Found the issue. There was an extra ’ at the and of my key before the " and once I removed that it now shows the attributes. Let me try the template now. I will report back.
Ok so I got the youtube api sensor working but if I test the subscriber count and view count template you sent me in developer template it give the below error.
You don’t need all the text there only the stuff in between { }
that will also make it easier to see what you have there.
Did you remember to add the [0]
as I said here:
meaning:
sensors:
youtube_subscriber_count:
friendly_name: "Subscriber count"
value_template: >-
{% if state_attr('sensor.youtube_api', 'items') != None %}
{{ state_attr('sensor.youtube_api', 'items').[0].statistics.subscriberCount }}
{%- endif %}
sensors:
youtube_view_count:
friendly_name: "View count"
value_template: >-
{{ state_attr('sensor.youtube_api', 'items').[0].statistics.viewCount }}
{%- endif %}
Oh I see, Ok cool let me change the [0] and then test it out again.
Thank you so much for your help.
Did it work?
Sorry I had to step out. I will check it now and let you know.
So I have the following in my configuration.yaml and changed the fake value to 0 as you mentioned. (I only put a 0 there instead of the 1 as when I put the code there that you posted and I check my configuration before restart it gives me the error )
#####Youtube Statistics Sensor#######
- platform: rest
resource_template: "https://youtube.googleapis.com/youtube/v3/channels?part=statistics&id=UCOSx30ko605VZI4f0mdMlYw&key=$mykey"
method: GET
headers:
content-type: 'application/json'
value_template: "0"
json_attributes:
- "items"
scan_interval: 300 # 5 Minutes
sensors:
value_template: >-
{{ state_attr('sensor.youtube_api', 'items').statistics.subscriberCount }}
{%- endif %}
And then I pasted only the stuff between the {{ }} into the developer template and the below is what I am getting:
I may be pointing out the obvious but in case there are those who haven’t read the subscriberCount notes it may save some anguish.
The API does not return a true subscriber count. It returns a rounded count with the rounded numbers (they round down always) a significant part of the count. For example, if you have 12,345 subscribers it will show 12,300. If you have 1,234,567 subs you will get 1230000.
In a developer email I received in 2019, YouTube stated that this was done for “mental health reasons” and “anxiety” (I wish I kept the email!) of their publishers who watch subscriber counts like a hawk, causing stress. You know what didn’t work well for my mental health, YouTube? Breaking all the of the automations I had around my YouTube subscriber count, my live counters, and fudging your data to treat me like a child.
Anyway, point is that this rounding significantly reduces the usefulness, at least in my experience, of subscriberCount as a data source for automations.
So I played with the code you sent me with the [0] in it and it turns out that I needed to remove the < . > in front of the [0]
Original code:
After I changed it:
{{ state_attr('sensor.youtube_api', 'items')[0].statistics.subscriberCount }}
And that seems to have fixed the issue.
Thank you so much for your assistance, much appreciated.
Hi guys just an update on what I have done with my Youtube integration in Lovelace
The Only thing I would still like to incorporate is the “Watch Time - Hours” but I have not managed to find a way to get that info using the DataAPIV3 yet. If anyone knows please do share.
Similar to this, I created a rest sensor and template to fetch a YouTube video url when an artist and song name input is provided. When the input_text
var is changed, it will trigger an automation that will trigger a refresh of the REST sensor. Which will capture the first result matching the artist name and song provided. It will fetch the youtube title, videoId and thumbnail url. With this a direct youtube url can be build which can then be used to stream/cast.
- Create YouTube API key
- Store API credentials in
secret.yaml
youtube_api_key: XXXXXXXXXXXXXXXXXXXXXXXXXXX
- Link hidden password
input_text
to secret inconfiguration.yaml
input_text:
youtube_api_key:
initial: !secret youtube_api_key
mode: password
homeassistant:
customize:
input_text.youtube_api_key:
hidden: true
- Enable YouTube API v3
- Restrict API key to only query YouTube API
- Add REST sensor to query YouTube API, set high scan interval so REST call will only be executed when a refresh would be triggered.
configuration.yaml
(or can be split intosensor.yaml
- platform: rest
name: Get YouTube first search result
scan_interval: 99999999
resource_template: "https://www.googleapis.com/youtube/v3/search?part=snippet&maxResults=1&type=video&&format=json&q={{states('input_text.search_mp3_youtube')}}&key={{states('input_text.youtube_api_key')}}"
value_template: "{{value[:250]}}"
json_attributes:
- items
sensors:
youtube_search_song_video_url:
value_template: "https://www.youtube.com/watch?v={{state_attr('sensor.get_youtube_first_search_result','items')[0].id.videoId }}"
sensors:
youtube_search_song_video_title:
value_template: "{{state_attr('sensor.get_youtube_first_search_result','items')[0].snippet.title }}"
sensors:
youtube_search_song_video_thumbnail:
value_template: "{{state_attr('sensor.get_youtube_first_search_result','items')[0].snippet.thumbnails.high.url }}"
- Create automation to trigger REST sensor refresh when
input_text
to search is changed
- id: 'XXXXXXX'
alias: Search YouTube URL
description: ''
- platform: state
entity_id: input_text.search_mp3_youtube
to:
condition: []
- service: homeassistant.update_entity
entity_id: sensor.get_youtube_first_search_result
mode: single
- Create script to cast first found YouTube result based on search input text. With a short delay to make sure the rest sensor is updated after input has changed. In
scripts.yaml
play_youtube_search_selection:
alias: Play YouTube search
sequence:
- delay:
hours: 0
minutes: 0
seconds: 3
milliseconds: 0
- service: media_extractor.play_media
data_template:
entity_id: media_player.chromecast
media_content_id: '{{ states(''sensor.youtube_search_song_video_url'') }}'
media_content_type: video/youtube
mode: single
icon: mdi:youtube
- Add input text and button to trigger script into lovelace. Thumbnail and title could also be added based on sensors above:
- entity: input_text.search_mp3_youtube
type: custom:text-input-row
- type: button
tap_action:
action: toggle
entity: script.play_youtube_search_selection
