Nothing fancy.
frontdoor_send:
- rtsp://xxxxxx:[email protected]/h264Preview_01_main
- ffmpeg:{input}#audio=opus
Nothing fancy.
frontdoor_send:
Ah, I see. Are you using the Frigate integration in Home Assistant or stand alone Frigate? I have the stand alone Frigate and canāt seem to send tts to my doorbell. But reading through the docās, it looks like the steam setting needs to be configured in the go2rtc.yaml file which I donāt have. Do you know if I create one manually if this would work or does this only apply to Frigate integrated?
I donāt use frigate as a backend. I only use the frigate card and a regular go2rtc installation. I would guess that if you created a go2rtc config in frigate, it work work similarly.
Okay thanks. Iāll give it a try.
Did you figure this out? I just canāt figure out what to put in the stream object.
Iām running frigate in docker so I canāt think of what makes sense to go here!
Where did you define your frontdoor_send? Is this part also in your yaml.config?
can you elaborate how you did this? all i want to achieve is for my doorbell to play a ding dong sound whenever the doorbell button is pressā¦ the ding_dong audio file is locally available in my HA upload folder.
