag
platform: time
at: '07:00'
condition:
- not:
condition: state
state: geen
message_nl: >
message_en: >
- id: afval_morgen
platform: time
at: '21:00'
condition:
- not:
condition: state
state: geen
message_nl: >
message_en: >
platform: state
to: 'on'
for:
hours: 5
platform: state
to: geen
condition:
condition: state
state: 'on'
platform: state
to: geen
condition:
condition: state
state: 'on'
condition:
or:
- condition: state
state: 'on'
- condition: state
state: 'on'
entity_id: >
push:
badge: 0
sound: >
platform: event
event_data:
notification_id: >
entity_id: >
push:
badge: 0
sound: >
All of my Boolean’s are created in the Ui helper section …
They are not in the yaml package
Seven days ago, you told me that everything is in the ‘backend script’ and that it should work straightforwardly. I’ve mentioned multiple times that I’m not a programmer. Therefore, it’s sometimes challenging for me to connect the dots. I’m doing my best.
Is it possible to post the YAML of the helpers?
It looks like I’ve probably figured out how it works. After some “Googling” and watching “YouTube” videos, it seems like I’ve got it. Now, let’s see if we can also create a nice Dutch text from it.
Already said we need to take a step back… this it part of that.
There is no yaml of these helpers (well technically there is but we don’t use that) . You simple create it in the helper section . In Dutch it is a schakelaar.
Can you have a go at that? Just take care they use the same name as the object id
Edit
We cross posted … cool
Sometimes, I can be a bit like a pitbull when I really want to get something working. Sorry if I come across as impatient then.
Is it possible to provide the “Automaten” with a Dutch text? Perhaps something like a “Friendly name”?"
