currently I test the Gardene Bluetooth Integration together with a Raspberry Pi 3 (rpi3-64). The Bluethooth connection is unstable or breaks off completly. The only solotion here is to reboot the Raspberry PI. I tested the internal Bluetooth device and a TP-Link UB500 adapter. Both devices having the same issue, but the TP-Link UB500 adapter seams to be more stable.
Connected are two Gardena Water Control Bluetooth Devices 01889-20.
Is this a know issue? Does anybode have the same experience?
If your setup is stable, what devices are you using.
thanks for the tip. A 2m USB cable seems to improve the stability. Test is running since 10h without interruption. I’ll let the test continue and will report back as soon as I know more.
Unfortunately Bluetooth signals are affected by so many other devices(which we love). WiFi 2.4GHz, in my opinion, conflicts the most.
Heck, even microwaves and fluorescent lighting emit 2.4GHz frequencies. The dongle is a great suggestion.
I’d also look at the BT device’s dBi. I struggled with BT SwitchBot curtain devices and an cheap upgrade to a slightly stronger BT adapter fixed the dropped signal issues.
@LiQuid_cOOled ,
many thanks for your response. Reception shouldn’t be a problem. The devices are located right next to each other in a separate room. However, WiFi or cell phones can of course be disruptive.
@Sir_Goodenough
With the additional USB cable, the connection is more stable, but it breaks off again after a long time. Unfortunately, the connection is not re-established on its own. The only thing that helps here is a restart.
I will now try get an ESP Bluetooth proxy and continue testing with it.
Please consider marking my post with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
