I have successfully accessed my Reolink 810A cameras using Go2RTC via the HA Integration WebUI. I can see that there is an option to send an audio file and I believe that I can therefore use TTS.
I need some help with the coding to use TTS: and playing a Message to the camera please. My device stream URL is: rtsp://user:[email protected]/h264Preview_01_sub.
How do I address the camera in an automation to send a message via TTS?
I am still having an issue with 2 way audio on Lorex cameras when my NVR is in play.
If I wire the camera directly to my network switch I can set my configuration to go to the camera directly. In this scenario 2 way audio works properly, but when I have the camera connected to the NVR and access it through the NVR 2 way audio doesn’t work anymore.
Lorex has a lot of the same API’s as Dahua and after a ton of poking at this thing, I cannot spot where the NVR is changing any settings, but one thing I did notice is the ONVIF version is being downgraded through the NVR. Going to the camera direct it is 19.06, but going through the NVR causes it to downgrade to 18.12. At this point I’m drawing blanks on how to proceed as I don’t want to connect my cameras to my main network switch and would prefer them be connected directly to the NVR, but Lorex also does not appear to support bridge mode to make the cameras directly accessible from my main network.
Any tips on how to debug this further to determine what exactly the difference is between the two setups and determine if it’s something that is fixable?
Hi, I have a relatively cheap chinese cam with two rstp channels. One is SD and it works. The other channel is HD (which I would like to use), but I get the the message:
webrtc/offer: codecs not match: H265, AAC
I tried to use ffmpeg to transcode to H264 and opus, but this results in another message:
Thank you! This was the solution that finally worked for me, but I’m trying to understand why. I don’t understand how a standard iframe doesn’t work, but nested ones do…
Thank you Alexey. I have changed loglevel from info to verbose, but when I click on log (left colums in dashboard) I only get some info not related to go2rtc. dmsg in console goves me some errormessages related to bluetooth. Entering ‘journalctl’ in console results in ‘command not found’.
Подскажите пожалуйста я настроил go2rtc.yaml вот так.
Please tell me, I configured go2rtc.yaml like this.
Как мне отправить текст (TTS) или музыку (MP3) на камеру DoorBell?
Спасибо.
How can I send text (TTS) or music (MP3) to the DoorBell camera?
Thank you.
sorry, I apologize for the post but I’ve been trying for months and every time I go back with the hope of succeeding sooner or later but still nothing. I use webRTC camera integration version 2.3.1 and with these lines:
I’m trying to update the integration to the latest version, which is 3.1.0, but nothing works anymore if I do.
I state that I’m not very practical, in fact I’m very poor, but I also installed go2rtc and I also tried to insert the url of the camera there but I don’t see anything.
Did I miss some step to do? Are there any compatibility issues with hikvision? where am i wrong? Can anyone help me? I would just like to keep the integration updated in the hope that it will improve a bit since at the moment the video often doesn’t load and I have to refresh the page several times to get it started, but if I update then nothing works anymore.
thanks a lot to everyone.
