Gecko in.touch2 integration (Spa wireless remote control module)
It’s changed a bit since that post:
YAML for right hand card
type: entities
entities:
  - entity: input_datetime.pm_on_time
    name: Boost On Time
  - entity: input_number.pm_on_temp
    name: Evening Temperature
  - entity: input_datetime.pm_off_time
    name: Boost Off Time
  - entity: automation.pm_setpoint_change_1
    name: Enable Evening Boost On
  - entity: automation.pm_setpoint_2
    name: Enable Evening Boost Off
  - entity: automation.heat_boost_on
    name: Enable Octopus Overnight Heat On
  - entity: automation.heat_boost_off
    name: Enable Octopus Overnight Heat Off
  - entity: input_datetime.octopus_on_time
    name: Time to Start Octopus Heating
  - entity: input_number.octopus_on_temp
    name: Target temperature
There are 4 automations that change the setpoint. 2 for the overnight heat, 2 for the afternoon boost. The high temperatures are settable, along with the on-off times for the afternoon boost and finally the on-time for the overnight boost. This is because in the summer it can heat too quickly, leaving a longer cooldown period before the afternoon boost, which can increase the off-tariff heating time. I’ve thought about an algorithm to auto set the on-time, but I’m too lazy.
Here’s what the automations look like. All 4 are basically the same, using the appropriate time or temperature:
alias: Heat Boost On
description: ''
  - platform: time
    at: input_datetime.octopus_on_time
condition: []
  - service: climate.set_temperature
      entity_id: climate.ducky_tub_heater
      temperature: '{{states(''input_number.octopus_on_temp'')}}'
the datetime and temperature entities are all ‘helpers’.
Hope this helps.
