I’m having some trouble adding in to the Google Home app. It keeps searching for a Hue Bridge (which I don’t have of course).
Log:
Time
Level
Message
Component
04-23-2017 13:03:19.676 INFO HA Bridge (v3.5.1) starting.... com.bwssystems.HABridge.HABridge
04-23-2017 13:03:19.876 INFO reading from config file: /home/pi/habridge/data/habridge.config com.bwssystems.HABridge.BridgeSettings
04-23-2017 13:03:20.450 WARN Error reading the file: /home/pi/habridge/data/habridge.config - Does not exist or is not readable. continuing... com.bwssystems.HABridge.BridgeSettings
04-23-2017 13:03:20.656 INFO Adding 10.0.0.20 as our default upnp config address. com.bwssystems.HABridge.BridgeSettings
04-23-2017 13:03:20.659 INFO HA Bridge initializing.... com.bwssystems.HABridge.HABridge
04-23-2017 13:03:20.928 INFO System control service started.... com.bwssystems.HABridge.SystemControl
04-23-2017 13:03:23.089 WARN Error reading the file: data/device.db - Does not exist or is not readable. continuing... com.bwssystems.HABridge.dao.DeviceRepository
04-23-2017 13:03:23.093 INFO HABridge device management service started.... com.bwssystems.HABridge.devicemanagmeent.DeviceResource
04-23-2017 13:03:23.224 INFO Hue description service started.... com.bwssystems.HABridge.upnp.UpnpSettingsResource
04-23-2017 13:03:23.249 INFO Initializing UDP response Seocket... com.bwssystems.util.UDPDatagramSender
04-23-2017 13:03:23.337 INFO UDP response Seocket initialized to: 50000 com.bwssystems.util.UDPDatagramSender
04-23-2017 13:03:24.356 INFO == Spark has ignited ... spark.webserver.JettySparkServer
04-23-2017 13:03:24.394 INFO >> Listening on 0.0.0.0:80 spark.webserver.JettySparkServer
04-23-2017 13:13:26.201 INFO Hue emulator service started.... com.bwssystems.HABridge.hue.HueMulator
04-23-2017 13:13:26.264 INFO UPNP Discovery Listener starting.... com.bwssystems.HABridge.upnp.UpnpListener
04-23-2017 13:13:26.272 INFO UPNP Discovery Listener running and ready.... com.bwssystems.HABridge.upnp.UpnpListener
04-23-2017 13:16:34.019 WARN Issue getting directory listing for backups in directory: data com.bwssystems.util.BackupHandler
04-23-2017 13:19:43.795 INFO UPNP Discovery Listener - ended, restart found com.bwssystems.HABridge.upnp.UpnpListener
04-23-2017 13:19:43.796 INFO HA Bridge (v3.5.1) reinitialization requessted.... com.bwssystems.HABridge.HABridge
04-23-2017 13:19:43.881 INFO >>> Spark shutting down ... spark.webserver.JettySparkServer
04-23-2017 13:19:43.911 INFO done spark.webserver.JettySparkServer
04-23-2017 13:19:43.912 INFO reading from config file: /home/pi/habridge/data/habridge.config com.bwssystems.HABridge.BridgeSettings
04-23-2017 13:19:43.925 INFO HA Bridge initializing.... com.bwssystems.HABridge.HABridge
04-23-2017 13:19:43.929 INFO System control service started.... com.bwssystems.HABridge.SystemControl
04-23-2017 13:19:43.933 INFO == Spark has ignited ... spark.webserver.JettySparkServer
04-23-2017 13:19:43.933 WARN Error reading the file: data/device.db - Does not exist or is not readable. continuing... com.bwssystems.HABridge.dao.DeviceRepository
04-23-2017 13:19:43.934 INFO >> Listening on 0.0.0.0:80 spark.webserver.JettySparkServer
04-23-2017 13:19:43.934 INFO HABridge device management service started.... com.bwssystems.HABridge.devicemanagmeent.DeviceResource
04-23-2017 13:19:43.940 INFO Hue description service started.... com.bwssystems.HABridge.upnp.UpnpSettingsResource
04-23-2017 13:19:43.941 INFO Initializing UDP response Seocket... com.bwssystems.util.UDPDatagramSender
04-23-2017 13:19:43.943 INFO UDP response Seocket initialized to: 50000 com.bwssystems.util.UDPDatagramSender
04-23-2017 13:19:43.983 INFO Hue emulator service started.... com.bwssystems.HABridge.hue.HueMulator
04-23-2017 13:19:43.986 INFO UPNP Discovery Listener starting.... com.bwssystems.HABridge.upnp.UpnpListener
04-23-2017 13:19:43.989 INFO UPNP Discovery Listener running and ready.... com.bwssystems.HABridge.upnp.UpnpListener
Looks like it can’t read the device.db for some reason.
P.S. I followed the starting post to the letter so this means I’m running 3.5.1 I suppose?
Google Home support wasn’t added until later. I’d try an updated version.
I usually change the name of the file ha-bridge-3.5.1.jar to just ha-bridge.jar and the corresponding line in the systemd auto start file (habridge.service) to be
and rename for example ha-bridge-4.5.0.jar to ha-bridge.jar and copy/replace the existing file in your install directory, probably /home/pi/habridge/.
If you update there is now a spot to add the hass configuration to the various bridges and you will get a tab to auto build your various devices. I don’t have it installed currently so I can’t check exactly where that is or take screen shots for you.
Time
Level
Message
Component
04-23-2017 14:28:00.915 INFO HA Bridge (v4.5.0) starting.... com.bwssystems.HABridge.HABridge
04-23-2017 14:28:01.248 INFO reading from config file: /home/pi/habridge/data/habridge.config com.bwssystems.HABridge.BridgeSettings
04-23-2017 14:28:15.995 INFO HA Bridge initializing.... com.bwssystems.HABridge.HABridge
04-23-2017 14:28:16.081 INFO System control service started.... com.bwssystems.HABridge.SystemControl
04-23-2017 14:28:16.209 INFO Initializing UDP response Socket... com.bwssystems.HABridge.util.UDPDatagramSender
04-23-2017 14:28:16.248 INFO UDP response Seocket initialized to: 50000 com.bwssystems.HABridge.util.UDPDatagramSender
04-23-2017 14:28:16.264 INFO Harmony Home created. No Harmony devices configured. com.bwssystems.HABridge.plugins.harmony.HarmonyHome
04-23-2017 14:28:16.277 INFO Nest Home created. com.bwssystems.HABridge.plugins.NestBridge.NestHome
04-23-2017 14:28:16.362 INFO Starting Nest login... com.bwssystems.nest.controller.NestSession
04-23-2017 14:28:16.715 INFO == Spark has ignited ... spark.webserver.JettySparkServer
04-23-2017 14:28:16.728 INFO >> Listening on 0.0.0.0:80 spark.webserver.JettySparkServer
04-23-2017 14:28:19.710 INFO Completed Nest login... com.bwssystems.nest.controller.NestSession
04-23-2017 14:28:20.731 INFO Hue passthru Home created. No Hue passtrhu systems configured. com.bwssystems.HABridge.plugins.hue.HueHome
04-23-2017 14:28:20.736 INFO HAL Home created. No HAL devices configured. com.bwssystems.HABridge.plugins.hal.HalHome
04-23-2017 14:28:20.743 INFO MQTT Home created. No MQTT Clients configured. com.bwssystems.HABridge.plugins.mqtt.MQTTHome
04-23-2017 14:28:20.749 INFO HomeAssistant Home created. com.bwssystems.HABridge.plugins.hass.HassHome
04-23-2017 14:28:20.785 INFO Command Home for system program execution created. com.bwssystems.HABridge.plugins.exec.CommandHome
04-23-2017 14:28:20.810 INFO Http Home created. com.bwssystems.HABridge.plugins.http.HTTPHome
04-23-2017 14:28:20.816 INFO TCP Home created. com.bwssystems.HABridge.plugins.tcp.TCPHome
04-23-2017 14:28:20.821 INFO UDP Home created. com.bwssystems.HABridge.plugins.udp.UDPHome
04-23-2017 14:28:20.826 INFO Vera Home created. No Veras configured. com.bwssystems.HABridge.plugins.vera.VeraHome
04-23-2017 14:28:20.833 INFO Domoticz Home created. No Domoticz devices configured. com.bwssystems.HABridge.plugins.domoticz.DomoticzHome
04-23-2017 14:28:20.839 INFO Somfy Home created. No Somfys configured. com.bwssystems.HABridge.plugins.somfy.SomfyHome
04-23-2017 14:28:20.849 INFO LifxDevice Home created. No LifxDevices configured. com.bwssystems.HABridge.plugins.lifx.LifxHome
04-23-2017 14:28:20.901 INFO HABridge device management service started.... com.bwssystems.HABridge.devicemanagmeent.DeviceResource
04-23-2017 14:28:21.004 INFO Hue description service started.... com.bwssystems.HABridge.upnp.UpnpSettingsResource
04-23-2017 14:28:21.038 INFO Hue emulator service started.... com.bwssystems.HABridge.hue.HueMulator
04-23-2017 14:28:21.166 INFO UPNP Discovery Listener starting.... com.bwssystems.HABridge.upnp.UpnpListener
04-23-2017 14:28:21.172 INFO UPNP Discovery Listener running and ready.... com.bwssystems.HABridge.upnp.UpnpListener
04-23-2017 14:29:14.029 INFO Link button pressed.... com.bwssystems.HABridge.SystemControl
Both Nest and Home Assistant tabs are empty. Still can’t add Hue in the Google Home app (not finding the bridge).
Running HASS on the same PI as the HA-Bridge so this should be correct right? I also tried with password (which shouldn’t be neccesary because i’m on the trusted network).
04-23-2017 14:31:51.776 WARN Error calling out to HA gateway: IOException in log com.bwssystems.HABridge.plugins.http.HTTPHandler
04-23-2017 14:31:51.779 WARN Cannot get an devices for HomeAssistant Home Assistant http call failed. com.bwssystems.HABridge.plugins.hass.HomeAssistant
04-23-2017 14:31:51.780 WARN Cannot get devices for HomeAssistant with name: Home Assistant, skipping this Hass. com.bwssystems.HABridge.plugins.hass.HassHome
04-23-2017 14:31:53.062 WARN Error calling out to HA gateway: IOException in log com.bwssystems.HABridge.plugins.http.HTTPHandler
04-23-2017 14:31:53.064 WARN Cannot get an devices for HomeAssistant Home Assistant http call failed. com.bwssystems.HABridge.plugins.hass.HomeAssistant
04-23-2017 14:31:53.065 WARN Cannot get devices for HomeAssistant with name: Home Assistant, skipping this Hass. com.bwssystems.HABridge.plugins.hass.HassHome
04-23-2017 14:41:30.649 WARN Error calling out to HA gateway: IOException in log com.bwssystems.HABridge.plugins.http.HTTPHandler
04-23-2017 14:41:30.651 WARN Cannot get an devices for HomeAssistant Home Assistant http call failed. com.bwssystems.HABridge.plugins.hass.HomeAssistant
04-23-2017 14:41:30.652 WARN Cannot get devices for HomeAssistant with name: Home Assistant, skipping this Hass. com.bwssystems.HABridge.plugins.hass.HassHome
04-23-2017 14:41:53.785 WARN Error calling out to HA gateway: IOException in log com.bwssystems.HABridge.plugins.http.HTTPHandler
04-23-2017 14:41:53.787 WARN Cannot get an devices for HomeAssistant Home Assistant http call failed. com.bwssystems.HABridge.plugins.hass.HomeAssistant
04-23-2017 14:41:53.787 WARN Cannot get devices for HomeAssistant with name: Home Assistant, skipping this Hass. com.bwssystems.HABridge.plugins.hass.HassHome
I have to run but I seem to remember having problems creating the database and config file at one stage - it gets created the first time you launch, and then trouble getting data to stick. I, would open the file and it wouldn’t have any of my data in it. I can’t remember if it was permissions or a matter of launching quitting and then launching again.
I’m new Here, I am using HaBridge 3.5.1 With X10 commander with all X10 devices and Amazon Echo. I have successfully set up my X10 devices in HaBridge and they work great with Echo voice commands, however when the computer is re-booted all the devices disappear on HaBridge. I hit the save button on HaBridge once and everything disappeared then as well… Help!
Sorry - still haven’t reinstalled and last used a few versions ago. I had a similar problem then with config not sticking. First place I’d be looking is permissions - or even if the config files are being saved and kept. Have a look in/at the directory and compare files between reboots.
Where can I find a habridge.config file? After installation there was no data directory and no such config file.
Where do I specify a port address? 80 and 8080 are already taken by other components.
Hi there I just get in here and I all ready added xiaomi stuff an I put ha bridge running I have q orange pi with Google assistant and with home assistant how can I control the lights? Anyone an help me?
