When I try to use that I get:
1305 - FUNCTION homeassistant.strftime does not exist
STRFTIME is specific to sqlite. That 1305 comes from MySQL, doesn’t it?
Yeah I’m using MariaDB. I think I’ve got it:
SELECT state FROM states WHERE entity_id = 'sensor.total_cost_today' AND HOUR(TIMEDIFF(UTC_TIMESTAMP(), last_updated))>=24 ORDER BY last_updated DESC LIMIT 1
I started using Grafana for this (and other reasons).
It’s strange that nobody mentions the existence of it?
EDIT: this is mainly addressed to those looking for a way to have data from the past
I needed a sensor not a graph.
The querying of the DB indeed takes a lot of CPU power; my Pi4 increased from 30% CPU usage to 50%, which really slows the overall experience of HA.
Solution: disable the updates for the SQL sensor and update it via an automation at the frequency you want.
see: SQL - Home Assistant scan interval
In summary: disable the updates in the SQL integration (via the 3 dots and system options).
Next: make an automation to update the sensor, eg. every 10 minutes.
Example:
- alias: update van zonneproductie gisteren op dit uur
description: ""
- platform: time_pattern
minutes: /10
condition: []
data: {}
entity_id: sensor.zonneproductie_gisteren_op_dit_uur
Note: I defined the SQL sensor in the configuration.yaml file and saw that the sensor was mentioned 2 times in the SQL integration. I have the impression that you have to define the SQL sensor via the GUI only instead of the configuration.yaml because you cannot disable the updates via the config file.
Anyone could help?
I need to make query to show sensor state from 23:59 form yesterday and 23:59 from the day before yesterday.
I tried the queries given above but looks like my scropt is wrong as the integration doesn’t accept the query.
Thank you!
Please do not cross post on multiple threads. If you have a question, create a single new topic.
The timestamp spec in the database has changed in recent schema, so old SQL queries may no longer work. If you can wait a day to start using your data, I’d suggest using an automation to record the temperature in advance. Another option would be a trigger-based template sensor, but I’m not convinced they would do what you want if the system restarted. Something like this, with two input_number
helpers already set up:
alias: Temperature recorder
description: >
Records the temperature at 23:59 into input_number.temp_yday, dropping
the previous value into input_number.temp_day_before.
- platform: time
at: "23:59:00"
entity_id: input_number.temp_day_before
value: "{{ states('input_number.temp_yday')|float(0.0) }}"
entity_id: input_number.temp_yday
value: "{{ states('sensor.current_temperature')|float(0.0) }}"
Thank you fot quick response!
I will try that now and post results when I’m back from vacation (I am about to go the airport).
You could manually trigger it a couple of times, which should populate both helpers with the current temperature. At least you’ll know that the automation works…
I’m using Average sensor from HACS to do that.
- platform: average
name: Temperature yesterday this time
unique_id: ANYUNIQUEID
entities:
- sensor.openweathermap_temperature
start: "{{ now() - timedelta(days=1, minutes=5) }}"
end: "{{ now() - timedelta(days=1, minutes=0) }}"
But if you want the temperature from exactly 23:59 that’s not the way.
sorry to bother with the original post from 2021.
My template sensor is working, but it becomes unknown after HA restart (i understand why) but trying to research your hint, HA Startup trigger for refreshing the value.
I’ve found
- platform: homeassistant
event: start
- platform: event
event_type: event_template_reloaded
but I’ve no success with combining them into a template…
I tried setting this up for one of my own sensors, restarted HA, got the confirmation message “HA has started” 10 minutes before the trigger was supposed to fire, I then checked my entities 12m afterward but the sensor still didn’t show up.
This also somehow made my other template sensors I wrote below it in config.yaml, such as the binary sensor below, disappear.
template:
- trigger:
- platform: time
at: "14:05"
- name: RealFeel Temperatur gestern
unique_id: realfeel_temperatur_gestern
state: "{{ states('sensor.dungeon_realfeel_temperature_max_0d') }}"
unit_of_measurement: °C
- binary_sensor:
- name: "Eingabe am PC"
#innerhalb der letzten <120s:
state: "{{ as_timestamp(now(),0) - as_timestamp(states('sensor.ars_computer_letzte_eingabe'),0) < 120 }}"
Edit: fixed it by adjusting the amount of spaces before the upper template sensor to be in line with the lower one:
template:
- trigger:
- platform: time
at: "23:59"
- name: RealFeel Temperatur max gestern
unique_id: realfeel_temperatur_max_gestern
state: "{{ states('sensor.rape_dungeon_realfeel_temperature_max_0d') }}"
Regarding this offered solution above, It seems to me that there will be a lot of unnecessary processor load throughout the day for just 1 update of an Entity each day before midnight! Should I worry about such stuff?
Anyway, my solution was to create an MQTT Entity and have an Automation running just before midnight that Published the ’ Yesterday’ value that the MQTT Entity picked up.
What’s with the hyphens? -%}
and {%-
You can do it with trigger based template entities now, those didn’t exist when that post was written.
remove trailing whitespace -%}
remove leading whitespace {%-
I can’t see how to do a Trigger based template in the GUI/Helpers section. Is it only possible in YAML:?
Ta for the hyphen explanation.
Yaml only
OK. So now I’ve got 8 Energy Yesterday sensors on various circuit from my consumer unit fed via MQTT and the equivalent 8 Cost Yesterday sensors fed from the Trigger Template.
It probably took a similar time to set them up. I don’t know which is the more processor efficient method.
a single trigger at 1 point in the day is hands down the most efficient way to do things. You can also configure them to all use the exact same trigger.
