the K:home is my iphone home {{ states.device_tracker.iphone.state }}
the A:not_home is my wife {{ states.device_tracker.galaxy.state }}
the number 53 is my LG phone’s battery level &count={{ states.sensor.lgphonebatt.state }}
the circle is around number 53 is my tablet’s battery level &percent={{ states.sensor.phonebatt.state }}
the H: 42 is humidity {{ states.sensor.humidity_livingroom.state }} but is from my sensor
the T: 78° is temperature {{ states.sensor.temperature_livingroom.state }}° but from sensor not from dark sky
the L: 4 are my lights how many are on {{ states.sensor.lights_on.state }}
the S:2 are my switches how many are on {{ states.sensor.switches_on.state }}
the D:closed is my door {{ states.sensor.door.state }}
the A:h is my daughter home {{ states.sensor.pollo.state }}
the J: h is my other daughter home {{ states.sensor.girl.state }}
Mine show differently,
this is my shell command
‘curl --data “token=mytoken&user=myuser&title=S:{{ states.device_tracker.suniphone.state }} D:{{ states.device_tracker.dianaiphone.state }}&text=L:{{ states.sensor.lights_on.state }} A:{{ states.alarm_control_panel.ssh.state }}&subtext=H:{{ states.sensor.sn1_humidity.state }} T:{{ states.sensor.sn1_temperature.state }}°D:{{ states.sensor.doors_open.state }}M:{{ states.sensor.motion_away.state }}” https://api.pushover.net/1/glances.json’
I cannot put &count=, &percent= , these two will give me error.
Then I get
On first row
S:{{ states.device_tracker.suniphone.state }} and so on I can’t see
On second row
L:{{ states.sensor.lights_on.state }} and so on I can’t see
On third row
H:{{ states.sensor.sn1_humidity.state }} and so on I can’t see
on shell command I got error if I put like you
token=mytoken&user=myuser=K:{{ states.device_tracker.iphone.state }}
behind &user=myuser without & before=K, I get error. when I put &=K, I get none of K display no error and follow by {{ states.device_tracker.iphone.state }}. So I have to put &title=K , then display the K but with {{ states.device_tracker.suniphone.state }}
Finally, I got it done with only from shell_command.
My shell_command doesn’t works if I put &percent=, &count=. It will give error and show with unknown. Also from the share counter above doesn’t work for me as well.
So I only use the shell_command and sensors only to get the information to my watch.
So, if you read the initial post, I am using Glances API to update the complication. To do that you first need an account with Pushover. There you get the user token. Then you need to create an application from which you’ll get the token value. Both are needed to send updates.
Does your Apple Watch still receive the updates using glances?
Mine was working fine up until a few weeks/month ago after an update now it just doesn’t receive/display any data… even though home assistant is showing the data pushed…
