Sorry, thought I had attached it in my previous post.
Config
panel_iframe:
guages:
title: Guages
url: http://192.168.200.210:8123/local/google-guages.html
icon: mdi:speedometer
google-guages.html
<!DOCTYPE html>
<html lang="en">
<head>
<title>Home Assistant Google Guages using WebSockets</title>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, minimum-scale=1.0, initial-scale=1.0, user-scalable=yes">
<meta name="description" content="A web interface for Home Assistant with WebSocket and Google Guages">
<script src="https://www.gstatic.com/charts/loader.js"></script>
<script src='https://cdnjs.cloudflare.com/ajax/libs/lodash.js/4.17.4/lodash.min.js'></script>
<script src='https://unpkg.com/[email protected]/dist/haws.umd.js'></script>
<style>
.flex-container {
padding: 0;
margin: 0;
list-style: none;
-ms-box-orient: horizontal;
display: -webkit-box;
display: -moz-box;
display: -ms-flexbox;
display: -moz-flex;
display: -webkit-flex;
display: flex;
.wrap {
-webkit-flex-wrap: wrap;
flex-wrap: wrap;
.flex-item {
padding: 0px;
width: 150px;
height: 150px;
margin: 5px;
line-height: 150px;
color: white;
font-weight: bold;
font-size: 1em;
text-align: center;
</style>
<script type="text/javascript">
function make_options(max) {
return {
width: 150, height: 150,
greenFrom: 0.25*max, greenTo: 0.5*max,
yellowFrom: 0.5*max, yellowTo: 0.75*max,
redFrom: 0.75*max, redTo: max,
minorTicks: 5,
max: max
//var URL = 'ws://' + location.host + '/api/websocket';
var URL = 'ws://192.168.200.210:8123/api/websocket';
var guages = {
"sensor.disk_use_home": {name: "Disk GB", div: "guage0_div", options: make_options(56)},
"sensor.memory_use": {name: "Ram MiB", div: "guage1_div", options: make_options(1000)},
"sensor.memory_free": {name: "Ram MiB", div: "guage2_div", options: make_options(1000)},
"sensor.processor_use": {name: "CPU %", div: "guage3_div", options: make_options(100)},
"sensor.cpu_speed": {name: "CPU GHZ", div: "guage6_div", options: make_options(12)},
"sensor.cpu_temperature": {name: "CPU Ā°F", div: "guage7_div", options: make_options(200)},
"sensor.hass_db_size": {name: "DB Size", div: "guage8_div", options: make_options(64)},
"sensor.living_room_thermostat_temperature": {name: "Living", div: "guage9_div", options: make_options(100)},
"sensor.master_bedroom_temperature": {name: "Master", div: "guage10_div", options: make_options(100)},
"sensor.girls_room_temperature": {name: "Girls", div: "guage11_div", options: make_options(100)},
"sensor.boys_room_temperature": {name: "Boys", div: "guage12_div", options: make_options(100)},
"sensor.vision_zp3111_multisensor_4in1_temperature": {name: "Comp", div: "guage13_div", options: make_options(100)},
"sensor.living_room_thermostat_humidity": {name: "Living", div: "guage14_div", options: make_options(100)},
"sensor.master_bedroom_humidity": {name: "Master", div: "guage15_div", options: make_options(100)},
"sensor.girls_room_humidity": {name: "Girls", div: "guage16_div", options: make_options(100)},
"sensor.boys_room_humidity": {name: "Boys", div: "guage17_div", options: make_options(100)},
"sensor.vision_zp3111_multisensor_4in1_relative_humidity": {name: "Comp", div: "guage18_div", options: make_options(100)},
"sensor.master_bedroom_lux_level": {name: "Master", div: "guage19_div", options: make_options(100)},
"sensor.girls_room_lux_level": {name: "Girls", div: "guage20_div", options: make_options(100)},
"sensor.boys_room_lux_level": {name: "Boys", div: "guage21_div", options: make_options(100)},
"sensor.vision_zp3111_multisensor_4in1_luminance": {name: "Comp", div: "guage22_div", options: make_options(100)},
"sensor.dome_motion_detector_luminance": {name: "Bath", div: "guage23_div", options: make_options(100)},
"sensor.bruce_fuel_level": {name: "Bruce", div: "guage24_div", options: make_options(100)},
"sensor.chevy_fuel_level": {name: "Chevy", div: "guage25_div", options: make_options(100)}
function init() {
const status = document.getElementById('status');
google.charts.load('current', {'packages':['gauge']});
google.charts.setOnLoadCallback(drawChart);
function render(entities) {
_.forEach(guages, function(guage, key) {
try {
var svalue = entities[key].state;
guage["data"].setValue(0, 1, svalue);
guage["chart"].draw(guage["data"], guage["options"]);
} catch(e) {
// Uncomment to see all state read failures in console
// console.log("Error reading state for key: " + key);
status.innerHTML = "Error reading state for key: " + key;
function drawChart() {
_.forEach(guages, function(guage) {
guage.data = google.visualization.arrayToDataTable([['Label', 'Value'], [guage.name, -1]]);
guage.chart = new google.visualization.Gauge(document.getElementById(guage.div));
guage.chart.draw(guage.data, guage.options);
HAWS.createConnection(URL).then(conn => {
status.innerHTML = 'Connected';
HAWS.subscribeEntities(conn, render);
}, err => { status.innerHTML = `Connection error: (${err})`; });
</script>
</head>
<body onload="init();">
<h4><span id='status'>Connecting...</span></h4>
<h1>System Resouces</h1>
<ul class="flex-container wrap">
<li class="flex-item" id='guage0_div'></li>
<li class="flex-item" id='guage1_div'></li>
<li class="flex-item" id='guage2_div'></li>
<li class="flex-item" id='guage3_div'></li>
<li class="flex-item" id='guage6_div'></li>
<li class="flex-item" id='guage7_div'></li>
<li class="flex-item" id='guage8_div'></li>
</ul>
<h1>Room Temp Ā°F</h1>
<li class="flex-item" id='guage9_div'></li>
<li class="flex-item" id='guage10_div'></li>
<li class="flex-item" id='guage11_div'></li>
<li class="flex-item" id='guage12_div'></li>
<li class="flex-item" id='guage13_div'></li>
</ul>
<h1>Humidity Level %</h1>
<li class="flex-item" id='guage14_div'></li>
<li class="flex-item" id='guage15_div'></li>
<li class="flex-item" id='guage16_div'></li>
<li class="flex-item" id='guage17_div'></li>
<li class="flex-item" id='guage18_div'></li>
</ul>
<h1>LUX Level %</h1>
<li class="flex-item" id='guage19_div'></li>
<li class="flex-item" id='guage20_div'></li>
<li class="flex-item" id='guage21_div'></li>
<li class="flex-item" id='guage22_div'></li>
<li class="flex-item" id='guage23_div'></li>
</ul>
<h1>Fuel Level %</h1>
<li class="flex-item" id='guage24_div'></li>
<li class="flex-item" id='guage25_div'></li>
</ul>
</body>
</html>
