I can raise one, the enable or disable of the timed export/discharge without switching mode all seem to be high level things you can do in the portal, so hopefully it sort of fits the criteria of being useful to more people than just me.
I don’t know what version of the inverter you have but mine is the G1 Hybrid 5kW with the 8.2kWh battery. Behaviour may vary between the different ones.
The way of using this efficiently will vary person to person, but for my purposes, this is what I do (with my thoughts in brackets):
02:00 - 05:00 - Timed Charged target 100% SOC (may as well always charge the battery as much as I can, just in case of bad weather).
05:00 - 14:00 - Eco Mode (Charge battery to full, then export, battery feeds house load as needed).
14:00 - 16:00 - Timed Charge target 50% SOC (Not really necessary but on the off chance the weather is really poor, this ensures I have enough battery to get through the peak window).
16:00 - 19:00 - Eco Mode + Timed Discharge (This combo appears to stop the battery charging but doesn’t export anything natively. Solar + battery feeds house load. Excess solar goes to grid export.
19:00 - 02:00 - Eco Mode (Back to BAU).
The reason I don’t want to necessarily always do Timed Export at 16:00 - 19:00 is because draining my battery to then use the grid later on doesn’t make sense both financially as well as for battery cycles. I get paid £0.36 per kWh in the peak window, and then I pay £0.34 after the peak period ends, but there are some losses in conversion between AC and DC. I think these net losses in energy would result in that being a loss.
Restricting the discharge rate to slow it down may also lead to grid being used so didn’t want to do that.
I’m a fairly heavy user as well, so essentially don’t have enough charge or panels producing to go too crazy with dumping energy to export.
What I have configured is a conditional export which (in addition to the list I put above) does a Timed Export in the 16:00 - 19:00 window only if the battery SOC is above 90%, and I want to stop it exporting if the battery reaches 70% SOC before 19:00 to preserve power for later. If this timed export finishes early, I want to go back into the previous Eco Mode + Timed Discharge mode.
To make this behave how I want with the Eco Mode + Timed Discharge today, I have told HA to run Activate Eco Mode, but then I need to go into the portal and enable the Timed Discharge slot again manually as I can’t automate that action.
This sounds like a lot of work, but this allows me to opportunistically export energy when I have some spare.
