Good Morning,
I have just received an API key from Geyserwise - I have the Geyserwise Client Integration API Document.
I will send the Document to whoever is willing to help.
Kindly give me some guidance on the integration.
Regards
Good Morning,
Regards
Hi, Iām very new to HA, and have opted for localTuya, which is working. Iām battling however to get all the entities youāve shown here. Also donāt have DSP 10 for current temperature. Have used Sensor, not sure if I should use climate.
Hi @HomeGeorge, please ignore my previous post on temperature. I got it working. I do however have a question around the enity type for DSP10. You used sensor, and it works well. I want to however use CLIMATE, because that will allow for an HVAC type control on a mushroom-climate card, which works pretty well too. Sensor entity type will unfortunately not cut it,
Any advice?
Will also be nice, to know what you used in your sample dashboard.
Interested in your approach.
Iām assuming you have not done anything to the device (just the Tuya enabled Geyserwise board).
I am keen to create MQTT - Tuya link in the Homie standard to automatically populate devices discovered on Tuya to MQTT. I see itās a little supported Home Assistant but the Homie standard is supported by OpenHab. In OpenHAB these devices are then autodiscovered based on Homie standard.
Iām using OpenHAB so not going to switch anytime soon.
I also want to summarise the approaches to solve this problem found on this thread:
Are these all the solutions?
My questions relates to 2 (a-c). Does that allow access to the full range of variables (14 it seems to be for the Max product). @the_brains seems to have solved this? Does this apply to the Tuya solution? Is this cloud?
Tuya cloud only gives you access to some of the sensor data. Tuya local gives you access to everything @the_brains listed above.
Does this apply to cloud? Or to the local?
Just got my Geyserwise Max Tuya. I see what you mean under the Tuya Project panel. Here it lists the additional variables withe the DP Instruction mode:
Cloud and Local
Once set, youāll be able to see all the attributes, I went the route of using Tuya local. You can run local and cloud simultaneously
No reason to go through Geyserwise to be honest. Just use Tuya.
Got it all connected up just now. Will share scripts later as it may be helpful for multiple Tuya devices. Though not HA specific. Graph shows panel temperature and geyser temperature below.
Hi @HomeGeorge been looking for a āsimpleā solution to replace existing solar/electric geyser combo, which will integrate to HA, but still run independently if HA down.
If Iām understanding correctly your solution entails:
If this is case Iām going shopping.
Look fwd to hearing from you.
Hi All
Thank you for everyone that shared their experience on this. I have re-used a bunch of learnings from this post and others and completed an integration from my Geyserwise Max to Home Assistant. This should also be possible with the Delta and TSE models but I have not tested that.
Sorry for the lack of media in the post, as a new user I seem to be limited to only one media file per post.
Steps I followed:
Step 1 & 2: Follow the steps as described by @kidcolt here
Step 3: Ensure you configure the Tasmota module type as Tuya MCU(54), this configures the ESP to interface with the tuya MCU module via the UART.
In order to periodically send the Tuya messages recieved on the UART but avoid unneccessary cyclic messages set the following options in the console settings.
SetOption66 1
SetOption137 1
Step 4: Add new sensor configuration for the Geyser. Here is my geyser1.yaml file. Make sure you correct the mqtt topic to reflect your settings in Tasmota.
I still need to map the correct error code values to human readable descriptions for the geyser1_error_code sensor. If anyone know the correct values for each error type please let me know.
# Requires:
# Transplant WBR3 chip transplanted with ESP-12F
# Tasmota configured for device type TuyaMCU (54)
# SetOption66 1 in tasmota
# To avoid some cyclic MCU <-> ESP messages enable SetOption137 1
# "DpType1Id1": 0, Element Control
# "DpType4Id2": 1, Mode (holiday/normal)
# "DpType2Id10": 47, Geyser Temperature
# "DpType4Id13": 0, Element Status
# "DpType5Id20": "0x0000", Error Code
# "DpType4Id101": 0, Pump Status
# "DpType2Id102": 7, Geyser Solar Diff Temp
# "DpType2Id103": 55, Geyser block 1 - Max Temp
# "DpType2Id104": 55, Geyser block 2 - Max Temp
# "DpType2Id105": 55, Geyser block 3 - Max Temp
# "DpType2Id106": 55, Geyser block 4 - Max Temp
# "DpType2Id107": 5, Geyser Antifreeze Temp
# "DpType2Id108": 21, Geyser Collector Temp
# "DpType2Id109": 2 Element Runtime hours
# TuyaSend<x> dpId,data
# x=1 Send Boolean(Type 1)
# x=2 Send Integer(Type 2) or 4 byte
# x=3 Send ASCII(Type 3) String
# x=4 Send Enum(Type 4) data
# x=5 Send HEX String(Type 3) data, does not require 0x prefix
mqtt:
- name: "Temp"
object_id: "geyser1_temp"
state_topic: "tele/tasmota_geyser1/RESULT"
device_class: temperature
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id10'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id10'] | int }}
{% endif %}
unit_of_measurement: "°C"
- name: "Collector Temp"
object_id: geyser1_collector_temp
icon: mdi:solar-power-variant
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id108'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id108'] | int }}
{% endif %}
- name: "Antifreeze Temp"
object_id: geyser1_antifreeze_temp
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id107'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id107'] | int }}
{% endif %}
- name: "Element Runtime"
object_id: geyser1_element_runtime
device_class: duration
state_class: measurement
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id109'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id109'] | int }}
{% endif %}
unit_of_measurement: "hrs"
- name: "Block 1 - Max Temp"
object_id: geyser1_block1_temp
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id103'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id103'] | int }}
{% endif %}
- name: "Block 2 - Max Temp"
object_id: geyser1_block2_temp
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id104'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id104'] | int }}
{% endif %}
- name: "Block 3 - Max Temp"
object_id: geyser1_block3_temp
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id105'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id105'] | int }}
{% endif %}
- name: "Block 4 - Max Temp"
object_id: geyser1_block4_temp
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id106'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id106'] | int }}
{% endif %}
- name: "Solar Diff Temp"
object_id: geyser1_solar_diff_temp
value_template: >-
{% if value_json['TuyaReceived']['DpType2Id102'] is defined %}
{{ value_json['TuyaReceived']['DpType2Id102'] | int }}
{% endif %}
- name: "Error Code"
object_id: geyser1_error_code
icon: mdi:information-box-outline
value_template: >-
{% if value_json['TuyaReceived']['DpType5Id20'] is defined %}
{% if (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x0000' %}
[00] Normal
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E1' %}
[E1] Earth Leakage
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E2' %}
[E2] Dry Burn Protection
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E3' %}
[E3] Sensor failure water geyser
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E4' %}
[E4] Heating Loss
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E5' %}
[E5] Over temperature protection
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E6' %}
[E6] Water Leak
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E7' %}
[E7] Communication failue
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E8' %}
[E8] Collector temperature probe
{%elif (value_json['TuyaReceived']['DpType5Id20'] | string) == '0x00E9' %}
[E9] Pump failure
{%else%}
Unknown
{% endif %}
{% endif %}
- name: "Element"
icon: mdi:fire
value_template: >-
{% if value_json['TuyaReceived']['DpType4Id13'] is defined %}
{% if (value_json['TuyaReceived']['DpType4Id13'] | string) == '0' %}
OFF
{%elif (value_json['TuyaReceived']['DpType4Id13'] | string) == '1' %}
ON
{%else%}
Unknown
{% endif %}
{% else %}
Unknown
{% endif %}
- name: "Pump"
object_id: geyser1_pump
icon: mdi:pipe-valve
value_template: >-
{% if value_json['TuyaReceived']['DpType4Id101'] is defined %}
{% if (value_json['TuyaReceived']['DpType4Id101'] | string) == '0' %}
OFF
{%elif (value_json['TuyaReceived']['DpType4Id101'] | string) == '1' %}
ON
{%else%}
Unknown
{% endif %}
{% else %}
Unknown
{% endif %}
binary_sensor:
- name: "Status"
object_id: geyser1_status
icon: mdi:alert
device_class: problem
value_template: >-
{% if value_json['TuyaReceived']['DpType5Id20'] == '0x0000' %}
OFF
{% else %}
ON
{% endif %}
{% else %}
OFF
{% endif %}
switch:
- name: "Power"
object_id: geyser1_power
icon: mdi:power
state_on: 1
state_off: 0
value_template: >-
{% if value_json['TuyaReceived'].DpType1Id1 is defined %}
{{ value_json.TuyaReceived.DpType1Id1 }}
{% else %}
0
{% endif %}
command_topic: "cmnd/tasmota_geyser1/TuyaSend1"
payload_on: "1, 1"
payload_off: "1, 0"
availability_topic: "tele/tasmota_geyser1/LWT"
payload_available: "Online"
payload_not_available: "Offline"
- name: "Holiday Mode"
object_id: geyser1_holiday_mode
icon: mdi:umbrella-beach
state_on: 0
state_off: 1
value_template: >-
{% if value_json['TuyaReceived'].DpType4Id2 is defined %}
{{ value_json.TuyaReceived.DpType4Id2 }}
{% else %}
1
{% endif %}
command_topic: "cmnd/tasmota_geyser1/TuyaSend4"
payload_on: "2, 0"
payload_off: "2, 1"
- platform: history_stats
name: Geyser1 Element Runtime
entity_id: sensor.geyser1_element
state: "ON"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0, microsecond=0) }}"
duration:
days: 1
sensors:
geyser1_element_runtime_rounded:
friendly_name: Element Runtime
icon_template: mdi:progress-clock
value_template: >
{{ (timedelta(hours=states('sensor.geyser1_element_runtime_2') | float(0)) | string)[:-3] }}
This is what my geyser lovelace configuration looks like. I use the custom Mushroom and apexcharts-card Frontend extensions installed from HACS.
Here is the yaml for that display.
type: vertical-stack
cards:
- type: custom:mushroom-title-card
title: Geyser 1
alignment: center
- type: horizontal-stack
cards:
- type: custom:mushroom-entity-card
entity: switch.geyser1_power
layout: horizontal
icon_color: red
tap_action:
action: toggle
entity: switch.geyser1_holiday_mode
layout: horizontal
icon_color: green
tap_action:
action: toggle
- show_name: true
show_icon: true
show_state: true
type: glance
entities:
- entity: sensor.geyser1_collector_temp
- entity: sensor.geyser1_temp
- entity: sensor.geyser1_element_runtime_rounded
state_color: false
columns: 3
cards:
layout: vertical
entity: sensor.geyser1_pump
layout: vertical
icon_color: red
- type: tile
entity: binary_sensor.geyser1_status
color: orange
vertical: true
show_entity_picture: false
- type: custom:apexcharts-card
apex_config:
chart:
height: 140%
yaxis:
- id: first
decimals: 0
apex_config:
tickAmount: 4
- id: second
opposite: true
decimals: 0
apex_config:
tickAmount: 1
graph_span: 10h
header:
show: false
show_states: true
colorize_states: true
series:
yaxis_id: first
stroke_width: 2
yaxis_id: first
stroke_width: 2
type: column
group_by:
func: avg
duration: 1min
stroke_width: 1
transform: 'return x === ''ON'' ? 1 : 0;'
yaxis_id: second
- type: history-graph
entities:
- entity: sensor.geyser1_error_code
This allows monitoring the temperatures, status of various components and control the element through home assistant.
I quite like the graph which shows the blue collector temp vs the orange geyser temperature. The red indicates the element runtime overlayed onto the temperature.
Enjoy!
I have the error outputs for the TSE model
(0 = No Fault) ("Earth_leakge", "Dry_burn", "Wt_sensor_fault", "Heating_loss", "Over_temp", "Water_leak", "Comm_failure", "Ct_probe_fault", "Pump_failure")
hopefully that will help you.
Could you possibly uide me on how to get the "geyser1.yaml" file loaded not sure if you jsut pasted this into your Configuration.yaml, or if you keep it as a seperate file?
thanks
Hi @Gaza84
I make use of the packages directive in the configuration.yaml file, have a look at this Packages - Home Assistant
Essentially I include all packages (.yaml files) placed in the folder called packages.
These are then loaded because I have the following in my configuration.yaml file.
homeassistant:
packages: !include_dir_named packages
I have found loading using studio code server extension makes it easy to create and edit these files.
thanks for the guidance! every day is a learning oppertunity, this helped me tidy up a few things.
Hi Andrew, sorry for this very late reply - I wish HA forum would send me an email for posts aimed at me.
I ended up using a ESP8266 for the job.
