Should be 2x - signs… --card-background-color
OR just add the variable back in the theme.
perfect, added it back to theme, now its dark again
what did and where did you add back to the theme to fix the white issue ?
i used version 1.6
Is it me or don’t I understand anything of this. Can’t this change just be deployed in the next update of the theme?
I’ve just installed this theme and I am really happy with it. However I do have one question. How do I get different colors to appear for chart lines on my Sensor cards (as shown in the original screenshots)? All of mine appear orange. I’m guessing this may be an additional plugin or something else?
It’s not a problem with the theme it is a problem with the custom card. The theme developer (prematurely) removed a variable still being used in custom cards but it is the custom card is what needs to be updated, not the theme. It was a poorly timed rush to change something with no benefit…
Thank you for the explanation. I’ll stick around and wait then.
I installed with HACS, restarted and the theme doesn’t appear in any profile. Is there a trick to showing this?
Hi, I can’t find anything in this thread regarding changing the color of active icons. They appear grey when they are turned on and blue when they are turned off. How do I change the grey to a yellowish?
Did you find out how to change? Because i am looking for that exact same thing.
No unfortunately not
