Get files from password protected snapshot?
Pretty neet indeed.
However it failed in my case.
Maybe something’s change since the writing of the script in 2019?
I systematically got a “Unable to extract SecureTar - Maybe your password is wrong or the tar is not password encrypted?” message even on freshly created backups .
Scratch that: I’m an idiot and was using the wrong password. :blush:
The script is fine and useful!
Although I decided to avoid encryption from now on.
you are a life saver. Thanks so much
Anyone who can tell me how to do this in windows?
Have installed python3 but dont know how to use it.
follow the instructions above, but in a cmd indow instead of the nano command use notepad (or your favorite text editor) and use that to create your decrypt.py file
install the cryptography module by doing:
pip install cryptography
then run the same python command above, but your executable might be python or py instead of python3.
Thanks a ton. This worked perfectly when all home-assistant would do on a partial backup was hang or error out.
I was pulling my hair out trying to get files out of a password protected backup. It was a long journey of not getting why other tar unpackers would not unpack the tar even with the password. Many thanks for this script worked a charm in WSL :slight_smile:
Big thanks, @Burningstone - your script worked perfectly on my Ubuntu laptop with Python3. I’m very relieved to see a backup tarball unpacked and viewable once again :+1:
I wrote a small shell script which sticks to core utils and openssl. Hassio-tar.sh - Decrypt Home Assistant backups with near-zero dependencies required
