Get notified when Home Assistant has errors/can't start up
@stefanheule I was able to get this working but made a few tweaks that (I think) simplified things. Sharing here to add to the knowledge pool. I referenced this post where they were picking up the persistent notifications via automations.yaml.
I’m using the all events node and filtering out to only call_service events. From there I am using a function as you suggested to filter, but it’s a bit more brief. An then lastly using a call service node to call notify and send me a notification. I’m referencing the message object to populate the notify data to pass on the title and message.
function code:
if (msg.payload.event.domain == 'persistent_notification' &&
    msg.payload.event.service == 'create')
    // this is a persistent notification
    return msg.payload;
} else {
    // ignore
    return null;
and the data within notify service node:
    "title": "Persistant: {{event.service_data.title}}",
    "message": "{{event.service_data.message}}"
