Hi! I tried using your version of this but unfortunately I got the following errors:
Thanks for looking into this!!
Configuration invalidCHECK CONFIG
Platform not found: sensor.shabbat_times
Error loading custom_components.sensor.shabbat_times. Make sure all dependencies are installed
Traceback (most recent call last): File “/usr/local/lib/python3.6/site-packages/homeassistant/loader.py”, line 92, in get_component module = importlib.import_module(path) File “/usr/local/lib/python3.6/importlib/init.py”, line 126, in import_module return _bootstrap._gcd_import(name[level:], package, level) File “<frozen importlib._bootstrap>”, line 994, in _gcd_import File “<frozen importlib._bootstrap>”, line 971, in _find_and_load File “<frozen importlib._bootstrap>”, line 955, in _find_and_load_unlocked File “<frozen importlib._bootstrap>”, line 665, in _load_unlocked File “<frozen importlib._bootstrap_external>”, line 678, in exec_module File “<frozen importlib._bootstrap>”, line 219, in _call_with_frames_removed File “/config/custom_components/sensor/shabbat_times.py”, line 13, in <module> from homeassistant.helpers.restore_state import async_get_last_state ImportError: cannot import name ‘async_get_last_state’
wow, that was quick! works great now! Thank you! I made a few automations based on your excellent examples. I’m looking forward to this shabbat to see if it works!
Hi all!
I just found this useful plugin to home assistant that i think works pretty well and could be useful. I especially found the “issur_melacha” sensor to be very useful for making automations.
A bit off topic but hopefully will get the right people on board. I was looking to make a smart plug that has the jewish calendar hard coded so one can make shabbat and holiday based schedules.
If anyone can help I was thinking of either using tasmota or esphome, please reach out.
Sounds like a great idea. Since all the calculations are mathematically based and it already can handle location and sunset calculations, it should be doable. I’d be a user, but I lack the technical capability to do it. I already use Tasmota to do Shabbat schedules, but that’s done purely on day of week.
Upon further research it seems esphome is the preferable method.
I still need some help with creating a web ui scheduler, as well as the hebrew calendar implementation.
I have an existing KNX Home Automation system with AMX as the Hub/Brain.
I’m replacing the AMX with HA. HA is already up and running with SSD and connected to all KNX devices.
I have the following capabilities in AMX and I want to replicate it in HA (and make it better, faster, stronger).
I’ve read about multiple ways to automate in HA; Automations, Code-Red, Schedule Cards (HACS). I’m not sure what would be the best architecture and set of technologies in HA to do this effectively (no coding and easy to maintain)
I have different scenarios. For example:
Regular Day
Vacation
Holiday
There is a set of default actions that will happen across all these scenarios, for example - outside lights going on at dusk and off at daybreak, Sensors, Shutters raising/lowering, etc.
Then each of the scenarios has a separate set of actions tied to that scenario. For example:
Lights or devices turning on and off
HVAC on/off or set to different temperatures
I also want to be able to change variables (time/entities) easily via LoveLace without having to change a script, automation or Code Red.
For example:
Changing the time a light goes on or off
Have HVAC go on in room or remove from scenario temporarily
Any Suggestions? Or things that are already pre-built and can be adapted.
