I’ve added in the following so i can get an update every 5mins.
import datetime
from datetime import timedelta
MIN_TIME_BETWEEN_UPDATES = timedelta(minutes=5)
import datetime
Can you share the information? I have some time until Monday to work on this.
Works awesome man! Thanks @TimmyBankers
I added the code in this repository (cleaned up a bit).
Also found out that the scraping interval can be configured with config setting: scan_interval
, and no code changes are required.
I have 2 inverters but sensor is showing status only one of them
@jojoro, I think the json parsing part of the code just takes the first element of a list somewhere. This means the current code only supports the first inverter. Feel free to update the code.
Hello Everyone. I wish I could contribute, your work is amazing.
I am however a complete beginner. I have managed to get this working though.
Is it possible to display only some of the many attributes on the UI ?
Lets say PV voltage and current for example.
Hello all,
I am also very new to Home Assistant, only a few weeks.
I have also managed to get this working.
It is possible to display only some atrributes on the UI.
I use this method:
platform: template
sensors:
invertersn:
value_template: “{{ states.sensor.sems_portal.attributes.sn }}”
pvvoltage1:
value_template: “{{ states.sensor.sems_portal.attributes.vpv1 }}”
pvvoltage2:
value_template: “{{ states.sensor.sems_portal.attributes.vpv2 }}”
I don’t know if this is the correct method but it will display the attributes sn,vpv1, vpv2
I hope this will help you a little more.
Hallo Bart
Thank you very much, it work perfectly
You can use also the custom:state-attribute-element to get this info out of the sensor.sems_portal
(so that it wouldn’t create a sensor for every attribute you want to show)
https://github.com/custom-cards/state-attribute-element
Kind regards,
Bart
Thanks Bart,
This works great!
Do you know if there is a way to return the value from each attribute as a number rather than as a text string?
I’d like to be able to graph the output over a period of time.
Just create a sensor.
See below for my implementation (the spellingmistakes are intentional!)
## Goodwe Inverter sensor
- platform: sems
username: 'your_id'
password: 'your_pw'
scan_interval: 900
sensors:
pv_eday:
value_template: '{{ states.sensor.sems_portal.attributes.eday }}'
unit_of_measurement: 'kWh'
friendly_name: "PV productie vandaag"
pv_temperature:
value_template: '{{ states.sensor.sems_portal.attributes.tempperature }}'
unit_of_measurement: '°C'
friendly_name: "Temperatuur Inverter"
pv_thismonthetotle:
value_template: '{{ states.sensor.sems_portal.attributes.thismonthetotle }}'
friendly_name: "Totaal deze maand"
pv_lastmonthetotle:
value_template: '{{ states.sensor.sems_portal.attributes.lastmonthetotle }}'
friendly_name: "Totaal t/m vorige maand"
pv_output_power:
value_template: '{{ states.sensor.sems_portal.attributes.outputpower }}'
unit_of_measurement: 'W'
friendly_name: "PV power"
Issues after upgrading to 0.92? See here: https://github.com/TimSoethout/goodwe-sems-home-assistant/issues/3
Did this work for you? I cant get it working. Could you possible share you files?
I see I made a small typing mistake, the first needed {
is not shown, sorry about that.
"domain": "sems",
"name": "Goodwe SEMS scraper",
"documentation": "https://github.com/TimSoethout/goodwe-sems-home-assistant",
"dependencies": [],
"codeowners": [],
"requirements": []
The issue-text on github has also been corrected.
Thanks, I had already added the { but I also made a typo I now corrected. It’s working again.
Any plans to change this from a scraper to a REST API call?
Documentation:
http://au.sems.com.cn:82/swagger/ui/index
E.g.
curl -X POST --header 'Accept: application/json' --header 'token: {"uid": "[redacted]","timestamp": 1558143769193,"token": "[redacted]","client": "web","version": "","language": "en-GB" }' 'http://au.semsportal.com:82/api/v2/Common/GetApis'
Payload
"language": "en-gb",
"function": null,
"hasError": false,
"msg": "success",
"code": "0",
"data": [
"http://au.semsportal.com:82/api",
"http://eu.semsportal.com:82/api",
"http://hk.semsportal.com:82/api",
"http://192.168.1.114:8080/api",
"http://192.168.1.114:8888/api",
"http://192.168.90.32:8821/api"
"components": {
"para": "{}",
"langVer": 4,
"timeSpan": 0,
"api": "http://au.semsportal.com:82/api/v2/Common/GetApis"
I’ve used the native REST API… limitation here is I can’t authenticate first to get the token, and then query, so token is set in config (not sure if this times out, so best would be to write a proper sensor to authenticate as required. I think it will invalidate the token once you log into the site manually. Also I look at specific array elements, better to loop through them within a proper sensor component. As test case, I am extracting the entire data payload (i.e. you can see it from Developer Tools > States) but only parse 3 of them (the ones I am interested in) Also converting W to kW. Note I am in Australia, hence I am using the au API. Again, not something I would use as the token can get invalidated due to the limitations of using the REST component, and not a custom component.
my configuration.yaml
# get token here http://au.semsportal.com:82/swagger/ui/index#!/CommonController/CommonController_CrossLogin_0 > v2 > POST /api/v2/Common/CrossLogin
# get powerStationId by logging into SEMS portal, the url would end with it, e.g. https://www.semsportal.com/PowerStation/PowerStatusSnMin/abcdef01-ab12-abdb-abcd-01ab12bc2367
- platform: rest
json_attributes:
- data
resource: http://au.semsportal.com:82/api/v2/PlantManage/GetPlantMonitor
headers:
Content-Type: application/json
token: '{"uid": "[redacted]","timestamp": 1558147862443,"token": "[redacted]","client": "web","version": "","language": "en" }'
method: POST
payload: '{"powerStationId": "[redacted]" }'
value_template: '{{ value_json.data.location }}'
sensors:
goodwe_inner_temperature:
friendly_name: Inner Temperature
value_template: '{{ states.sensor.goodwe_inverter.attributes.data.snIndexs[0].indexs[4].rowValue | float | round(2) }}'
unit_of_measurement: "°C"
goodwe_output_power:
friendly_name: 'Output Power'
value_template: '{{ states.sensor.goodwe_inverter.attributes.data.snIndexs[0].indexs[5].rowValue | float / 1000 | round(2) }}'
unit_of_measurement: "kW"
entity_id: sensor.goodwe_inverter
goodwe_output_voltage:
friendly_name: Output Voltage
value_template: '{{ states.sensor.goodwe_inverter.attributes.data.snIndexs[0].indexs[6].rowValue | round(2) }}'
unit_of_measurement: "V"
I’ve created a new custom component which uses the SEMS REST API. Its an ‘API adaptation’ of the component from TimmyBankers (above). You can find it here: https://github.com/hesselonline/sems, let me know if you have any issues (or not;))
Thank you @hesselonline, your component is working very well!
