Just tried out the iframe, I can get the video feed but unfortunately I can’t get 2-way communication working via my HA instance.
I’ve got 2-way communication working through the direct link to the camera: https://mydomain.org/go2rtc/webrtc.html?src=frontdoor
Does your camera use profile T for communication? What make/model is it? I didn’t do anything special for it to work. It travels along with the video so I doubt its getting blocked.
It’s an Amcrest AD410 doorbell, I think it’s profile T yeah!
2 way communication definitely works when I use the direct go2rtc link that I’ve exposed via swag/nginx: https://mydomain.org/go2rtc/webrtc.html?src=frontdoor
That’s my exact camera and it works great with 2-way. Hm Wonder what’s going on with yours. Maybe a browser permission issue? You try it in chrome? It works for me though in the companion app and chrome both via iframes.
Hi, I have an AIO which i plan to be used for lovelace, 4 cams frigate (direct on debian) and HA supervised…
The AIO is n4020 based and without HA its already hitting 80-90% with nativefier - made browser running 2 webrtc streams…
So,
I was wondering if this could help me reduce cpu usage detection by frigate… or browser running webrtc streams… if its possible care to elaborate?
Especially for the first one… cpu detection takes about 60-70%. I’m waiting for coral to be available at reasonable price but if this could help then i’d gladly try it.
go2RTC has been a great improvement overall in terms of video latency and CPU usage on the backend. However, I am seeing an issue with the video feeds are freezing on my lovelace dashboard after a certain period of time, usually a few hours. A refresh of the page resolves the issues. I don’t have to restart the go2rtc container. I’m using the cameras passed from the Frigate integration. I thought it might be that the computer seeing the issue was on WiFi, but it happened to another computer hardwired in.
Chrome Web Browser
Frigate Card
Is anyone else seeing this? What should my next steps be to provide information for troubleshooting the issue?
This is a pure coincidence, I noticed the same this morgning for a longer period of time and was planning to post this too.
I’m using go2rtc for a while now, just plain RTSP camera’s into the integration (manually added), 4 camera’s originate from the mqtt-ring plugin (but no live feed on my loveance dashboard), and they keep working but the one from my Foscam experiences exactly the same as @rogerquake is describing (this one has a live feed on my dashboard). The loveance card doesn’t work anymore. There is just no image. Refreshing page sometimes helps, but not always. Sometimes I need to restart the HA container, sometimes the Go2RTC container helps. There is no apparent error in the logs of the Go2RTC neither is there any entry in the logs of HA.
I’m using an iPad, iPhone and Windows 11 with Chrome as endpoints. They all have the same issue. My question would be the same; how do I go into troubleshooting mode. I already have added the logging part to Go2rtc, but nothing goes by. And besides that; my best bet would be it has more to do with the loveance card than Go2rtc.
I was trying to get iframes to work, but I’m having some trouble exposing the api using nginx. The iframe works great if I use the local link, http://192.168.0.201:1984/webrtc.html?src=baby_cam_1, but that obviously doesn’t work remotely.
I tried exposing 192.168.0.201:1984 as a subdirectory of my domain using nginx and wasn’t able to get it working. I’m guessing there may be some special nginx settings that I have to put in, but I’m not sure exactly which. I tried setting the custom location without any special settings and got a 404 error. I then tried the following settings and also got a 404 error.
Hey @nprez83 , this is how I’ve got mine setup and it works. Although I can’t get 2-way audio via Home Assistant yet (However, 2 way audio works by going directly to the url: https://mydomain.org/go2rtc/webrtc.html?src=frontdoor )
I just need to figure out how to get 2 way audio working through Home Assistant!
I’m guessing that has to do with how you have your cameras added to home assistant. If you use an iframe it should be the same as just using this directly.
Yeah I’m aware it needs to be https for microphone to work, my cert is also letsencrypt - I’m using the Swag docker container for my nginx reverse proxy solution.
I’ve attempted the iframe & 2-way audio on both Firefox & Edge on Mac and Android Companion app & Chrome on my phone. None of them work, I just see the video feed but no 2-way communication.
This is perfect! Works like a charm. Between having my iframes working now, and the recent fix to the Nest audio in beta 6, I now have two options for my cameras:
Skip the RTSPtoWeb integration, use built in conversion for Nest cam, and iframes for my Foscams
Use RTSPtoWeb integration, which allows the Foscams to work right off the bat, and use transcoding for Nest Cam.
In order for this to work without the rewrite, I Believe you would have had to change your ‘basedir’ for the api in the go2rtc config. Revert it and try the rewrite I used instead.
