If you are looking for a way to capture what the assistant heard and says then you can add the following to your voice assistant device yaml configuration. This gives you a text sensor within Home Assistant with the last conversation request and response.
text_sensor:
###### Text Request ######
icon: mdi:message-processing
internal: false
on_value:
lambda: |-
if(id(text_request).state.length()>32) {
std::string name = id(text_request).state.c_str();
std::string truncated = esphome::str_truncate(name.c_str(),31);
id(text_request).state = (truncated+"...").c_str();
###### Text Response ######
icon: mdi:message-reply-text
internal: false
on_value:
lambda: |-
if(id(text_response).state.length()>32) {
std::string name = id(text_response).state.c_str();
id(text_response).state = (truncated+"...").c_str();
voice_assistant:
on_listening:
- lambda: id(text_request).publish_state("...");
- lambda: id(text_response).publish_state("...");
on_stt_end:
- text_sensor.template.publish:
state: !lambda return x;
on_tts_start:
Hope this helps you out.
