Ah thankyou! Im on the latest 0.83.3
Where do you place the long lived access token? Been trying to do this with webhooks and canāt find the solution, as IFTTT webhooks have no Headers field
The IFTTT integration gives you the URL to use with the token
which integration are you using? IĀ“m using google assistant with webhooks, and thereās no place to use the tokenā¦
Thanks for the quick reply
I donāt understandā¦ If you are using IFTTT and Google Assistant itās nothing to do with HA anywayā¦ If you are using GA to control IFTTT then you will need to have the HA webhook in the actionā¦
I just tried adding the IFTTT integration and it wonāt add it (Iām on beta 0.84)ā¦ Not sure why. I thought it gave you a webhook with the IFTTT token and a json exampleā¦
Sry, I didnāt explain what I was trying to achieve. Iām trying to call a script on HA with GA, and Iām using IFTTT for that, with the GA applet and the webhooks trigger to send the request to the HA API.
The problem is that IFTTTās webhook trigger has no Headers field, thus I cannot authenticate my request against HA
I donāt understandā¦ I just got the integration to workā¦
Then at IFTTT
So you enter the URL and then JSON for the service and parametersā¦ Does that not work?
Now I got it! I wasnāt aware there was an IFTTT component, silly me xb Before the ānewā authentication mechanism in HA i used to call the scripts through HA REST api with HTTP basic auth, and only recently upgraded to the HA latest version. Guess IĀ“ll have to try this way. Thanks for your help
OKā¦ thatās what I meant by adding the IFTTT integration!
My bad ;b I thought you were talking about a HA Applet on IFTTT xb been around this issue for too long, time to disconnect for now. Thanks again
This thread seems to have taken a turn to IFTTT, but Iām stuck on the Access Token for integrating Google device sensors into HA. Everything else is connected and working - I can see my HA devices in the Google Home app and devices respond to voice requests as expected, but this token field has me stumped. Where do I get the token from? From Google? From Home Assistant? Is it a Long Lived Token?
Is āhttps://myservername.duckdns.org:8123/api/google_assistant?[long lived token from HA here]ā not correct? What am I missing?
Sadly no. Iāve tried and failed many times with information provided at the beginning of this thread, and Google search results offer very little information.
Iāve come a long way with python in just a few days and was able to run the script. It appears to be working, but debug log shows itās failing at device_id. Why?
# Optional Overrides (Set to None to ignore)
device_id = None
master_token = None
access_token = None
[*] Getting master token...
[!] Could not get master token.
[*] Master token: None
[*] Getting access token...
[!] Could not get access token.
[*] Access token: None
[*] Done.
PS C:\Users\admin\Desktop>
I tried a lot. get latest python v3.12.0 installed. run pip install gpsoauth - Ok. copy text of get_tokens.py raw text, saved to my pc. Change username to my google username full email address. password section, tried with app password generated by Google security. (note: it is 16 chars. google displayed with 4 sets with space in between. I tried with space or without). Even I turned off google 2 way auth method, so I can use my google password instead. I always get āCould not get master tokenā, āMaster token:Noneā , āCould not get access tokenā, āAccess token:Noneā donāt know why? Anyone can help?
