Stirling work, Chris!
Would you be able to zip and share the image files? I don’t know a thing about figma or image editing!
I’ve got your dash replicated here other than the above card.
Excellent work!
Excellent work!
I don’t know if am doing something wrong but my SVG images are not loading.
What’s your code?
I’ve made some modifications to the Rivian card, GitHub - tmack8001/ha-rivian-card: Rivian Card for use with Home Assistant, today that should fix a few things though now you need to explicitly setup your entity naming (find+replace-all) on the templated naming I’ve put in place now. This way you could easily update based on your device naming convention that is preferred by the integration now.
Looks like you are missing a required dependency of card-mod which will allow for the inlined CSS to resize the images appropriately.
anyone do anything similar with a Subaru vehicle?
Odd - I had it installed but it wasn’t working because I set an incorrect frontend url for the module.
Nice updates to the cards:
nice thanks for confirming it works as expected. sorry for the trouble on the card-mod installation
These cards look beautiful!
I’ve updated the readme recently, GitHub - tmack8001/ha-rivian-card: Rivian Card for use with Home Assistant, to contain example screenshots of what the various states are.
That side view charging card is dynamic based on if the vehicle is charging or not. Unforutunately I’ haven’t gone in to modify and remove the charger plug when not plugged in (these images come straight from the manufacturer… working on an update to pull in the right wheel style and color).
when there is an active charge session
normal for when not charging (plugged in or not)
Was wondering if somebody did something similar for a Kia EV6, if so, would love to see it!
And if possible, receive the required files to get going!
Have started based on another example from the forum of @flixlixlix, see picture below but far from ready. See the post in the " Car Dashboard - Volkswagen ID3 2021" for the possibilities of the card.
Thanks!
I’ll second the request for an EV6.
Awesome work @genosonic
Been looking for at way to display our Skoda Enyaq IV 60 in Home Asssistant and this is the perfect way
Any chance you can make the Enyaq also in black (Our car color is “Black Magic Pearl”)
Best regards
Nick Fredberg
So glad I stumbled upon this post. With a bit of Photoshop and the code above I was able to put the following card in action.
When the car is unlocked but no door is open it just displays an unlock sign:
Then I have images for all 4 doors, hood and trunk.
Forget about the entity that’s unavailable, the integration is not publishing it since yesterday.
So, this is a Skoda Scala Monte Carlo, if anyone has the same car, let me know and I can share the files…
Thank you very much
I have been doing some updates that i would like to share.
Now the vehicle card contains images for when the fuel is below 40% and i also added a lock image when only the trunk is unlocked. Improved a bit the car in the card by adding a different background and a shadow under the car. See below the entire dashboard:
Below is only the trunk unlocked:
When doors are unlocked:
Also the lights turn on in the picture element on the top left corner.
I am also using the swipe card to place the most common functions like unlock/lock the trunk, doors, flash, flash and honk and force refresh data from the integration.
It came out pretty nice! Hope you like it too but if an suggestions please let me know!
Thank you all!
Yeeaaah, it looks good
How can i build this
looks awsome!
Fancy!!!
Where did you find the top view file? Or maybe it’s homemade?
Snatched it of a cardealer site. The sun roof served my purposes well.
