Is there any way to change the measurement units from metric to imperial for us ‘freedom unit’ impaired folks? I’m sure it could be done with templates, but it seems like the sensor should use the HA unit_system setting.
I’m getting the following error:
2020-04-18 19:26:52 ERROR (MainThread) [homeassistant.components.sensor] google_fit: Error on device update!
File "C:\Python38\lib\site-packages\homeassistant\helpers\entity_platform.py", line 312, in _async_add_entity
await entity.async_device_update(warning=False)
File "C:\Python38\lib\site-packages\homeassistant\helpers\entity.py", line 476, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "C:\Python38\lib\concurrent\futures\thread.py", line 57, in run
File "C:\Python38\lib\site-packages\homeassistant\util\__init__.py", line 240, in wrapper
result = method(*args, **kwargs)
File "C:\Users\stefa\AppData\Roaming\.homeassistant\custom_components\google_fit\sensor.py", line 396, in update
height_datasources = self._get_datasources('com.google.height')
File "C:\Users\stefa\AppData\Roaming\.homeassistant\custom_components\google_fit\sensor.py", line 303, in _get_datasources
datasources_request = self._client.users().dataSources().list(
AttributeError: 'NoneType' object has no attribute 'users'
I tried to remove the pycache and restart, but the error is still the same…
After restarting HomeAssistant, you should se a notification such as:
In order to authorize Home-Assistant to view your Google Fit data you must visit: https://www.google.com/device and enter code: XXXX-XXXX
After following this step and restarting Home Asssistant, no errors in the log. Eyerything works fine.
“Freedom Unit” template sensor templates if still needed:
sensors:
sensor_weight:
friendly_name: "weight"
unit_of_measurement: 'lbs'
value_template: "{{ (states('sensor.sensor_weight') | float * 2.20462262185) | round }}"
icon_template: mdi:weight-pound
sensors:
sensor_distance:
friendly_name: "distance"
unit_of_measurement: 'mi'
value_template: "{{ (states('sensor.sensor_distance') | float / 1.609) | round(2) }}"
icon_template: mdi:map-marker-distance
This works great, I’m digging it a lot! Hopefully this post helps anyone facing syncing issues… I use Fitbit and ended up needing to utilize a third party app to push my data over to Google Fit called FitToFit. Worked wonders syncing everything nice and easy, although I’m sure google will eventually make the sync more streamlined if they ever close on the Fitbit acquisition… FittoFit worked as an interim solution for me.
Disclaimer: I’m a total novice at this but if I can do it anyone can, hopefully the config can keep inspiring others as you have inspired me!
cards:
- type: picture-elements
title: Google Fit
elements:
- type: image
image: /local/g_f.png
style:
width: 70%
top: 50%
left: 50%
filter: blur(3px) brightness(80%)
- type: state-label
entity: sensor. s_calories
style:
top: 40%
left: 50%
font-size: 14px
filter: brightness(140%)
- type: state-icon
style:
top: 20%
left: 47%
'--iron-icon-height': 70px
'--iron-icon-width': 70px
'--paper-item-icon-color': white
- type: state-label
entity: sensor. s_weight
style:
top: 80%
left: 50%
font-size: 14px
- type: state-icon
style:
top: 60%
left: 47%
- type: state-label
entity: sensor. s_sleep
style:
top: 80%
left: 83%
font-size: 14px
- type: state-icon
style:
top: 60%
left: 80%
- type: state-label
entity: sensor. s_heart_rate
style:
top: 80%
left: 18%
font-size: 14px
- type: state-icon
style:
top: 60%
left: 15%
- type: state-label
entity: sensor. s_steps
style:
top: 40%
left: 18%
font-size: 14px
- type: state-icon
style:
top: 20%
left: 15%
- type: state-label
entity: sensor. s_move_time
style:
top: 40%
left: 83%
font-size: 14px
- type: state-icon
entity: sensor.s_move_time
style:
top: 20%
left: 80%
image: /local/gradient_background_1440x900_24bit.png
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: sensor
graph: line
- entities:
- entity: sensor. s_steps
hours_to_show: 168
line_color:
- yellow
icon: 'mdi:walk'
refresh_interval: 0
type: 'custom:mini-graph-card'
cards:
- entities:
- entity: sensor. s_heart_rate
hours_to_show: 24
line_color:
- green
icon: 'mdi:heart'
refresh_interval: 0
- entities:
- entity: sensor. s_calories
hours_to_show: 24
line_color:
- red
icon: 'mdi:food'
refresh_interval: 0
cards:
- entities:
- entity: sensor. s_move_time
hours_to_show: 24
line_color:
- orange
icon: 'mdi:clock-outline'
refresh_interval: 0
- type: sensor
entity: sensor.s_sleep
icon: 'mdi:google-fit'
path: google-fit
title: Google Fit
Where can i find the repo for this custom component?
Everything worked fine with google fit ( https://github.com/vmanuel/hacs-google-fit ) until updating to 0.109.0. Now i get a lot of errors in the log. However, the sensor still works.
2020-04-30 19:04:56 ERROR (MainThread)
[homeassistant.components.websocket_api.http.connection.2770256720] Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 20, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/frontend/__init__.py", line 550, in websocket_get_translations
msg.get("config_flow"),
File "/usr/src/homeassistant/homeassistant/helpers/translation.py", line 329, in async_get_translations
resources = flatten(resource_func(results[0], components, category))
File "/usr/src/homeassistant/homeassistant/helpers/translation.py", line 127, in merge_resources
new_value = translation_strings[component].get(category)
KeyError: 'sensor.google_fit'
2020-04-30 19:04:58 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2770202000] Error handling message: Unknown error
2020-04-30 19:04:59 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2796357232] Error handling message: Unknown error
If you used HACs to deploy as a custom rep, I had some weird behavior getting to work initially… Instead, I uninstalled it from HACs and just copied the files over to custom_components, like so:
Created a google_fit.yaml under the sensor folder(if you have a split up config):
No errors, just updated to 0.109.2
Awesome, works perfectly! Any chance Heart Points could be added?
Ok, I am having a go at adding Heart Points by modifying the sensor.py file…
This is what I have so far…
Add (under # Google Fit API URL.)…
HEARTMINUTES = 'heart points'
Then (under add_devices)…
GoogleFitHeartMinutesSensor(client, name),
Lastly (inserted somewhere in the list of class sensors)…
class GoogleFitHeartMinutesSensor(GoogleFitSensor):
DATA_SOURCE = "derived: com.google.heart_minutes:" \
"com.google.android.gms:merge_heart_minutes"
@property
def _name_suffix(self):
"""Returns the name suffix of the sensor."""
return HEARTMINUTES
@property
def unit_of_measurement(self):
"""Returns the unit of measurement."""
return HEARTMINUTES
@property
def icon(self):
"""Return the icon."""
return 'mdi:heart'
@util.Throttle(MIN_TIME_BETWEEN_SCANS, MIN_TIME_BETWEEN_UPDATES)
def update(self):
"""Extracts the relevant data points for from the Fitness API."""
values = []
for point in self._get_dataset(self.DATA_SOURCE)["point"]:
if int(point["startTimeNanos"]) > _today_dataset_start():
values.append(point['value'][0]['fpVal'])
self._last_updated = time.time()
self._state = sum(values)
_LOGGER.debug("Heart Points %s", self._state)
self._attributes = {}
The above seems to be working (after a lot of messing around - trial and error style - the worst style!).
Can you please share images from your config?
Thanks.
I have done as ctowers recommended to install.
I had already done the 1st step when I set up my calender.
In order to generate your client_id and client_secret, see the prerequisites for Google Calender component: https://www.home-assistant.io/components/calendar.google/#prerequisites
I then enabled the Fitness API
To make sensor work you have to enable Fintness API in your project. In oder to enable Fitness API open Google cloud console: https://console.cloud.google.com/apis/library/fitness.googleapis.com and enable API.
I presume I use the same client_id and client_secret as I have with my calender?
I then continued to configure my /config/configuration.yaml
- platform: google_fit
client_id: redacted
client_secret: redacted
After restarting HA I did the following
After following this step and restarting Home Asssistant, I get the following errors in my log.
Log Details (ERROR)
Logger: homeassistant.components.sensor
Source: custom_components/google_fit/sensor.py:253
Integration: Sensor (documentation, issues)
First occurred: 14:21:35 (1 occurrences)
Last logged: 14:21:35
Error while setting up google_fit platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 186, in _async_setup_platform
await asyncio.gather(*pending)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 295, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 446, in _async_add_entity
entity.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 297, in async_write_ha_state
self._async_write_ha_state() # type: ignore
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 324, in _async_write_ha_state
attr.update(self.device_state_attributes or {})
File "/config/custom_components/google_fit/sensor.py", line 253, in device_state_attributes
return self._attributes
AttributeError: 'GoogleFitWeightSensor' object has no attribute '_attributes'
What am i missing?
FYI: in case someone was using it. I am hiding (as private) my version of the Google Fit custom component
I think no one was using it as there were solutions built on top of mine (and others) with more sensors attributes. However, if you were using it, the Gist is still available.
This is a small protest against not having a YAML (or equivalent non-UI configuration) support mode for integrations (reference).
Hi all,
Not sure if somethings changed but for steps and anything with a “during the day” setting there is a “bucketByTime”: { “durationMillis”: 86400000 } as well as the start, finish time. I think is why my steps go down and up, and then when I relax at the end of the day I finally get something close to my steps. I’ve tried but my python is not good - how do I add this in?
Here’s where it goes
"aggregateBy": [{
"dataTypeName": "com.google.step_count.delta",
"dataSourceId": "derived:com.google.step_count.delta:com.google.android.gms:estimated_steps"
"bucketByTime": { "durationMillis": 86400000 },
"startTimeMillis": 1438705622000,
"endTimeMillis": 1439310422000
I use to get information regarding deep and light sleep…now its never shown anymore… Any ideas?
This is a good idea. I think I’ll make my config and blog go dark in protest too
Any updates on making this official?
Ok, care to share how you did that?
