Wow, this was exctly my problem. I don’t think in a lifetime I would have suspected this was the problem. You made my day. Thanks!
hello. I am struggling with this error. When I log in to Google Assistant it gives me an error message: Could not connect with [test]
How did they solve it?
Same problem here. No solution yet.
Stil struggling here. Tried several ‘solutions’. But no success…
Like this; How to connect Google Assistant using the Cloudflare tunnel - #38 by paulbaird87
and this: Google Home: Could not reach [test] myapp. Please try again - #58 by Tomcose96
no success at all…
This fixed it for me as well! Turning off ‘bot fight mode’ in cloudflare under ‘security’ → bots
Thanks you! After digging through so much, this was my issue as well. Turning off bot fighting in cloudflare fix the issue
I didn’t even think about Cloudflare blocking it. Thanks!
I try to stay anonymous most of the time. But after several months on being unable to configure Google Home I found out what was wrong with my setup so I had to create an account to share it.
Everything was fine, except that my firewall had a GEO IP blocking. So it was letting me sign in but blocking Google Requests. When disabled the Geo IP firewall rule voilá… IT WOOOORKS
So happy!
Thank you!
Adding an OAuth consent screen solved it for me as well.
August 2025
Bot fight mode in Cloudflare got me!! As soon as I switched it off I was able to link it. I had all this working years ago but it had messed up and I finally got around to troubleshooting more today. Thanks!
