Goodwe rest sensor for multiple json elements
Hey Mate,
Not sure if you have heard of Node Red - but it will easily enable you to query the SEMS portal and drag down what you need.
I can provide you with a template to pull down all the data and you can then get it across to HA through either MQTT or the embedded entities
Craig
Hi Craig,
Now and then I notice an email showing this thread is still active. While my priority shifted elsewhere I’m sure templates are welcome for anyone. I would suggest to use GitHub, post your template there, and share some Node love.
If anybody is still interested, I did a rewrite of the HA SEMS component. Its at about 90% now, will also support the new energy dashboard. Will upload it to my github when done.
Just to let you and the rest know. “My” component, which you based your initial version on, also has some new features including the energy dashboard:
  • uses the API nowadays,
  • supports energy dashboard,
  • supports multiple inverters,
  • (HA compliant) async component, and
  • configurable via component flow.
(I hope this does not come off too much as a brag. Feel free to use the code as inspiration as well.)
Hi, I did not know that. Will have a look → might take some inspiration from the multiple inverter part :wink:
