Unfortunately, part of the requirement for 2-way of that card is that it is a frigate backend camera. You can’t just use a regular go2rtc feed last I looked. Because of that, I am still using i-frame.
@conorlap thanks for the reply, much appreciated.
I’ve tried but gave up given the complexity in setting up the this card.
Any chance you can share some basic config + 2way audio ?
Are you running frigate or just the card with go2rtc ?
@calisro thanks for your reply, much appriciated.
I’ve tried the i-frame method, but it won’t work from within HA dashboard.
Straight in chrome the link works fine, maybe I’m missing something, I’ve read this whole thread few times - not sure what to check next…
Hey @Saxin , no problem! I’m running Frigate yeah.
Here’s my Frigate-card config with working 2-way audio:
type: custom:frigate-card
cameras:
- live_provider: go2rtc
frigate:
camera_name: frontdoor
camera_entity: camera.frontdoor
webrtc_card:
url: rtsp://192.168.0.22:8554/frontdoor?video=all&audio=all
ui: false
muted: true
go2rtc:
stream: frontdoor
modes:
- webrtc
view:
default: live
camera_select: live
dimensions:
aspect_ratio_mode: static
aspect_ratio: '4:3'
live:
controls:
thumbnails:
mode: none
media: clips
title:
mode: none
next_previous:
style: none
timeline:
mode: none
builtin: false
show_image_during_load: true
lazy_unload: hidden
draggable: false
zoomable: false
auto_unmute: never
media_viewer:
controls:
title:
mode: none
thumbnails:
mode: none
show_timeline_control: false
next_previous:
style: chevrons
builtin: true
auto_unmute: never
transition_effect: slide
auto_mute: hidden
draggable: false
zoomable: false
lazy_load: true
menu:
buttons:
frigate:
enabled: false
live:
enabled: true
clips:
enabled: true
snapshots:
enabled: false
download:
enabled: true
fullscreen:
enabled: false
timeline:
enabled: false
media_player:
enabled: false
image:
enabled: false
camera_ui:
enabled: false
cameras:
enabled: false
recordings:
enabled: false
substreams:
enabled: false
expand:
enabled: true
microphone:
enabled: true
priority: 42
alignment: opposing
type: toggle
mute:
enabled: true
alignment: opposing
style: overlay
position: right
media_gallery:
controls:
thumbnails:
show_details: false
show_favorite_control: true
filter:
mode: none
performance:
profile: high
I really do wish the frigate card would support non-frigate cameras for 2-way but it is what it is. For now till I have something else, the i-frame works well for me within lovelace but there are a few things you need to do.
- your url to go2rtc needs to be ssl like this and passed directly from a reverse proxy. I don’t know how you have HA setup but here is my setup.
Lovelace:
- type: custom:frigate-card-menu-icon
icon: mdi:phone-forward
title: Talk
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: Frontdoor Call
content:
type: iframe
url: >-
/go2rtc/webrtc.html?src=frontdoor_call&media=video+audio+microphone&key=XXXXXXXXXXXXXXXXXXXXXXXXX
aspect_ratio: 75%
In order for that to work, i use go2rtc through a reverse proxy and I proxy that on the same port as home assistant itself but in a subdirectory of ‘/go2rtc’ (look at the link above)
I use nginx proxy manager and this the config to make that work:
All that does is pass ssl for that url directly to go2rtc port. I use that ‘key’ which is just a random long string of characters that match the lovelace entry. You don’t need to use it but there is no security with this method. So this works to obscure it.
- your camera needs to have a video/audio that go2rtc supports. I have a AD410 and changed it with a 3rd party tool since the app doesn’t let you change the codec. YMMV
I’m running Frigate too. I have added your card (tnx btw), but how do I push to talk? I have a reolink videodoorbell which should support this. Or is it when you click the card it should just open an audiostream?
I never see a talk button or something. I’m really confused. Everybody seems to be able to get this working
go2rtc code:
go2rtc:
streams:
deurbel_sub:
- http://192.168.2.5/flv?port=1935&app=bcs&stream=channel0_sub.bcs&user=admin&password=password
- ffmpeg:deurbel_sub#audio=opus
camera code:
camera:
deurbel:
live:
stream_name: deurbel_main
ffmpeg:
hwaccel_args: preset-vaapi
inputs:
- path: rtsp://127.0.0.1:8554/deurbel_main?video=copy&audio=aac
input_args: preset-rtsp-restream
roles:
- record
- path: rtsp://127.0.0.1:8554/deurbel_sub?video=copy
roles:
- detect
I’m using NGINX proxy manager to make an SSL entry of it. Websockets are configured/ enabled. But still when going to https://frigate.domain.name with either Edge or Chrome on my Win11 laptop, I can’t get the stream goging. It keeps loading the stream.
Any idea of what i’m doing wrong?
edit -----
Just read some advise to switch to host network_mode on my frigate server. This seems to work a lot better, don’t understand why because all ports were opened. But, going to try more in comming few days.
You need to add the rtsp stream also for 2-way audio:
go2rtc:
streams:
deurbel_sub:
- rtsp://admin:[email protected]:554/h264Preview_01_main
going to try later this week, thanks
You using HTTP-FLV as main source. Is RTSP also awful for this model like other Reolink cameras?
Yeah, HTTP-FLV is much more stable than RTSP on the Reolink doorbell.
I now have the following:
deurbel_sub:
- http://192.168.22.52/flv?port=1935&app=bcs&stream=channel0_sub.bcs&user=admin&password=password
- rtsp://admin:[email protected]:554/h264Preview_01_sub
The RTSP stream opens in VLC player so is correct.
With EDGE i can talk now. Only the record button doesn’t show up with the frigate card. I have copied the config above.
What I just don’t understand is it only works with https. When I browse to my ha instance it is https://ha.domainname.xxx which just works great. So both internally and externally it is a secure site. In the frigate card I type the IP address, how does Ha know it has to proxy that? Or does it just do that?
I don’t get a question in edge to allow microphone either, so it doesn’t seem to be requesting access. Should do that right?
with the microphone always connected the ring on the doorbell doesn’t light up blue like it does when going to the webpage from go2rtc.
Hey there,
quick question, Everything operates properly I am able to receive video and two-way audio, and I can answer and end calls via a web browser. (utilizing a frigate card with go2rtc)
But when I attempt the same via my iPhone, I can only listen but not speak.
In Settings → Home Assistant, there is no toggle option for the microphone, so I assume it is disabled.
any idea guys?
Thanks a lot much appreciated, I will try that.
Hey @conorlap thanks a lot the info I will give Frigate a try.
Hey guys,
Got a new tablet to be used as HA dashboard, it’s Lenovo P11, TB-J606F. Tablet is nice good specs and nice screen but…
It won’t play any stream via. HA app I get black screen:
Stream info:
“producers”: [
“type”: “RTSP active producer”,
“url”: “rtsp://192.168.88.20:554/cam/realmonitor?channel=1\u0026subtype=0/”,
“remote_addr”: “192.168.88.20:554”,
“user_agent”: “go2rtc/1.6.2”,
“medias”: [
“video, recvonly, H.264 Main 5.0”,
“audio, recvonly, PCMA/8000”,
“audio, sendonly, PCMA/8000”
“receivers”: [
“96 H264, bytes=4543757, senders=2”,
“8 PCMA/8000, bytes=173120, senders=2”
“recv”: 4765237
“consumers”: [
“type”: “WebRTC/WebSocket async passive consumer”,
“remote_addr”: “udp4 prflx 192.168.88.104:42673 related :0”,
“user_agent”: “Mozilla/5.0 (Linux; Android 11; Lenovo TB-J606F Build/RKQ1.210303.002; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/115.0.5790.166 Safari/537.36 Home Assistant/2023.8.2-10992 (Android 11; Lenovo TB-J606F)”,
“medias”: [
“video, sendonly, VP8, RTX, VP9, AV1, H264, RED, ULPFEC, FLEXFEC-03”,
“audio, sendonly, OPUS/48000/2, RED/48000/2, G722/8000, PCMU/8000, PCMA/8000, CN/8000, TELEPHONE-EVENT/48000, TELEPHONE-EVENT/8000, L16, PCML”
“senders”: [
“102 H264, bytes=4401876, receivers=1”,
“8 PCMA/8000, bytes=170880, receivers=1”
“send”: 4622968
“type”: “MSE/WebSocket passive consumer”,
“remote_addr”: “192.168.88.104, 127.0.0.1:45334”,
“medias”: [
“video, sendonly, H264, H265”,
“audio, sendonly, MPEG4-GENERIC, PCMA, PCMU, L16, PCML”
“senders”: [
“96 H264, bytes=4401876, receivers=1”,
“8 FLAC/8000, bytes=170560, receivers=1”
“send”: 4624898
It won’t play stream via. Chrome either go2rtc webui - stream:
Stream info:
“producers”: [
“medias”: [
“receivers”: [
“96 H264, bytes=37843531, senders=2”,
“8 PCMA/8000, bytes=1040000, senders=2”
“recv”: 39261075
“consumers”: [
“remote_addr”: “udp4 host 192.168.88.104:60146”,
“user_agent”: “Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36”,
“medias”: [
“senders”: [
“102 H264, bytes=37843531, receivers=1”,
“8 PCMA/8000, bytes=1040000, receivers=1”
“send”: 39309339
“remote_addr”: “192.168.88.104:43974”,
“medias”: [
“audio, sendonly, MPEG4-GENERIC, PCMA, PCMU, L16, PCML, OPUS”
“senders”: [
“96 H264, bytes=37843531, receivers=1”,
“8 FLAC/8000, bytes=1040000, receivers=1”
“send”: 40628829
I’m a bit lost here any guidance what can be done is much appreciated guys.
Try to check low res link. Main5 is hi profile. Some cheap or old devices may not handle it.
@AlexxIT - you are absolutely right, using substream or dropping main stream to 1080P makes it work and shows as H.264 Main 4.0.
I’m stocked as I have old samsung Galaxy S9 which displays the 5.0 profile fine.
What a shame Lenovo…and even more shame as it’s 100% software thing.
I guess transcoding video is not an option to have all devices have the high res and only tablet lower (1080P) ?
Hi, any idea if it is possible by go2rtc and how to extract only audio from stream, so I can cast it to Google Home Mini?
I already tried to proxy it through HAProxy, so it will be behind SSL, checked all possible options displayed in links, without luck.
ffmpeg:rtsp://127.0.0.1:8554/garage_main?audio
what url do you send to google home? http or https?
